Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
  1. #1
    47018
    Aug 2011
    Latvia
    Asus tf101
    Asus tf101: Wifi connection problem
    I have a problem to connect my Asus tf101 to my wifi network. My tablet does not see the network, while other devices do, the network signal strength is max. It is WPA secured. The tablet see some networks around with a much lower signal.
    Also noticed that wifi is working very slow even with networks to which it is possible to connect.
    Could anybody advice possible way to solve the problem?
    Thanks!
    Sent from my HTC Desire using Android Tablet Forum
    Ads
    Advertising world
  3. #2
    Senior Member Achievements:
    500 Experience Points 1,000 Experience Points 250 Experience Points 100 Experience Points 3 months registered
    12776
    Jan 2011
    Mississauga Canada
    147
    Thanked
    1 times
    Is your network Wi-Fi "visible" that is, broadcasting the SSID identity?
  4. #3
    Points: 99,133, Level: 100
    Overall activity: 100.0%
    Achievements:
    Veteran 50,000 Experience Points 25,000 Experience Points Recommendation First Class Recommendation Second Class
    23311
    Mar 2011
    Chicago, IL
    13,101
    Thanked
    1553 times
    Points
    99,133
    Level
    100
    NOOK Tablet Stock NOOKcolor Rooted & ManualNooted Google Nexus 7 (2013) 32GB
    Some people have had success by changing from WPA to WEP. I have no idea why, but they say it works.
    If it's important to you, you'll find a
    way. If not, you'll find an excuse.
    If you're too busy for friends,
    You're too busy.
    Attention lurkers! Join the forum,
    and enter Spider into the referrer
    field of the application.The $0.00
    USD fee will be waived.
    People will forget what you said.
    People will forget what you did.
    But, people will never forget
    how you made them feel.
  5. #4
    47018
    Aug 2011
    Latvia
    Asus tf101
    Thank you very much for your coments.
    Yes, network is visible. As also it was WEP encripted initialy, Ive changed it to WPA while looking for the reason, it didnt help. And my tablet see othet WPA encripted network.
    No success so far.
    Also a new thing Ive noticed, if I reset my rooter, the network becomes visible for my tablet for few seconds and after that disapears...
  6. #5
    47018
    Aug 2011
    Latvia
    Asus tf101
    Works now. Thanks everybody. Dont understand the reason, but my tablet just connected the network...
    Probably there were some disturbances, but strange that other devices were working without problems...
    Anyway, great that everything working and hope problem will not come back again.
  7. #6
    Achievements:
    23311
    Mar 2011
    Chicago, IL
    13,101
    Thanked
    1553 times
    Points
    99,133
    Level
    100
    That's great, glad to hear it's working now.
    You're too busy.
  8. #7
    47276
    Aug 2011
    Hi,
    I had the same problem - all devices saw the internet connections and router, but my Asus didn`t. I try a lot of solution and I find the reason. Problem was in basic router settings. Asus didn`t seen router because channel on router was set on 13, when I change it to 6 everything was fine. Maybe somebody will have the same problem and I hope this post will be helpfull.
  9. #8
    47018
    Aug 2011
    Latvia
    Asus tf101
    For me the problem was the same, it just came back and I go deeper in router settings changes. Chanel selection was set to auto and I set it to 9. That helped. Later in internet I found a post about wifi chanels for tf101, it was saying that chanel has to be 11 or lower. Cannot explain why, but looks like it is true.
    Hope this info will be helpful.
  10. #9
    Junior Member Achievements:
    45123
    Aug 2011
    Omaha, NE
    15
    Thanked
    1 times
    Asus Transformer TF101 16GB
    North American devices are only to access channels 1-11. FCC bans use of 12-14 in USA for most home use. See List of WLAN channels - Wikipedia, the free encyclopedia
    If your unit is a USA based device with US based drivers, the upper channels would not be available.
  11. #10
    87702
    Jan 2012
    Provo, UT
    Unhappy wifi connection not working!
    So my tablet says it's "connected" to my wireless router, and the signal is excellent. BUT when i try to go on the internet browser, it bring up a page that says "Webpage not available" and this is for any site i try to go to. Also when i try to use anything that requires an internet connection, it says "no connection". So is it connected or not?
    And the little icon below that shows your internet connection, its supposed to be Blue, but is gray.
    Also, my laptop connects to it perfectly, just not my tablet, i don't know what to do. Can anyone help???
Ads:
  1. TF101 Asus Problem installng apps
    By avlgeek in forum New Member Introduction & Site Assistance
    Last Post: 09-13-2011, 04:54 PM
  2. Asus TF101 & VNC & WiFi
    By NasaPJN in forum Asus TF101/SL101 Forum
    Last Post: 08-09-2011, 07:28 PM
  3. Wifi Connection problem
    By rohak in forum Gome Flytouch II Variant 2
    Last Post: 05-23-2011, 01:34 AM
  4. wifi connection problem! pleas help
    By hammada in forum Telechips TCC8902 Tablets
    Last Post: 01-15-2011, 07:37 AM
  5. Wifi connection problem
    By CCAREY in forum Android Tablet Q&A
    Last Post: 12-26-2010, 01:04 PM
asus 101 tablet problems/wont recognise wifi
asus tablet connection issues
asus tablet not connecting to internet
asus tablet wifi connection
asus tablet wifi issues
asus tablet wifi problem
asus tablet wifi problems
asus transformer tf101 no internet connection
how to connect wifi to asus tablet
my asus tablet connects to my wifi but no internet
my asus tablet won't connect to the wifi
tf101 has slow wifi
