Results 1 to 7 of 7
  1. #1
    75012
    Dec 2011
    Canada
    Nextbook Premium 7
    Nextbook Premium 7, connection and speed
    I have the Nextbook Premium 7 ... and experiencing connection and internet speed issues. I have searched this site and it seems like a common issue is very common. I had to reset the system 2x to finally get the connection working, but then I can hardly get to any site. No Youtube videos will play, Nextbookusa.com will not even pull up. The odd time I may get msn.com, but only after a few minutes of me leaving it alone.
    I checked out the Nextbook product site and there is a firmware update, but not for my serial number. It does state the firmware is specifically for issues with connection and internet speed.
    Anyone have any other suggestions? If it does not work, I will be sending it back very soon.
    If I can get a fix going, I will be posting all my findings on the forum, plus my journey as I add apps, games etc. Forums are awesome !!
    Thanks for any help!
    Ads
    Advertising world
  3. #2
    75012
    Dec 2011
    Canada
    Nextbook Premium 7
    To fix the Nextbook Premium 7 connection and speed issue... goto :: Welcome to Nextbook.com :: and top right corner.... click on the firmware update.
    * Note- serial numbers listed are the 'ranges of serial numbers' and not just extra numbers.
    This took maybe 10minutes tops and worked great for me.
    Here is the video on how to install: ::Nextbook2::
  4. #3
    Junior Member Achievements:
    7 days registered
    78683
    Dec 2011
    Canada
    Next8p
    Hey, I have a next8p tablet and ive been having the same problems....
    The update didnt work for me, it said invalid file image, which is odd because my serial number matched with one of the listed ones
    Does this update only work for the next7p?
  5. #4
    7 days registered
    78683
    Dec 2011
    Canada
    Next8p
    Ah, I figured it out for the next8p...
    First i changed the channel my wifi was on from 6 to 1.. there are 12 different channels i just picked one....
    I hope it helps anyone else with similar problems on the next8p tablet
  6. #5
    87157
    Jan 2012
    ontario
    nextbook 8
    I have the nextbook 8 also and its sooooo slow and tried almost everything. Where are the channels on the wifi to change. Is it on the nextbook 8 or wifi router.
  7. #6
    7 days registered
    78683
    Dec 2011
    Canada
    Next8p
    Quote Originally Posted by imakarguy View Post
    Its in the route settings, its only a temp fix tho i installed a custom ROM on it and it fixed it for good (not to mention 1000 other things fixed)... The link to the forum is bellow
    E-fun Nextbook 8 Premium (Next8P) Modification - SlateDroid.com
  8. #7
    113339
    May 2012
    Florida
    Nextbook 7
    Can't find firmware update
    Quote Originally Posted by finplan View Post
    I don't find any firmware updates on the nextbookusa site. :-(
Ads:
  1. Catatonic Nextbook Premium 8
    By Motley in forum Android Tablet Q&A
    Last Post: 01-14-2013, 04:39 PM
  2. Help with Nextbook Premium 7
    By Yashikibuta in forum Android Tablet Q&A
    Last Post: 12-12-2011, 09:41 AM
  3. Nextbook Premium 8
    By frzamir in forum Android Tablet Q&A
    Last Post: 12-07-2011, 02:21 PM
  4. Nextbook 7 premium help
    By scotty921 in forum Android Tablet Q&A
    Last Post: 12-02-2011, 07:30 PM
  5. Nextbook Premium 8 Newbie
    By EdeBee in forum Android Tablet Q&A
    Last Post: 11-09-2011, 03:37 AM
how can i speed up my nextbook
how to speed up my nextbook
my nextbook is running too slow
next book slow
nextbook 7 is slow
nextbook 7 yfg firmware
nextbook premium 7 serial number
nextbook premium 7, connection and speed
nextbook tablet running slow
nextbook wifi problems
nextbook yfg
speed up nextbook downloads
