Results 1 to 3 of 3
  1. #1
    Junior Member Achievements:
    100 Experience Points 31 days registered 7 days registered 250 Experience Points
    147309
    Oct 2012
    Santa Ana, CA
    Star N9770 Android ICS 4.0.9 Note II
    WIFI Authentication Problem
    I was downloading just fine for about an hour then click authentication problem. I'm sitting right next to my router and full signal and show password it just will not connect. I feel the guy next door may be using a device that is stopping WIFI Connections. Any Ideas? Star N9770 Rooted Android 4.0.9 Apps = WIFI Analyzer, Y5 Battery Saver
    Any known issues would be appreciated. It was working fine. Netgear router WA
    Ads
    Advertising world
  3. #2
    Super Moderator
    Points: 18,950, Level: 87
    Level completed: 20%, Points required for next Level: 400
    Overall activity: 89.0%
    Achievements:
    Recommendation First Class 10,000 Experience Points Recommendation Second Class 1 year registered 5,000 Experience Points
    Awards:
    Frequent Poster
    77592
    Dec 2011
    Norcross, GA
    4,467
    Thanked
    843 times
    Points
    18,950
    Level
    87
    Transformer Prime & TF700
    Welcome to the forum
    You might want to turn your router off for 30 seconds or so. After it comes back up completely restart your tablet and try again. I have some additional tips in a link, below.
    Locked out of your Tablet? - Printing from an Android tablet (or phone) - Connecting to the Internet with no WiFi - Move/copy/cut/paste files to and from your tablet - WiFi connection issues - Getting Flash Player
    TF201 & TF700 (stock) with dock, .
  4. #3
    Points: 99,318, Level: 100
    Overall activity: 100.0%
    Achievements:
    Veteran 50,000 Experience Points 25,000 Experience Points Recommendation First Class Recommendation Second Class
    23311
    Mar 2011
    Chicago, IL
    13,116
    Thanked
    1553 times
    Points
    99,318
    Level
    100
    NOOK Tablet Stock NOOKcolor Rooted & ManualNooted Google Nexus 7 (2013) 32GB
    Hi bmaz, congratulations on your new Star tablet and welcome to the forum. Nice of you to become a member of Android Tablets. As Lee suggested, resetting your router is a good place to start. Some things that have worked for others include changing the channel to a channel number less than 11 and changing your security to WEP. In case those things don't work, I'm going to move your thread over to the Android Tablet Q&A section where others are more likely to join the discussion and try to help. Good luck!
    If it's important to you, you'll find a
    way. If not, you'll find an excuse.
    If you're too busy for friends,
    You're too busy.
    Attention lurkers! Join the forum,
    and enter Spider into the referrer
    field of the application.The $0.00
    USD fee will be waived.
    People will forget what you said.
    People will forget what you did.
    But, people will never forget
    how you made them feel.
Ads:
  1. Proxy Authentication
    By Hadrian1x in forum Android Tablet Q&A
    Last Post: 01-07-2012, 06:02 PM
  2. Password Authentication
    By Hadrian1x in forum Toshiba Thrive
    Last Post: 08-11-2011, 01:16 AM
  3. Proxy Authentication
    By Hadrian1x in forum Toshiba Tablets
    Last Post: 08-10-2011, 08:23 PM
  4. Tablet with built-in Authentication
    By ChristianSA in forum Android Tablet Discussions
    Last Post: 04-12-2011, 03:33 AM
  5. Replies: 0
    Last Post: 02-06-2011, 01:00 PM
android authentication problem
android tablet authentication problem
android wifi authentication problem
authentication problem android
authentication problem wifi android
authentication problem wifi android tablet
authentication problem with tablet
tablet wifi authentication problem
wifi authentication problem android
wifi authentication problem android tablet
