Page 1 of 2 1 2 LastLast
Results 1 to 10 of 13
  1. #1
    Junior Member Achievements:
    1,000 Experience Points 3 months registered 1 year registered 250 Experience Points 500 Experience Points
    33437
    May 2011
    22
    Angry Need factory firmware for Mach speed technology trio stealth 7 pro
    This company gave me no support in finding the firmware for this tablet, I have screen rotation 45 degree off, and the keys are not functioning after using a different ROM. Please help.
    Trio Stealth Pro 7 | Trio Media Players by Mach Speed Technologies
    • Dimensions- W7.5” x H4.8” x D0.4”
    • Operating System- Android™ 4.0 (Ice Cream Sandwich)
    • CPU – A10 Cortex A8 1.2 GHz
    • GPU – Dual Mali-400 2D/3D core
    • RAM – 512MB DDR3
    • Flash storage – 4GB Internal
    • Display – 7 inch TFT LCD
    • Native Resolution – 800480 pix
    • Expansion – Micro SD card slot (up to 32GB), Mini HDMI Socket
    • Wireless LAN – Realtek 8188
    • Video Output – HDMI Ver 1.4 output
    • Native video support – AVI(H.264), DIVX, XVID, RM, RMVB, MKV, WMV (non encrypted), MP4(H.264, MPEG, DIVX, XVID), MPEG, MPG, FLV. HD 1080P max.
    • Native Audio Support – MP3,WMA (non encrypted),MP2,OGG,M4A,MA4,FLAC,3GP,WAV
    • Battery – Li-Ion rechargeable, up to 6 hours playtime
    Ads
  3. #2
    500 Experience Points 250 Experience Points 31 days registered 3 months registered 7 days registered
    125212
    Jun 2012
    Paris
    9
    AZhuo A10MID
    Seems to be another clone of the LY-F1 : SHENZHEN LYRIC PIONEER CO., LTD-LYXF TABLE PC --- Products
    May be you could use some of their rom ? SHENZHEN LYRIC PIONEER CO., LTD-LYXF TABLE PC --- DownLoads
    Odrade
  4. #3
    33437
    May 2011
    22
    Thank you for the information, I was told that the network chip is different though, which could mean incompatibility and no wifi.
  5. #4
    132457
    Aug 2012
    United States
    Visual Land Prestige 7
    Quote Originally Posted by Goes View Post
    I can't give help, but can repeat the request. I have this tablet w Android 4.0.3, which causes netflix to freeze after 5 min of movie play. This is a well known problem, and solved w Android 4.0.4. I have a friend who just bought this tablet, and his has Android 4.0.4 on it. I called tech support to request firmware update. The courteous, but extremely unhelpful tech support person said 1) never heard of problem (google netflix android 4.0.3 and you will get lots of hits) and 2) offered no solution other than mailing tablet back to factory. All I wanted was link to 4.0.4, which I know they are using, and I can fix the problem quickly if I have the image. Big BOOO for Mach Speed tech support.
  6. #5
    33437
    May 2011
    22
    I was able to get an unofficial CM9 working on my tablet as it is a LY-F1 clone and everything is fine now. As for Mach speed technology, it is the worse company I have ever dealt with, even their support web site has nothing at all.
  7. #6
    137892
    Aug 2012
    chicago
    machspeed trio
    step by step
    Can you provide me with how you did that I have same tablet which I tried to root but keep getting error on gapp install
  8. #7
    33437
    May 2011
    22
    use this script to get Google play. https://www.dropbox.com/s/izqfn0qzf7o0ev6/polroot.zip
  9. #8
    141003
    Sep 2012
    MachSpeed Trio Stealth Pro 7
    Oops
    I'm not new to flashing android, having experience with Motorola and Samsung phones. Very good with directions, and searching for tools, info, etc. Polroot did not work for me, there was no way to set ADB on the device when I first got it, the setting was absent from the system (maybe new shipments are locked a bit tighter?) Well, being the impatient adventurer, I decided LiveSuite and Phoenix would do the job, so flashed A10 images. Only the 4.0.3 images will completely flash, and those sit at the droid image (bootloop). All these Chinese sites, my brain hurts, and now I have managed to turn my daughters present into a paper weight. Is there a Phoenix, or LiveSuite image that I can flash to this thing to get it up again? Otherwise, Tiger is getting this thing back on Monday.
  10. #9
    33437
    May 2011
    22
    The Chinese ROM can be easily chnged to Englsih by accessing the Key
  11. #10
    140983
    Sep 2012
    Orkia ok-p555
    Hi odrade,...This my model ... my tablet not loading at the android icon screen....I download eken t10 firmware, and installed it..But it ain't working....Can you help me on this...
    Orkia Android 4 Tablet Capacitive Screen @ Rs. 4999/- Call 9594404726 - Mumbai: Mobile - Cell Phones in Mumbai at Quikr Mumbai
    Processor - Cortex A10, 1.2GHz
    Operation System - Android 4.0.3 (Ice Cream Sandwich O.S.)
    RAM -512MB DDR3
    Nand Flash - 4GB
    AllGravity Sensor
    Screen Size - 7 Inch HD,
    Screen Type - Capacitive Screen
    HD Video Player
    HDMI out
    Resolution - 800 x 480
    Visible Angle - 150
    3G - Support 3G/WCDMA dongle
    Expandable Memory - Support TF card up to 32 GB
    Thanks in advance
Ads:
  1. Download Apps for Trio Stealth
    By nzinger11 in forum Android Tablet Q&A
    Last Post: 01-08-2014, 09:08 PM
  2. Mach Speed Trio Stealth Pro 7C Internet Tablet $99.00
    By tiltrotor22 in forum Android Tablet Reviews
    Last Post: 07-25-2013, 10:45 AM
  3. factory firmware for wondermedia 8650
    By yasserayad in forum WonderMedia WM8650 Tablets
    Last Post: 07-09-2013, 09:34 AM
  4. Trio Stealth Pro 7 - Zeki Killer ?
    By PureDigital in forum Android Tablet Discussions
    Last Post: 06-25-2012, 05:20 PM
  5. Replies: 1
    Last Post: 07-04-2011, 09:44 PM
firmware for trio stealthg2 7 tablet
firmware tablet trio
how to update trio mach stealth pro
looking for trio tablet firmware
ly-f1 clone .zip
room tablet trio
trio stealth g2 10.1 flash rom
trio stealth g2 firmware update
trio stealth pro 9.7 custom rom
trio stealth pro firmware
trio stealth pro firmware update
where to download trio stealth g2 stock firmware
