Register Hello & Welcome to Andriodtablets.net, is this your first visit?
[ROM] XAUMOD Custom Firmware for APAD IMX515 (Single Speaker, Utopia)
This is a discussion on [ROM] XAUMOD Custom Firmware for APAD IMX515 (Single Speaker, Utopia) within the APAD IMX515 forums, part of the Utopia Tablets category; THIS CUSTOM FIRMWARE IS ONLY INTENDED FOR THE SINGLE SPEAKER UTOPIA (乌托邦/安酷) 8" IMX515 ANDROID TABLET. THIS WAS BUILT FOR THE CAMERALESS VERSION ONLY FROM ...
Page 1 of 7 1 2 3 ... LastLast
Results 1 to 10 of 69
Thanks Tree1Thanks
Thread: [ROM] XAUMOD Custom Firmware for APAD IMX515 (Single Speaker, Utopia)
  1. #1
    Points: 108,100, Level: 100
    Overall activity: 10.0%
    Achievements:
    Recommendation Second Class 25000 Experience Points 10000 Experience Points 5000 Experience Points 1000 Experience Points
    795
    Jul 2010
    Hong Kong, China (formerly Canada)
    3,474
    Thanked
    363 times
    Points
    108,100
    Level
    100
    Huwaei Ideos S7-104 (Rogers 3G), HSG X5A, RK2818 RT7 (Past APAD IMX515, APAD RK2808)
    THIS WAS BUILT FOR THE CAMERALESS VERSION ONLY FROM THE FIRST BATCHES.
    IF IN DOUBT, USE THIS THREAD TO IDENTIFY YOUR TABLET
    No warranty or support pledged with this firmware. Apply at your own risk. Use common sense.
    'xaumod' .12, last updated Jan 26
    To reduce battery drain, download Airplane mode wifi tool from market (http://www.appbrain.com/app/airplane...d.airplanemode) to enable airplane mode and wifi together.
    This is a work in progress
    Clean Install:
    These files are to be extracted to the root directory of the internal memory (FAT) of the device (/mnt/disk) directory.
    To update, from power off, start the device with menu and home keys held down. Then switch the device on. Choose 'update all', then wipe data/factory reset, and reboot.
    After the first bootup is complete, power cycle the tablet via normal shutdown, and you are good to go.
    XAUMOD 0.12 Download http://www.multiupload.com/VIT78USCST
    MD5: 1C9BA387AB868B3D54FE5F4FBB019FC9
    This is just a repacked 0106 ROM from hiapad. So it comes with Google apps as in the original update. Wasn't keeping track of all my changes, but this just contains superficial changes for the most part.
    Not throughly tested! Quick system repack. No sources to speak of.
    Process takes me about 10 minutes to update...
    Post-Install Notes:
    Notification sounds are copied in /system/media. Copy this folder to /sdcard/ and restart the device to enable sounds.
    To see Contacts, use AnyCut to create a shortcut to the Phone intent.
    Install Youtube from market
    Will add full credits alter.
    Recommended Installs after Market Access is gained:
    Adobe Flash
    Google VoiceSearch
    Wifi on-off widget by Curvefish
    ADW Launcher & Perfect Task Switcher
    Added components:
    Superuser (rooted)
    PassionQuickOffice Viewer
    Email.apk
    AnyCut by Jeff Hamilton
    Google ChomeToPhone
    More Locale by C-LIS Crazy Lab.
    Gingerbread Keyboard (default, Peter Alfonso/malez/AOSP)
    Google ContactsSyncProvider
    Google CalendarSyncProvider
    News and Weather (AOSP)
    Modified Calendar.apk to show up on Launcher (test keys)
    MusicMod Froyo by Eliot Stocker
    CNDDU cifs.ko in /system/modules/
    CNDDU patched wpa_supplicant with adhoc support reference XDA
    ES File Explorer
    Google Search Bar
    Terminal Emulator (pulled from CM ROM)
    Removed:
    Speedforge 3D
    Provider.apk
    TianTian Browser
    Repligo Warez
    ES Task Manager
    System Info
    ES File Explorer Old
    Old Google Search Bar
    Screenshots:
    Credits to Shenzhen Richtechie for original 0106 firmware
    Huawei Ideos S7-104 on Singapore ROM, HSG X5A, RK2818 RT7, (Past: IMX515 APAD, RK2808 APAD)
    My written articles are licensed under a Creative Commons Attribution-NonCommercial 3.0 Unported License
    本人現在已比較小時間瀏覽此論壇。有關和此論壇的合作關係,請聯絡admin或4Nines。
    Advertising world
  3. #2
    Achievements:
    795
    Jul 2010
    3,474
    Thanked
    363 times
    Points
    108,100
    Level
    100
    That was a quick version bump. .1->.11->.12
    Found a black statusbar mod and applied it from frankie_2012 (PadBBS) with a minor modification.
    Removed Youtube APK, ADB wireless.
    Fixed Superuser to work on first boot
    Hopefully I don't find any more annoying things. Don't want to reflash for a while.
    Clean wipe and flash
  4. #3
    Junior Member Achievements:
    7 days registered 31 days registered 3 months registered 100 Experience Points 250 Experience Points
    7607
    Nov 2010
    Thanked
    1 times
    Your link is messed up but if you remove <br /> from the end of address it works
    Thank you for the work on this rom
  5. #4
    Achievements:
    795
    Jul 2010
    3,474
    Thanked
    363 times
    Points
    108,100
    Level
    100
    This is what the blackbar looks like:
  6. #5
    15410
    Jan 2011
    Northamptonshire
    17
    Apad a8
    WOW just tried this on my black apad a8 2 speaker model and it working amazing love the speed and look
  7. #6
    Achievements:
    795
    Jul 2010
    3,474
    Thanked
    363 times
    Points
    108,100
    Level
    100
    ... This isn't supposed to work properly on a 2 speaker model. I haven't looked into how to fix the g-sensor yet..
    Main problem is that I don't have one. It might be possible to swap a couple of libs and see if that works.
    For properly functioning dual-speaker model:
    Try copying this file http://www.megaupload.com/?d=ZPR9MO3B uploaded by sohosurfer here, and place into /system/lib/hw using adb or Root Explorer, and reboot.
    I might reupload a dual speaker version. I just need someone to test.
  8. #7
    15410
    Jan 2011
    Northamptonshire
    17
    Apad a8
    working super here mate the g-sensor a little bit wobbly but work fine if i cant deal with it i will just swap my old setting it only three files but as you can see in the pictures it a true 2 speaker model running your fw
    Soo pleased it works i just wish i can get a 3g dongle to work or my iphone mywi
    as if i go somewhere without wifi im stuck lol
    Hopefully we can fix the 3g problem well done on your work sofar im happy to help out in anyway
  9. #8
    Achievements:
    795
    Jul 2010
    3,474
    Thanked
    363 times
    Points
    108,100
    Level
    100
    If 3G works on ordinary 0106Utopia(laotao) firmware on dual speaker, it should work on this as well. I only modified /system files on 0106 and cleaned it up.
  10. #9
    15410
    Jan 2011
    Northamptonshire
    17
    Apad a8
    Not your fault mate never had 3g working tried all sorts still cant get my 3g uk dongle or my tethered iphone mywi to connect to it
    You have done a great job looking for too seeing more tweaks/mods soon
  11. #10
    Achievements:
    795
    Jul 2010
    3,474
    Thanked
    363 times
    Points
    108,100
    Level
    100
    Edit:
    The IMX515 should work with MyWi. Adhoc connections should work. It will be marked with a (*) in front.
    I basically already did the equivalent of this hack on the IMX515 already: http://reviewhorizon.com/2010/12/how...rks-like-mywi/
    USB 3G I'm not sure about
Sponsors:
  1. Help identifying Apad and locating custom Roms
    By ghow in forum Telechips TCC8902 Tablets
    Last Post: 07-14-2011, 12:52 PM
  2. Any custom firmware for eken m008
    By ch0s3n1 in forum WonderMedia WM8505 Tablets
    Last Post: 02-23-2011, 06:26 AM
  3. Replies: 18
    Last Post: 12-12-2010, 08:56 PM
  4. [ROM] HKX Custom Firmware for Batch 2 Rockchip 7" Apad iRobot - 0801
    By xaueious in forum Rockchip RK2808 Tablets
    Last Post: 08-02-2010, 04:34 PM
APAD IMX515 firmware update
APAD iMX515
IMX515
a8 imx515 rom
apad firmware update
apad imx515 rom
apad irobot two speaker
gingerbread m802 rom
imx515 custom rom
imx515 rom
imx515 utopia
xaumod
Tags for this Thread
Copyright © 2012 vBulletin Solutions, Inc. All rights reserved.
