Results 1 to 9 of 9
  1. #1
    Senior Member Achievements:
    Your first Group 500 Experience Points 250 Experience Points 100 Experience Points Tagger Second Class
    1547
    Aug 2010
    Michigan
    516
    Thanked
    13 times
    Waiting for a good iPod Touch Android Device
    How to confiqure proxy setting for WIFI.
    Hello when I was trying to connect my gentouch to the internet at school, you need to enter proxy settings. I could not find where to enter the proxy settings. Help!
    Carbira1
    Ads
    Advertising world
  3. #2
    1547
    Aug 2010
    Michigan
    516
    Thanked
    13 times
    Bump. Anyone? Please?
  4. #3
    5000 Experience Points 1000 Experience Points 500 Experience Points 250 Experience Points 1 year registered
    1474
    Aug 2010
    North Carolina
    354
    Thanked
    23 times
    Archos 101, Viewsonic G-Tablet, Motorola Droid X.... test drove: Augen gentouch 78, Coby Kyros 7015
    Hate to say but I don't believe android will do proxies natively.... but if u have a working android market... I think there's an app there that will allow them. Just do a search for proxy...
    Sorry to be vague... I only came across the app in passingg looking for a proxy style tehering app for my Droid...
  5. #4
    Developer
    Achievements:
    Recommendation Second Class Recommendation First Class 7 days registered 31 days registered 3 months registered
    1423
    Aug 2010
    USA
    1,504
    Thanked
    103 times
    COBY KYROS 7015 | 7015A
    Proxy Server by IP or buy name like myuniv.tc.net:5050 with a port to be open. You have something like that? Are you using a wireless router in your dorm room. I was looking deeper into WiFi Buddy that's in Powertools you can configure to use Static IP, Subnet Mask Gateway, DNS1, DNS2 You can also add VPN (Virtual Private Network). But you use a proxy server to get out.
    Try this WiFi Proxy Settings for Android which you need to download and install.
    Devices: MID7015-4G | MOD: HoneyComb Hybrid HCV31.0 GB38 with Extreme Power Booster | ROM OS: Rooted Android OS 2.3.1a GingerBread
    Devices: MID7015A-4G | MOD: HoneyComb Hyrbird HCV15.0-B22V with Extreme Power Booster | ROM OS: Rooted Android OS 2.1a Eclair
    Devices: M150A12 | MOD: HoneyComb Hybrid HCV15.0-B22V with Extreme Power Booster | ROM OS: Rooted Android OS 1.6a Donut
    18x Tablets Owned/Tested/Configured/Tweaked: Running OS: 1.6, 2.0, 2.1, 2.2, 2.3 | Since 2010
  6. #5
    1547
    Aug 2010
    Michigan
    516
    Thanked
    13 times
    Yes I need proxy settings to use the internet at school. On your site it says that the app is not for WIFI. Does this work on wifi now?
  7. #6
    Developer
    Achievements:
    1423
    Aug 2010
    USA
    1,504
    Thanked
    103 times
    I've installed it it does say WiFi Proxy Settings. I am not behind a Proxy Server so I can't test it you would need to test it and report back here your results. Thanks
  8. #7
    1547
    Aug 2010
    Michigan
    516
    Thanked
    13 times
    Unfortunately my gentouch's screen has a bad dead spot that calibration will not fix so I will be returning it tomorrow. When I get a new tablet I will test it!
  9. #8
    Points: 682, Level: 13
    Level completed: 64%, Points required for next Level: 18
    Overall activity: 1.0%
    Achievements:
    7 days registered 31 days registered 3 months registered 100 Experience Points 250 Experience Points
    100045
    Mar 2012
    Southern California
    8
    Points
    682
    Level
    13
    Nextbook 8P & impression i10-80
    Android Proxy settings
    Source of the following excerpt: Connect to Wi-Fi networks - Android OS Help Configure proxy settings for a Wi-Fi network
    Some network administrators require you to connect to internal or external network resources via a proxy server. By default, the Wi-Fi networks you add are not configured to connect via a proxy, but you can change that for each Wi-Fi network you've added.
    Proxy settings are used by Browser but may not be used by other apps.
    1. Touch & hold a network in the list of Wi-Fi networks you've added.
    2. Touch Modify network in the dialog that opens.
    3. Select Show advanced options.
    4. If the network has no proxy settings, touch None under Proxy Settings, then touch Manual in the menu that opens.
    5. Enter the proxy settings supplied by your network administrator.
    6. Touch Save.
    The proxy settings apply only to the Wi-Fi network you modified. To change the proxy settings for other Wi-Fi networks, modify them individually.
  10. #9
    Achievements:
    100045
    Mar 2012
    Southern California
    8
    Points
    682
    Level
    13
    6. Touch Save.
Ads:
  1. How to configure the proxy
    By abhinavgujjar in forum Android Tablet Hacking
    Last Post: 06-03-2011, 01:22 PM
  2. MIDX5 no WIFI !
    By grefix in forum Coby Tablets
    Last Post: 05-28-2011, 12:47 PM
  3. Wifi Problem
    By willcnow in forum New Member Introduction & Site Assistance
    Last Post: 12-20-2010, 04:59 PM
  4. Wifi problems..
    By robbie_vienna in forum Augen Gentouch
    Last Post: 08-18-2010, 12:41 PM
android proxy settings for wifi
android proxy wifi
android tablet proxy
android tablet proxy settings
android wifi proxy
android wifi proxy setting
android wifi proxy settings
proxy wifi
proxy wifi android
wifi proxy
wifi proxy android
wifi proxy settings
