Page 4 of 4 FirstFirst ... 2 3 4
Results 31 to 38 of 38
Thanks Tree6Thanks
Thread: MicroSD will NOT mount!!
  1. #31
    Member Achievements:
    3 months registered 500 Experience Points 250 Experience Points 31 days registered 100 Experience Points
    67212
    Dec 2011
    36
    Thanked
    1 times
    I had a similar issue, here's what solved it for me:
    On rooted stock HC 3.2 ROM, I first formatted a Samsung-branded 16gb Class 4 SDHC MicroSD card using Window 7.
    Formatted the card to NTFS (which HC 3.2 will recognize) and FAT32. Neither would mount.
    Then, I put the card in an Android phone (GB 2.2) and formatted it. That worked.
    So, suggest updating your ROM to 3.2 for NTFS support. Then try formatting the card in an Android device if that doesn't work.
    Ads
  3. #32
    Points: 52,432, Level: 100
    Overall activity: 11.0%
    Achievements:
    Veteran 50,000 Experience Points 25,000 Experience Points 10,000 Experience Points 1 year registered
    28319
    Apr 2011
    1,523
    Thanked
    186 times
    Points
    52,432
    Level
    100
    Quote Originally Posted by jpinsl View Post
    Look, folks, this is how superstitions get started.
    People try all sorts of shotgun solutions and at some point it works, so they assume you have to go thru all those steps.
    Format the card in Windows, and check the option to "check for errors".
    Power down the tablet, then insert card. Then Power up and GIVE IT A FEW MINUTES.
    The reboot is often necessary because when you insert any memory device the Acer rebuilds a cache of
    thumbnails. If you start plugging and unplugging while it is either clearing or rebuilding thumbnails you confuse
    it to the point where it just gives up and ignores the tablet.
    There is no reason to format to NTFS or format in another phone or any of that stuff.
    This isn't a disk drive where the heads can be misaligned from one computer to the next.
    I was eating fried chicken at the time I formatted my Microsd card. Maybe it will work for you.
  4. #33
    Points: 10,186, Level: 67
    Level completed: 34%, Points required for next Level: 264
    Overall activity: 0%
    Achievements:
    10,000 Experience Points 5,000 Experience Points 1 year registered 1,000 Experience Points 500 Experience Points
    18376
    Feb 2011
    Washington State
    1,653
    Thanked
    193 times
    Points
    10,186
    Level
    67
    Hauwei S7
    The old fried chicken sd mount method, I heard it actually increases the spead of read/write access as well. Probably the grease, but that's just a guess and I don't want anyone to be disappointed if they aren't technically proficient enough to implement it properly.
    Sent from a Gibson using Tapatalk - heavy metal edition
    Huawei S7 104 (BB)
    Froyo 2.2.2 S7V100R001C98B021
    SOC Rooted - link2sd
    Samsung Galaxy Note 10.1
    SS SsS oo
  5. #34
    Super Moderator Achievements:
    12338
    Jan 2011
    Northern CA
    5,174
    Thanked
    899 times
    Was it crispy or regular? I'm still having issues and hope you can tell me
    Nexus 7
    Nook Color -
    (eMMC): CM10 Nightlies
    Nook Tablet 16GB: Jelly Bean
    VTAB1008: Rooted Gingerbread
    Android OS Help & How To
  6. #35
    Junior Member Achievements:
    31 days registered 100 Experience Points 7 days registered
    81361
    Jan 2012
    Cencal
    9
    Acer Iconia A500
    Lmao Icebike!!
    Thank you all for your help.
    I ended up sending it back to where I bought it for an exchange...I hope the next one performs better.
    Now I have to wait again to get it.
  7. #36
    Points: 5,772, Level: 49
    Level completed: 11%, Points required for next Level: 178
    Overall activity: 18.0%
    Achievements:
    5,000 Experience Points 1 year registered 1,000 Experience Points 500 Experience Points 250 Experience Points
    35054
    Jun 2011
    Kyneton, Australia
    1,016
    Thanked
    70 times
    Points
    5,772
    Level
    49
    Quote Originally Posted by Icebike View Post
    Was the famous SOUTHERN FRIED variety? Come on it got to be!
    ICONIA A500
    Galaxy Note 10.1
    I believe therefore I have spoken....
    Be Gronk - bloop bloop nleep nleep swoosh swoosh innajeep.
    Now where is That Simlish Dictionary!
  8. #37
    81361
    Jan 2012
    Cencal
    9
    Acer Iconia A500
    Wooot!! Got my replacement A500 and the MicroSD mounts perfect!! It must have been a software issue. I'm so glad this bad boy is up to speed.
    Now I'm just downloading and installing the gobs of OS updates! What is the OS number for ICS? 4.1? So far mine has updated to 3.2.
    Thanks again all for your help- Close the book.
  9. #38
    Achievements:
    28319
    Apr 2011
    1,523
    Thanked
    186 times
    Points
    52,432
    Level
    100
    Doubt it was a software issue. I'm suspecting damaged/dirty microSD contacts in the slot.
    If it were software, far more people would be reporting it.
Ads:
  1. Car Mount or Pad Holder
    By tipstir in forum Android Tablet Discussions
    Last Post: 08-29-2013, 04:16 AM
  2. Car headrest mount
    By s971001 in forum Acer Iconia Tab A500 Accessories
    Last Post: 07-22-2011, 06:25 AM
  3. Can't mount SD card after new ROM
    By theksp111 in forum Nook Color Technical
    Last Post: 05-24-2011, 10:53 PM
  4. mount usb drive
    By ferraresi in forum Android Tablet Q&A
    Last Post: 03-29-2011, 08:58 AM
  5. Can't get sdcard to mount
    By zeffuri in forum Coby Tablet Accessories
    Last Post: 01-27-2011, 11:53 AM
16gb sdhc wont mount in tablet
galaxy s2 won't mount micro sd card
micro sd card not mounting
micro sd card will not mount
micro sd card won't mount
micro sd card wont mount
sd card that will not mount on xp
sd card wont mount in my toshiba thrive
sd card wont mount on samsung galaxy tab 2
sd wont mount on galaxy tab 2
tmax tablet sd card won't mount
why cant i mount my micro sd card
Tags for this Thread
