Page 1 of 4 1 2 3 ... LastLast
Results 1 to 10 of 35
Thanks Tree3Thanks
Thread: TF101 will not charge
  1. #1
    Junior Member Achievements:
    3939
    Sep 2010
    Unhappy TF101 will not charge
    I have had this tablet for less than a week. It has updated to 3.1 but now it will not charge (tablet or dock). I have tried with the original charging brick and with one that came with my Droid X. I also tried a USB connection to my PC. No good.
    Any word from Asus? I checked their forums and found nothing.
    TIA, Diggs
    Edit: I have confirmed the original brick is good by using a different USB to micro-USB and charging my Droid X with it.
    Edit2: Every site from a google search (http://www.google.com/search?q=90-OK...ient=firefox-a) for the AC adapter says it is 5v, not 15v.
    When I connected the tablet to my PC, it connects for data transfer, so I know that at least part of the cable is good.
    This is not a good thing.
    Diggs
    Ads
  3. #2
    31 days registered 7 days registered
    41832
    Jul 2011
    San Diego, CA
    Thanked
    1 times
    Asus Transformer tablet, 32 GB
    Unfortunately, Asus does not use the standard 5 volts on it's usb charger. It uses 15 volts, so plugging it into a computer, usb hub, or most any other usb charger, which all use 5 volts, will not work.
    In response to this, I have purchased a spare Asus charger for the Asus Transformer tablet.
    There are several places to buy one online.
    I found one at:
    ASUS Transformer TF101 AC Adapter (Includes USB Power Adapter & USB Connector Cable). ASUS 90-OK06AD00020Y
    My current Android tablets:
    Asus Transformer, TF101-B1, 32 GB internal
    with Docking Station
    rooted, Prime v1.6 ROM (Android Honeycomb, 3.1)
    Netformer 15 kernel, OC'd @1.6 GHz
    Anomander thanked this.
  4. #3
    39198
    Jul 2011
    Gatwick
    Asus Eee Pad Transformer
    Hi,
    my TF recieved an over the air update about a week ago and afterwards it stopped taking a charge. With the TF in standby, plugging in the charger would make the TF light up, so it was recognising that the charger had been plugged in but the notification icon at the bottom right of the screen would remain as if nothing had been plugged in.
    I read elsewhere that this problem had affected a few other units after the OTA update but had been resolved by pressing and holding both the power botton and the down volume button for about 10 seconds. Then you are asked if you want to delete all data, press the down volume button again to say no, it then rebooted and the charging problem disappeared.
    No idea if this is the same problem that you are getting but maybe its worth a try.
  5. #4
    3939
    Sep 2010
    Well, I did the Power/Down Volume thing. It made no difference when I said "No" to a wipe so I did it again and said "Yes" to a wipe. Again, no change. It still says to plug in the charger.
    Diggs
  6. #5
    1,000 Experience Points 500 Experience Points 250 Experience Points 1 year registered 100 Experience Points
    1516
    Aug 2010
    North Carloina
    13
    Thanked
    1 times
    Asus Transformer (16GB)
    My wife had the same issue with hers. All she did was to blow canned air into both the male and female side of the connection (where it plugs into the TF 101) and it worked.
  7. #6
    Points: 5,004, Level: 45
    Level completed: 27%, Points required for next Level: 146
    Overall activity: 0%
    Achievements:
    5,000 Experience Points Veteran 1 year registered 1,000 Experience Points 500 Experience Points
    8513
    Dec 2010
    north jersey
    235
    Thanked
    15 times
    Points
    5,004
    Level
    45
    Huawei s7-Wpdn-nook-libre pro
    I know this is gonna sound off the wall- But put the power brick in a zip lock bag and put in the freezer for an hour or so. It resets something inside. I never needed to do it but read 3 times that it worked. Good luck.
    Kgs
    Note-Gnex-lumia 521-iphone 5s-Nexus 7 original- Asus Vivobook
    nook-libre pro-asus 1000h-iphone3gs- incite -Huawei s7 (C62B11 + link2sd)- Asus TF (Prime 1.8.4 rooted)
    "Never be afraid to try, but always know where your back-up is when you screw up!"
  8. #7
    36018
    Jun 2011
    Oregon
    49
    Thanked
    1 times
    Asus Transformer 32GB
    How depleted is the battery? If the charger and the cable are working it sounds like you may have to contact ASUS which would suck. Sorry to hear you are having troubles. Have you upgraded to 3.2 yet? The problem may be though even if you have an update that the battery may be below 50% and it will not allow the update. Any chance you are using a USB extension cable to help charge with? I know USB 2.0 Extension cable can not be used with the charger and the cable and that if you need to use a USB extension then it needs to be 3.0. I think if you are having troubles with this and have only had it for a week I would take it back and ask for a different one, you shouldn't have issues like that after a weeks use and if you do get it fixed, do you want to put up with potential problems?
  9. #8
    88317
    Jan 2012
    England
    Asus Eee Pad Transformer TF101
    Update
    Hi. I've joined this forum as I've had a similar problem and thought I'd search for existing topics first.
    I was just wondering what happened with regards to your Transformer not charging?
    I've had mine 3 months and it seems to be doing the same. I also tested the dock / connection to computer and it recognises these things fine, just won't charge. I actually sent it back to Asus (complete with a letter descriping the problem as there wasn't the option to add this info on applying for a RMA). The Transformer has been returned with a note saying "no problems" (and enclosed documents not even opened). Therefore I think my next option would be to buy a charger (which seem either hard to get hold of / quite expensive for "testing purposes"). Just thought it would be interesting to see how your story ended...
    Thank you
  10. #9
    1 year registered 500 Experience Points 250 Experience Points 100 Experience Points 3 months registered
    39408
    Jul 2011
    Villas, NJ
    7
    Thanked
    1 times
    I had a similar problem in the fall. All I had to do was push the adapter into the slot with a counter-intuitively large amount of pressure until I noticed an indication it was charging. I had to do the same thing each time for about a week and then it just started working like normal again after that.
  11. #10
    Points: 10,186, Level: 67
    Level completed: 34%, Points required for next Level: 264
    Achievements:
    10,000 Experience Points 5,000 Experience Points 1 year registered 1,000 Experience Points 500 Experience Points
    18376
    Feb 2011
    Washington State
    1,653
    Thanked
    193 times
    Points
    10,186
    Level
    67
    Hauwei S7
    Quote Originally Posted by Sean081978 View Post
    One thing to check for, and it is not always obvious, is some foriegn matter can get in the cable or slot. I would check very carefully before you put too much pressure as it could cause permanent damage.
    Sent from a Gibson using Tapatalk - heavy metal edition
    Huawei S7 104 (BB)
    Froyo 2.2.2 S7V100R001C98B021
    SOC Rooted - link2sd
    Samsung Galaxy Note 10.1
    SS SsS oo
Ads:
  1. Transformer tf101/email/Talktalk
    By lesliejack in forum Honeycomb
    Last Post: 02-25-2012, 12:13 PM
  2. Apps not compatible with tf101?
    By Grumsh in forum Android Tablet Q&A
    Last Post: 09-08-2011, 06:36 PM
  3. [How]ASUS Eee Pad TF101-- play movie from PC via MyNet ?
    By Rutherford in forum Asus TF101/SL101 Forum
    Last Post: 06-21-2011, 02:56 AM
  4. ASUS Eee Pad Transformer TF101 UK and US Availability Soon
    By xaueious in forum Android Tablet News
    Last Post: 04-25-2011, 10:26 AM
  5. ASUS Eee Pad Transformer TF101 Launch Day
    Last Post: 04-22-2011, 10:59 PM
asus tablet not charging
asus tablet will not charge
asus tf101 not charging
asus tf101 will not charge
asus tf101 won't charge
asus tf101 wont charge
asus transformer not charging
asus transformer tablet not charging
asus transformer tf101 not charging
asus transformer wont charge
my asus tablet will not charge
