Page 1 of 2 1 2 LastLast
Results 1 to 10 of 16
Thanks Tree1Thanks
Thread: Please help me fix my mid android 2.3.3 tablet!
  1. #1
    Junior Member Achievements:
    Tagger Second Class
    96184
    Feb 2012
    Philippines
    Unhappy Please help me fix my mid android 2.3.3 tablet!
    I just received & started using my MID tablet last Jan. 07, 2012. Installed some useful market and non-market apps, customized its theme, wallpapers, widgets, etc. and loaded its SD card with photos, videos, music and some PDF files.
    After a month, I modified its AVG antivirus settings, restarted my device to see if the settings I've changed work but when it started up, its Available user space suddenly became 0.00B in the Storage settings.
    It also automatically unmounted its micro SD card and when I inserted the card back to the device "memory device safe to remove" appeared. I tried to mount it back many times but the same notification kept on appearing.
    I connected it (through USB) to a Windows XP & 7 PC to find out what's wrong but both computers didn't detect my device. I can turn on the Wi-Fi but it won't scan any source and after a few seconds it just automatically turns off.
    It doesn't have Restore on its Privacy settings so I tried the Format local and Factory data reset but it just turned my tablet back to its original settings and didn't solve any of the problems.
    My tablet won't accept any external devices, any Windows PC can't detect it and its wireless doesn't work. Does the real problem lie on the software or on the hardware of my device? Your response will be highly appreciated.
    About device
    Model number: M009F
    Android version: 2.3.3
    Kernel version: 2.6.35.7
    Build number: GRI40
    Ads
    Advertising world
  3. #2
    96324
    Feb 2012
    apple valley ca
    Thanked
    1 times
    android mid
    hello i joined because i have a problem with my tablet its a android mid 2.3 i go to WiFi settings and click turn on WiFi wait a few sec then click manage WiFi access points [i have internet] but says cannot find internet and then turns off plz help
    coneytown thanked this.
  4. #3
    Points: 2,676, Level: 31
    Level completed: 51%, Points required for next Level: 74
    Overall activity: 0%
    Achievements:
    1 year registered 1,000 Experience Points 3 months registered 500 Experience Points 250 Experience Points
    67581
    Dec 2011
    philippines
    155
    Thanked
    7 times
    Points
    2,676
    Level
    31
    COBY KYROS MID1024-4G
    try to do this, turn off your tablet then insert your memory card then power it on. then if you want you can format your memory card first before inserting it to your tablet. just use a card reader and then connect it to pc and format it. about your device not detected by pc try to install pda.net or sdk.
    Coby Kyros M1024-4G
    Gingerbread LF V1.5
    PSP 3000 PRO-B10
    Sony Ericsson Satio (rooted)
    Nintendo Wii (soft-modded)
    Xperia S (Advanced Stock ICS Kernel)
  5. #4
    99101
    Mar 2012
    baguio
    mid tablet ginger bread 2.3.3
    try to upgrade or downgrade your pad
    they say in the other websita that upgrading or downgrading your device also wipe the user space...
    try it
  6. #5
    99354
    Mar 2012
    austin
    mid
    If you have a wireless router, you have to give it access by adding the mac address of the MID. It may be blocked.
  7. #6
    99109
    Mar 2012
    baguio
    i join because i have the same problem
    if anyone have an idea how to fix this problem... plss help us
  8. #7
    99109
    Mar 2012
    baguio
    download the m9oof.....read the instructions...try it...i dint try it yet
    because im very bussy....
    http://www.eken.com/support/
  9. #8
    105884
    Apr 2012
    Italy
    M009F
    I cannot flash the new software on EKEN website EKEN Tablet PC,Car DVR Support Download Center since the USB connection is not recognize.
    Same sw is installed in the tablet (see below). I used the tool IUW as described in the website, but I have no connection via USB cable at all.Please, help !
    About device
    Model number: M009F
    Build number: GRI40
  10. #9
    99109
    Mar 2012
    baguio
    Quote Originally Posted by ebenedetti View Post
    About device
    Model number: M009F
    Build number: GRI40
    install 1st the otg driver(a file were you unzip the infotmic) then press the menu botton then power on...then tha box will turn to green
  11. #10
    105884
    Apr 2012
    Italy
    M009F
    Quote Originally Posted by tyutyu View Post
    I need to know if the sw in the EKEN directory is newer than this
    or not:
    mine is 2.3.3, there is 2.3 only....let me know........
    About device
    Model number: M009F
    Build number: GRI40
Ads:
  1. Replies: 1
    Last Post: 01-15-2012, 10:06 AM
  2. HOW TO: Control your Android Tablet (or Android Phone) from your PC or other Android
    By pbrauer in forum Android Tablet Usage, Tips & Tricks
    Last Post: 10-18-2011, 04:45 AM
  3. Viewsonic Android Tablet (G-Tablet) Android Market Demo
    By dandroid in forum Viewsonic gTablet
    Last Post: 12-28-2010, 09:16 AM
android 2.3.3 wifi problem
android tablet 2.3.3 factory data reset does not work
china tablet 2.3.3 hard reset
format mid android
how do i fix my tablet rooted problem
how do you fix a tablet model m729s if it doesnt turn on
how to format mid tablet
how to reformat a china tablet 2.3 but its already off
how to repair android 2.3
modem setting in infotmic andriod 2.3.3 tablets
my android os 2.3 tablet doesnt say privacy on main menu to reset my tablet
software android 0.2.3.3 model m009f
Tags for this Thread
