Results 1 to 2 of 2
Thread: need help asap
  1. #1
    Junior Member Achievements:
    7 days registered Tagger Second Class
    153632
    Nov 2012
    derry
    neuropad
    need help asap
    My brother bought an android neuropad for my father for christmas, and in his infinite wisdom he decided to play with it beforehand.
    he decided that he didnt like the apps that came preinstalled on it and for reasons know only to himself he, instead of just deleting the apps, did a complete factory reset
    The tablet, once it rebooted, was all in chinese and after I got the guys at the local chinese restaurant to decipher and change the language back to english, I have found that the tablet is now unable to download apps from the google play/android store.
    does anyone know how to fix this.
    any help would be appreciated.
    Ads
    Advertising world
  3. #2
    7 days registered
    154515
    Nov 2012
    London
    Neuropad
    seems to me that the solution to your problem would be to re-install the firmware, here are some links to the tools to flash and full flashing instructions to re-instate your Neuropad tablet the way it was when you first got it. I've done it myself when my Neuropad suddenly stopped booting and it works perfectly fine.
    OK first you need to get all the required software installed on your pc/laptop.
    To download the latest version of firmware (as of 18/03/12) go to the following link
    http://www.androidtabletpcs.co.uk/neuropad.img
    Once you have that you will need the tool to flash your tablet
    The flashing tool is called Livesuite -- you can download it here.
    www.androidtabletpcs.co.uk/livesuite.zip
    Download it and then unzip it to a location you know where it is
    When you plug in the tablet and asks you for drivers you need to browse your PC for drivers and select the USB drivers folder in the livesuite folder you have just unzipped.
    If it does not ask for drivers go to start on your PC, right click on the computer option and select manage. Then from the pop up box select 'device manager'. In there you will see a device called 'android' with a yellow exclamation mark. double click this, select update driver from the pop up box and then browse to the livesuite folder you have unzipped and then into the USB drivers folder contained within
    there are PDF instructions in the livesuite zip to help you install livesuite
    Install the 4.0.3 firmware using the Livesuite tool . Instructions are here in a video, it's all in chinese but fast forward to the point when you connect the tablet to the pc/laptop and see what button you need to press.
    http://static.youku.com/v1.0.0221/v/...dy5odG0%3D&wd=
    You are now ready to flash
    To get the tablet into the mode to accept being flashed it mus be powered off
    Hold down the Volume + button, plug in the USB cable, tap the power button 10 times quickly, then let go of the volume+ button, select the format install option from the pop up box and wait for it to finish.
Ads:
  1. Help! What tablet should I get? Need help ASAP!
    By Angell3abie69 in forum Android Tablet Q&A
    Last Post: 05-23-2012, 05:10 AM
  2. Heeeelp please ASAP!!!
    By Skyybluelife in forum Pandigital Novel Black Firmware
    Last Post: 12-22-2011, 10:05 PM
  3. Hurry asap
    By elitecmdr666 in forum Samsung Galaxy Note/Tab
    Last Post: 04-27-2011, 01:18 PM
  4. HELP ASAP- should I buy this tablet?? Need to know soon
    By donutdude246 in forum Android Tablet Discussions
    Last Post: 11-23-2010, 01:41 PM
  5. HSG-X5A --- Rom 270 VS 297 (opinions ASAP please)
    By cancelx in forum Telechips TCC8902 Tablets
    Last Post: 08-16-2010, 12:14 PM
how do i change the language on my neuropad ireader
how to factory reset neropad
how to reset a neuropad2
how to reset neuropad
neuropad factory reset
neuropad how do i fix it
neuropad manual
neuropad reset
neuropad2 firmware
neuropad2 firmware download
neuropad2 reset
reset neuropad2
Tags for this Thread
