Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 30
Thanks Tree1Thanks
Thread: Need help stuck in boot loop
  1. #1
    136728
    Aug 2012
    20
    LY-F9S
    Exclamation Need help stuck in boot loop
    Hi All,
    im new to this forum, i received this Android tablet, it looks exactly like this SHENZHEN LYRIC PIONEER CO., LTD-LYXF TABLE PC --- Products
    my problem is, i installed an app called LCD Density Modder, being dumb i set the value very high as i was curios on how it'll work, so the app told me to reboot, I reboot, and now im stuck at the bootscreen "Android", I cant start up my tablet using the power button, but it will start the tablet using the reset button in the back, i tried pressing a key combination and i got into download mode, but if i can just get to the recovery mode i can do a factory reset from there.
    I just dont know how to get to recovery mode. Can anyone help me ?
    or even better, someone may have a the same firmware or suggest a firmware that is compatible with this tablet, and also a flash tool.
    Thank you very much
    Ads
  3. #2
    136728
    Aug 2012
    20
    LY-F9S
    Can someone help me ? i am in the download mode right now the "android with triangle" on it. what should i do next ? please help\
  4. #3
    Developer
    Points: 23,032, Level: 93
    Level completed: 69%, Points required for next Level: 318
    Overall activity: 65.0%
    Achievements:
    Recommendation Second Class 10,000 Experience Points 5,000 Experience Points 1 year registered 1,000 Experience Points
    61306
    Nov 2011
    Huntington WV
    3,670
    Thanked
    1372 times
    Points
    23,032
    Level
    93
    Coby 7065, Coby 8042, Coby 9740, Lenovo A2109
    If you have adb set up, during bootloop adb pull build.prop set correct settings example 120 for 7 or 8 inch screen. Save then adb push build.prop. reboot
  5. #4
    136728
    Aug 2012
    20
    LY-F9S
    Quote Originally Posted by vampirefo. View Post
    sorry but i do not know how to set that one up, is there anyway I can get to the tablets recovery mode without adb ?
  6. #5
    Developer
    Points: 20,302, Level: 89
    Level completed: 91%, Points required for next Level: 48
    Overall activity: 0%
    Achievements:
    10,000 Experience Points 5,000 Experience Points Recommendation Second Class 1 year registered 1,000 Experience Points
    22191
    Mar 2011
    Singapore
    361
    Thanked
    77 times
    Points
    20,302
    Level
    89
    Teclast P76ti
    your only bet is to try connecting via adb during the bootloop. If it does, it will help.
    Doing a factory reset will not revert the change in build.prop
  7. #6
    136728
    Aug 2012
    20
    LY-F9S
    Quote Originally Posted by KillerKink View Post
    Oh, thats bad news, im not really sure how to do that, i tried adb devices command using android sdk, but it doesnt list / recognize the device, can you tell me how to make the android device to detect ?
    really appreciate all your response. please bear with me
  8. #7
    136728
    Aug 2012
    20
    LY-F9S
    or even better, if there is a custom rom that is compatible with my tablet, LY-F9S i can try and flash it
  9. #8
    Developer
    Achievements:
    22191
    Mar 2011
    Singapore
    361
    Thanked
    77 times
    Points
    20,302
    Level
    89
    Teclast P76ti
    Quote Originally Posted by shoyru777 View Post
    adb need to be enable in the android system. If its not, then there is no way you will be able to access to it now.
    you need to install the adb driver before you can use it : Colonel Zap's Blog: Allwinner A10 ADB-Drivers
    here's a guide on how to use adb: How To Set Up ADB/USB Drivers for Android Devices (Updated 12/13/11) - TheUnlockrTheUnlockr
  10. #9
    136728
    Aug 2012
    20
    LY-F9S
    Thank you KillerKink, i will try this one out, I'll keep you posted.
    Thank you very much
  11. #10
    136728
    Aug 2012
    20
    LY-F9S
    Unfortunately, since my device is already in bootloop, i won't be able to check the USB Debugging mode, darn, does this means this tablet is useless now ?
Ads:
  1. 4.1.1 Install now stuck in boot loop
    By antoeknee in forum Coby Generation 2
    Last Post: 08-16-2012, 10:03 PM
  2. Tablet Newbie stuck in boot loop (if that's what it's called)
    By QTjedigrl in forum Viewsonic gTablet
    Last Post: 05-06-2012, 11:51 AM
  3. 7012 stuck at Coby splash screen boot loop
    By StizzyNyC in forum Coby Generation 1
    Last Post: 05-03-2012, 03:43 PM
  4. HELP 7127 Stuck in Boot Loop!
    By LiquidFire187 in forum Coby Generation 2 Technical
    Last Post: 12-31-2011, 08:43 AM
  5. Stuck with infinite boot loop
    By Woody619 in forum Huawei Ideos S7
    Last Post: 03-23-2011, 02:35 AM
a13 allwinner recovery loop problem
allwinner a13 recovery mode
android tablet is in bootloop
how to fix boot loop on allwinner a10?
how to fix bootloop rca tablet
infinite tab 786dc
mid t900 allwinner stuck boot screen
pioneer tst-7r1-l tablet stuck on boot up screen
rca tablet bootloop
rca tablet change build prop bootloop
rca tablet stock build prop
tablet stuck on android loop
