How to side load apps if market wont work
This is really simple and i am sure most people know how to do this but here it is step by step
first search for the app you want which will be an apk file download it to a computer or straight to your tablet, if you download it to a computer transfer it to your tablets sd card. then follow these steps
- First go into settings-applications and check unknown sources
- Use a file explorer app to find the apk file(most tablets have them pre installed).
- Open it, find the apk file and click install.
hope that helps some if you have any questions just ask
Here is a video on how to install a file browser if your tablet doesn't have one, also shows a little of how to use it to side load apps
sorry about the video quality I couldn't find my good camera hope it still helps
Reason: added a video
08-02-2010 07:45 PM
# ADS
i dont have a file xplorer?
if you dont have a file explorer you will need to download one. so open up your tablets browser search for apkmanager or fileexplorer the extensions will be apk you can also try this one Download Apps Installer for Android and see if that works and then once your notification bar says download complete just click on it and click install and you will be able to use that app to side load other apps
Oh you're calling installing/loading the apps side loading when your don't use Market store. Most of these China made tablets have Wonder App Store instead.
Devices: MID7015-4G | MOD: HoneyComb Hybrid HCV31.0 GB38 with Extreme Power Booster | ROM OS: Rooted Android OS 2.3.1a GingerBread
Devices: MID7015A-4G | MOD: HoneyComb Hyrbird HCV15.0-B22V with Extreme Power Booster | ROM OS: Rooted Android OS 2.1a Eclair
Devices: M150A12 | MOD: HoneyComb Hybrid HCV15.0-B22V with Extreme Power Booster | ROM OS: Rooted Android OS 1.6a Donut
18x Tablets Owned/Tested/Configured/Tweaked: Running OS: 1.6, 2.0, 2.1, 2.2, 2.3 | Since 2010
Go to the other market...
many apps are readily available from torrenting.
it would be helpful of a thread with various NON Android Market apps for downloading though.
applanet
slideme
androlicious
Originally Posted by
goldshirt9
applanet
slideme
androlicious
Good idea but there are just so many apps out there that it would be hard to throw them all in one thread
we could make a collecting thread though and someone copies all together in a sticky thread
probbiethe1
goldshirt9
applanet
slideme
androlicious
a list of sites would be the best option.
and a quick review if worth visiting or not , and what the site is best for.
goldshirt9
probbiethe1
goldshirt9
applanet
slideme
androlicious
I recommend FileCrop - Search and Download Rapidshare Megaupload and Hotfile Files has a huge collection of apk's
