Achievements:
Recharging battery
Can any one help me. Got a new android tablet and charged it up. Now it has gone flat and although I have put it on charge it says the battery is 0% charged after 2 days on the charger. Can only use it plugged in to the power which isn't much use to me. Appreciate any feedback.
01-26-2012 08:16 PM
# ADS
Sounds like the battery isn't charging at all. Take it back.
Sent from my DROID using Tapatalk
Achievements:
Wish I could. It was given to me for a Christmas present and they bought it on one of the web sites. Can I get the battery out do you know? Then I could probably go and get a new one. Not sure whether I trust website purchases.
Type of tablet
You really need to post all the details that you can about your Tablet e.g. make and Model, what it says in "about" in settings, can you see any screws around the edges?
Achievements:
Yes here are screws but I was scared to undo them in case everything popped out!
@Agatha, DON'T unscrew anything until someone advises you, plus, what is the make and model of the tablet?
Reason: missing comma
Achievements:
The box has MID on it and I believe it is an Eximus.
Tyey are all called MID! does it look like this? : Eximus 7 Inch Android Tablet | Geeky Gadgets
Plus start it up then open the "Settings" and scroll down to "About" copy what you see in about and post it here on your thread.
Achievements:
Thanks to everyone that has given advice. must have had a loose connection or something because it suddenly started charging when I moved it to another power outlet in another room.
Good to know that you are now up and running. It does help others when you provide details of the outcome. Thanks.
