Results 1 to 8 of 8
  1. #1
    Junior Member Achievements:
    7 days registered 31 days registered 100 Experience Points
    119258
    Jun 2012
    serbia
    blueberry netcat m-06
    few problems with tablet
    i have few problems with my tablet. it is blueberry netcat m-06 from serbian market, but basicly it is iview 760tpc (ployer momo9).
    here is spec.
    allwinner a10 1,2ghz
    mali-400
    512ram ddr3
    4gb (2gb for internal memory, 2gb for sd card)
    16gb memory card
    ics 4.0.3
    i install all iview and momo9 stock roms and everything works as it should, install cwm, superuser but i cant fully boot cm9, aokp and any other custom rom. they all stuck at boot logo after install from cwm.
    only custom rom that install and fully boot is fun series v3.0, but it is for micromax funbook and hardware buttons (menu, back, home) wont respond. those three hard butoons is touch (not mehanical with micro switch). they work in stock rom for iview .
    are there any solutions for those problems (tried over google, different forums, but cant found anything)?
    Ads
    Advertising world
  3. #2
    7 days registered
    134484
    Aug 2012
    Ireland
    A10 MID(McPad F1), Transformer Infinity
    What partition did you install CWM to?
  4. #3
    119258
    Jun 2012
    serbia
    im install cwm from script specifically made for AllWinner A10 tablets iview760tpc (a.k.a ployer momo9), then use novotool to enter the recovery mode, then wipe data/factory reset, erase dalvik catche then install cm9, gaps then compatibility pack from internal sd card (not extsd) beacuse it said e:cant mount extsd. ill try that and every combination of those steps. every time tablet stucks at cm9 picture boot logo. i even let boot logo for an hour.
  5. #4
    500 Experience Points 250 Experience Points 3 months registered 31 days registered 100 Experience Points
    109707
    Apr 2012
    Barbados
    20
    Thanked
    2 times
    Ainol Novo 7 Aurora, Ainol Novo 7 Advance, Aoson M11
    Hey nule4
    I would recommend heading over to Tabletrepublic.com. They specialize in Chinese tablets and they have an expert on board for Iview.
    Good luck and let us know how it goes.
  6. #5
    137718
    Aug 2012
    Tablet asking for a code to unlock screen. Does anybody know code.
  7. #6
    119258
    Jun 2012
    serbia
    thanks for advice.
  8. #7
    119258
    Jun 2012
    serbia
    i discover what it is. it was 16gb external sd card that makes boot problem. spec. are trascedent 16gb micro sdhc class 2. but in fun series v3.0 it work perfectly.
    in fact i tried several different sd cards from different vendors and sizes, non of them wont work in cm9 and aokp, tablet wont recognised them.
  9. #8
    119258
    Jun 2012
    serbia
    i format sdcard with "SDFormatter" and now it work as it should.
Ads:
  1. Tablet problems :(
    By Smorin4408 in forum Sony Tablet S
    Last Post: 09-29-2012, 06:45 AM
  2. app problems for tablet :(
    By byronrobs in forum Tel7
    Last Post: 01-08-2012, 07:22 AM
  3. Help me please!! My tablet is having problems...
    By Jatz in forum Android Tablet Q&A
    Last Post: 10-18-2011, 12:20 AM
  4. Replies: 0
    Last Post: 10-06-2011, 09:09 AM
a13 android tablet hard reset#gsc.tab
a13 tablet recovery factory reset
a13-mid hard reset
hard reset a13-mid
hard reset mid a13
hardware reset on a13-mid tablet
how to mount card on blueberry netcat 4
i view tablet/reset
iview tablet hardrest
mid a13 hard reset
ployer momo9 hard reset
tablet netcat m 17 specifications
