Results 1 to 8 of 8
  1. #1
    Junior Member Achievements:
    15429
    Jan 2011
    Iconia does not have "Turn on USB storage" when plugged in
    When I plug my Acer Iconia into my comp via mini USB cord supplied, I do not get the usual "Turn on USB storage" tab.
    It does come up and say "USB debugging connected.
    AND my computer recognizes it, but it does not seem to be connecting completely.
    Docs to Go does not recognize it as connected.
    The Computer does not show access to external minisd.
    Any help is much appreciated.
    Thanks!
    Ads
  3. #2
    Points: 54,494, Level: 100
    Overall activity: 89.0%
    Achievements:
    Veteran 50,000 Experience Points 25,000 Experience Points 10,000 Experience Points 1 year registered
    28319
    Apr 2011
    1,523
    Thanked
    186 times
    Points
    54,494
    Level
    100
    If this persists after rebooting your computer, try a different computer.
    Also what version of Android are you running.
    And your computer, what OS version is that running?
    The acer won't show up as a disk drive, its going to show up under the name of Acer. Its a MTP device. So your computer
    has to know what to do with that.
  4. #3
    Points: 6,384, Level: 52
    Level completed: 17%, Points required for next Level: 166
    Overall activity: 38.0%
    Achievements:
    Veteran Recommendation Second Class 5,000 Experience Points 1 year registered 1,000 Experience Points
    35054
    Jun 2011
    Kyneton, Australia
    1,031
    Thanked
    70 times
    Points
    6,384
    Level
    52
    Quote Originally Posted by lvilleflyer View Post
    Thanks!
    Have you downloaded the driver for your PC from the ACER WEBSITE?
    Try that first.
    ICONIA A500
    Galaxy Note 10.1
    I believe therefore I have spoken....
    Be Gronk - bloop bloop nleep nleep swoosh swoosh innajeep.
    Now where is That Simlish Dictionary!
  5. #4
    31 days registered 7 days registered 100 Experience Points
    52766
    Sep 2011
    Tucson, AZ
    11
    Acer a500
    you must be running HC3.2 to be able to see the external SD card when connected to the pc.
    You must also install the Acer usb driver in order to see the device. if youre running windows xp media player 11 must be installed.
  6. #5
    15429
    Jan 2011
    Thanks for the replies!
    I have already downloaded the driver to PC.
    I ultimately care about getting my Docs to Go to recognize my tablet so it will sync.
    Shouldn't the tablet come up with "Allow USB connection" or something along those lines?
  7. #6
    Achievements:
    35054
    Jun 2011
    Kyneton, Australia
    1,031
    Thanked
    70 times
    Points
    6,384
    Level
    52
    Have you got DTG on your PC? I've omly got it on the A500. On my PC I have MSOFFICE Corporate edition. I don't use the Sync option because I copy the stuff I want leaving the stuff I don't.
    Do you have DTG the full version? Certain options are not available with the free version.
    ICONIA A500
    Galaxy Note 10.1
  8. #7
    15429
    Jan 2011
    I double checked to make sure that My full version is on my Acer. Indeed it is.
    on DocsToGo help site, it says to deselect the Debugging.
    1-2 secs after I click on the box to deselect Debugging, it automatically gets selected again.
    to make matters more confusing,
    I decided to try Acersync...
    It seemed to work the first time to download my files, but now when I go to sync, it Fails everytime.
  9. #8
    Achievements:
    35054
    Jun 2011
    Kyneton, Australia
    1,031
    Thanked
    70 times
    Points
    6,384
    Level
    52
    Have you tried a different USB port on your PC? I have had issues with USB ports on all the different PCs (laptops, desktops, netbooks...) where a device with not work on one port but when plugged into another it installs and works fine.
    I've had this issue almost on a daily basis because I service a large range of MFDs of a particular brand. Some models when I need to do a firmware upgrade the machine needs to be put in a particular mode and I have to uninstall USB composite printing on my work laptop before my laptop will see the MFDs as a mass storage device - so I can copy the MFD's address book and user settings on to the laptop desktop before I do the upgrade.
    ICONIA A500
    Galaxy Note 10.1
Ads:
  1. "Download Unsuccessful" of Market Apps on Acer Iconia Tab A500?
    By Jeff Modzelewski in forum Acer Iconia Tab A500 Forum
    Last Post: 05-26-2012, 07:42 PM
  2. Replies: 4
    Last Post: 02-23-2012, 08:51 PM
  3. Problems getting TF to "see" files on desktop media file storage
    By Warkman in forum Asus TF101/SL101 Forum
    Last Post: 09-04-2011, 03:56 AM
  4. Acer Iconia A500 "No wifi connection"
    By odirty06 in forum Acer Iconia Tab A500 Forum
    Last Post: 08-01-2011, 09:20 AM
  5. Replies: 0
    Last Post: 02-02-2011, 03:42 PM
acer a500 pc wont read usb
acer a500 usb mass storage
acer iconia mass storage mode
acer tablet cant find mass storage
connect wii mote to acer iconia b1-710
enable debugging on acer a210
enable usb debugging iconia
how disable debagging on acer a500 android
how to enable mass storage in acer iconia a1-811
how to show acer a501 as storage device on computer
my computor does not recognise my acer iconia b1-710
my laptop does not recognize my tablet acer iconia a1-810
