Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 21 to 30 of 33
Thanks Tree4Thanks
Thread: How to load firmware from nothing
  1. #21
    Junior Member Achievements:
    250 Experience Points 100 Experience Points 7 days registered
    126518
    Jul 2012
    19
    Allwinner A13
    It's downloading pretty slow, but I'll update this post when I'm done fiddling around with it. Thanks for your help again.
    EDIT: Ok, got it to boot up and everything is fine except the screen. There are quite a few quirks here though.
    The broken english in the word document tutorial and the video being silent did not help at all.
    You are going to have to rename the key and img files. For some reason the Phoenix Pro application wouldn't "Start Production" until they had different file names. I have no idea why. I renamed them Key.key and A13.img respectively.
    The screen is about 1cm off to the left. May be a hardware difference between the mcbub a13 and the one I have. I will try other images I may find.
    EDIT 2: Looks like I need a seperate Key file for each FW img or something. It won't load another A13 img I have.
    Ads
  3. #22
    126518
    Jul 2012
    19
    Allwinner A13
    Oh, man, have I gone down a rabbit hole on this one.
    I got CWM on this thing (5.5.0.4) but it has no back button or option in the lists of selections within CWM.
    After that I was able to get GAPPS on it from here:
    allwinner-cm9.googlecode.com/files/gapps-ics-20120429-signed.zip
    I still have the issue with the display being about 1cm to the left. I can't tell if it's because of the McBub FW that's on it or not. I think I messed something up when I took it apart because even clockworkmod is shifted. I don't know.
    To get CWM on this thing just follow instructions here:
    [Script/Mod] For Allwinner A1X platforms - SlateDroid.com
    After that I installed Cyanogen Mod 9 on it. It worked, but no touch screen. I didn't wipe my caches though... maybe it'd work if I did that... Oh well, food for thought.
    Thanks again vamps for all your help. Maybe you know where I could find another A13 img to fix this screen issue? I'm not afraid of testing crap, as you can tell.
  4. #23
    Developer
    Points: 23,036, Level: 93
    Level completed: 69%, Points required for next Level: 314
    Overall activity: 71.0%
    Achievements:
    Recommendation Second Class 10,000 Experience Points 5,000 Experience Points 1 year registered 1,000 Experience Points
    61306
    Nov 2011
    Huntington WV
    3,670
    Thanked
    1372 times
    Points
    23,036
    Level
    93
    Coby 7065, Coby 8042, Coby 9740, Lenovo A2109
    We need to find your exact device, yours isn't the Mcpad F1, that's why you are seeing screen offset, a lot of firmware will work on many different allwinners, as in this case, but there maybe some offsets, like you are having. If you can find someone will your exact tablet, and have them dump the bootloader, system and boot.img you could restore that to yours and have a good tablet.
  5. #24
    126518
    Jul 2012
    19
    Allwinner A13
    Exactly my thoughts. I really have no way of finding out though, shady Chinese dealer sending me the wrong tablet. Pretty certain they won't be replying to any e-mails regarding specifics of their hardware serial numbers.
    So, like I said, if you happen to find any IMGs out there for this design I'd be happy to test 'em for you
  6. #25
    130325
    Jul 2012
    Thanked
    1 times
    Quote Originally Posted by poursoul View Post
    I had the same problem on one of my tablets (image shifted to the left) and my tablet looks cosmetically the same as yours, try this firmware
    https://www.dropbox.com/s/hg23fvxun3vt7m3/DCPAD2121.zip
    It worked for me.
    poursoul thanked this.
  7. #26
    126518
    Jul 2012
    19
    Allwinner A13
    I will try it as soon as I can find the tablet. Girlfriend hides it from me to keep me from messing with it :P
    She should be happy if it works, thanks a ton for the link.
    EDIT: Everything is centered! Thanks again! w00t!
  8. #27
    126518
    Jul 2012
    19
    Allwinner A13
    @kmr1962 Where did you get the link for that? Please name as many names as you can.
  9. #28
    500 Experience Points 3 months registered 250 Experience Points 100 Experience Points 31 days registered
    128342
    Jul 2012
    Oxford UK
    9
    unbranded chinese tablet A13(A8 cortex)
    The Livesuit loads the firmware from nothing. Where are you located
  10. #29
    128342
    Jul 2012
    Oxford UK
    9
    Can you find out from the seller where the tablet came from i.e. which factory in China.
  11. #30
    126518
    Jul 2012
    19
    Allwinner A13
    I'm all set as far as firmware. The tablet is working great now thanks to kmr1962.
    The forum won't let me post links yet. So I'll give a description. The site is ali Express and the tablet is listed as an Eken T01, but I can assure you that it is definitely not one. They even list the T01 specs, bastards. This is definitely an Allwinner A13, similar to the McBub model.
    The manufacturer on that site is simply listed as:
    Original brand mobile phone OEM factory
    Store No.603716
    So no, no real info. I did get a 20% refund back though through Ali Express which equaled out to $17.
Ads:
  1. Can't load widgets
    By curtsr in forum Ice Cream Sandwich
    Last Post: 03-24-2012, 10:05 AM
  2. Apps won't load
    By racer48 in forum Velocity Micro Tablets
    Last Post: 01-23-2012, 07:15 PM
  3. no files will load
    By saq in forum Pandigital Novel
    Last Post: 10-13-2011, 09:23 PM
  4. epad will not load
    By Michelle_o_rn in forum Android Tablet Q&A
    Last Post: 05-23-2011, 11:12 AM
  5. How to load Android 2.2?
    By labatts6972 in forum Gome Flytouch II Variant 2
    Last Post: 04-12-2011, 04:43 PM
a13 fastboot
a13 q88 firmware
allwinner a13 2012-08-01.img
allwinner a13 fastboot
allwinner a13 firmware
allwinner a13 q88 firmware
allwinner a13 q88 firmware download
allwinner a13 rom img
allwinner a13 wont boot
cmw allwinner a13 cortex 9
download firmware img allwinner a13
q88 del allwinner a13 firmware
