Results 1 to 10 of 10
  1. #1
    Junior Member Achievements:
    250 Experience Points 100 Experience Points
    133878
    Aug 2012
    MID android
    NEED help....tablet had battery symbol with triangle and exclamation point on screen.
    I was using my android tablet (MID--google tablet) and the battery was getting low. I plugged it up to charge and when I went back to use it about an hour later, there was a black screen with a battery on it. There is a triangle with an exclamation point in it. I unplugged the charger and tried to turn it on, but when I hold the power button, that pops up instead of starting the tablet.
    I have no idea what is wrong with it or how to fix it.
    Any ideas? What can I do to fix it?? I use my tablet ALL the time!
    I really appreciate the help...TIA!
    Attached Images Attached Images
    Ads
  3. #2
    Banned Achievements:
    150,000 Experience Points 100,000 Experience Points Recommendation First Class Tagger First Class Created Album pictures
    15754
    Jan 2011
    828
    Thanked
    443 times
    Try hard reset or volume+power
    Sent from my Smart ELF II 4.1 using Tapatalk 2
  4. #3
    133878
    Aug 2012
    MID android
    Quote Originally Posted by tragidy View Post
    I have tried the volume+power, but nothing....I have also pushed the reset button....how do you do a hard reset?
  5. #4
    Points: 1,753, Level: 24
    Level completed: 53%, Points required for next Level: 47
    Overall activity: 1.0%
    Achievements:
    1,000 Experience Points 1 year registered 500 Experience Points 3 months registered 250 Experience Points
    80299
    Jan 2012
    Toronto, Canada
    23
    Thanked
    1 times
    Points
    1,753
    Level
    24
    mid 9.7 android ics , playbook tablet
    Just curious is that a mid 9.7 screen I had the same thing except it was the android guy on his back with the same exclamation mark!
    Not too sure of buttons to press or if we have the same unit or not, I gave up on mine, did everything I knew but throw it out the window! I took mine back waiting for a new one any day now ?
    Just muck around with the buttons you'll find it eventually.
    good luck
  6. #5
    133878
    Aug 2012
    MID android
    It is google android F10 Android 4.0 7 in Capacitive Tablet PC....
    It's driving me crazy, not knowing how to fix it!
    Quote Originally Posted by Tim1131 View Post
    good luck
  7. #6
    100 Experience Points Your first Group 7 days registered
    131936
    Jul 2012
    United Kingdom
    57
    Thanked
    2 times
    looks like its not charging, that screen means it needs charging before it will turn back on.
    battery or charger fault? have you got a multimeter to test either?
  8. #7
    133878
    Aug 2012
    MID android
    Where do I take it to test the battery? I had it plugged up charging all night and it still had that this morning.
    I am not sure what a multimeter is?? I have tried the wall charger and also the adapter to the computer...neither worked...when I plugged it into the computer the computer chimed like it does when there is something connected to the port, but nothing ever came up on computer or tablet.
    Thanks!
    Quote Originally Posted by mugglesquop View Post
  9. #8
    131936
    Jul 2012
    United Kingdom
    57
    Thanked
    2 times
    o dear.
    if you dont know what a multimeter is, take it somewhere to be repaired - unless you want to learn basic electronics quickly
    the multimeter would be used on the battery connections to check the battery is ok, and if the charger is charging.
  10. #9
    147670
    Oct 2012
    pakistan
    china supernova
    Angry
    Dear ALL,
    1st remove the batter for few mints 5 or 10, (open ur tablet and remove it, or PUT your batter IN DIRECT-SUNLIGHT for atleast 5 HOURS,.than attach again, if still not works than follow below mentioned options.)
    2nd arange adapter (if batter operate on 5vdc than arange 10 6.5 vdc adapter)
    3rd connect batter with adpter for 5 mints (make sure Positive wire connect to positive terminal on battery)
    4th plugein battery again and enjoy.
    NO NEED TO DO ANY OTHER THING LIKE UPGRADE FIRMWARE ETC>
    all other are makking fulll.
    THIS IS PAKISTAN<.
    We hv solution for all. except cruption.
    Quote Originally Posted by fredregillc View Post
  11. #10
    150796
    Oct 2012
    I've had the same thing happen to my tablet, what is odd is that sometimes it charges okay and then it will go back to refusing to charge or turn on. Have you had any luck so far?
Ads:
  1. "green android icon holding a yellow triangle with an exclamation point"
    By atulbadani in forum Acer Iconia Tab A500 Forum
    Last Post: 08-18-2012, 11:58 AM
  2. help!!!! blue triangle with exclamation point
    By romiust in forum Vizio Tablets
    Last Post: 06-13-2012, 12:01 AM
  3. Android robot with a triangle with an exclamation mark
    By Cait7657 in forum Android Tablet Q&A
    Last Post: 01-30-2012, 11:45 AM
android charging exclamation mark
android tablet battery icon exclamation mark
battery triangle exclamation mark
galaxy tab 10.1 battery exclamation mark
galaxy tab battery exclamation mark
oclever tablet triangle exclamation mark
polaroid tablet battery exclamation
samsung galaxy tab battery exclamation mark
tablet battery with exclamation mark
tablet with exclamation mark
what does an exclamation mark mean on the pandigital tablet
what does the battery warning signal means on the tablet
