Page 2 of 2 FirstFirst 1 2
Results 11 to 13 of 13
Thanks Tree1Thanks
Thread: [DEV][ROM]Unofficial CyanogenMod 9 for many Boxchip/Allwinner A13 tablets Print Em
  1. #11
    161724
    Dec 2012
    Hungary
    Yeahpad A13
    Hi! Please check this file
    Ads
    Advertising world
  3. #12
    162233
    Dec 2012
    A13MID Some sort of AllWinner Tablet
    Hi, so far this is the most successfull rom I've tried. I've used clockworkmod to make a backup and to "update" the ROM to yours.
    But the touch screen doesn't work. It's in Russian, but apart from that the OS seems to be running smoothly.
    Could you suggest any changes that I could make to activate the touch screen, or would you say that it should be classed as entirely broken? I've already tried changing the default build.prop screen density from 120 to 160 to no avail.
    I'm running on a AllWinner A13MID tablet. Capacitive touchscreen, wifi, etc etc.
  4. #13
    Junior Member Achievements:
    166710
    Jan 2013
    Thanked
    1 times
    Hipstreet Aurora (HS-7DTB6-8GBR)
    HS-7DTB6-8GBR support...
    Love what you're doing here! Was interested to see how this ran on my A13 device... Hipstreet Aurora (HS-7DTB6-8GBR):
    CPU - A13 @ 1.2GHz
    Display - 7” 800x480 resolution, Capacitive Touch
    RAM - 512MB DDR3
    Memory - 8GB (Expandable to 32GB via Micro-SD)
    OS - Google Android 4.0 (ICS)
    Everything looks real nice, but my testing was limited... the touchscreen response was inverted (right is left, left is right; though top and bottom was correct). One other thing noticed right away was that the home-screen from the Trebuchet launcher went slightly off screen (i.e. the analog clock).
    If it helps, here's my stock dump, that is if your interested in supporting the Aurora - HS_7DTB6_8GBR_dump.zip - 169.81 MB
    Oh, and BTW, your CWM port... awesome! Again, some button mapping differences - the Aurora doesn't have a back button, so no way to go back If I need to shutdown, or reboot, I just hold the down the power button and go from there... the device does have a Home hardware key that I guess could be ported as a back button. Also, the Vol+ and Vol- buttons are reversed, but again, I can work around that as well.
    Thanks for everything you've done so far!
    Cha1n5aW thanked this.
Ads:
  1. Replies: 20
    Last Post: 07-26-2013, 04:30 AM
  2. [devs needed] Unofficial CyanogenMod7/2.3.3 port for RK2818 tablets
    By geoRG77 in forum Rockchip RK2818 Tablets
    Last Post: 03-30-2013, 06:41 AM
  3. [ROM] Unofficial CyanogenMod 7.2.0 KK Edition
    By KillerKink in forum Teclast P76ti
    Last Post: 02-17-2013, 03:36 PM
  4. [ROM] Unofficial CyanogenMod 9 KK Edition (Beta 7)
    Last Post: 10-30-2012, 11:21 AM
  5. [ROM] Unofficial CyanogenMod 10 KK Edition (Beta 3)
    Last Post: 09-16-2012, 12:27 AM
allwinner a13 cyanogenmod
allwinner a13 firmware download
allwinner a13 gps
allwinner a13 q88 firmware
allwinner a13 rom download
cm 11 for allwinner a13
cm11 for a13 tablets
cyanogenmod a13
cyanogenmod allwinner a13
cynogen for a13
full driver alleinner a10
rom allwinner a13
Tags for this Thread
