Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
  1. #1
    Junior Member Achievements:
    500 Experience Points 250 Experience Points 1 year registered 100 Experience Points 3 months registered
    1316
    Jul 2010
    Initial WiFi setup problems...
    Having read every bit of advice and reviews, I picked up my Gentouch at Kmart today. Everything works as expected -- looks and works very similar to my Droid X, including the WiFi setup. Problem is, even though my Droid X has no problems connecting to my wireless network at home, my Gentouch will not. I put in the network name, triple checked the password, the Gentouch knows what encryption settings I have, but does not actually connect. WiFi is enabled of course; I've deleted and re-entered the network information several times. I can live with the other limitations of this device, but WiFi not working is a dealbreaker!
    Anyone have any similar problems? No response yet from Augen support, nothing else in the FAQs on their site.
    Ads
  3. #2
    Super Moderator
    Points: 70,854, Level: 100
    Overall activity: 3.0%
    Achievements:
    Veteran 50,000 Experience Points 25,000 Experience Points 10,000 Experience Points 5,000 Experience Points
    Awards:
    User with most referrers
    688
    Jun 2010
    Gilbert, Arizona
    1,840
    Thanked
    138 times
    Points
    70,854
    Level
    100
    Have you tried removing the password from your wireless router that has been known to work, or try resetting your router and tablet and see if that helps.
  4. #3
    1325
    Jul 2010
    Oklahoma, USA
    17
    When I enabled WiFi, it found my router and asked for a password. After entering the password, it registered with the router, got an IP address and I've been browsing the internet just fine. I was even able to use the file browser to access files on my Win7 PC. FTP connections also work, although it has a tendancy to hang when requesting directory contents.
    My main complaint is that I can't download anything from the Android Store. It says Starting Download and then just hangs.
    Back to your WiFi connection, you might also try seeing if you can connect using a public hot-spot.
  5. #4
    1316
    Jul 2010
    OK, I will give those a try... thanks.
  6. #5
    Super Moderator
    Achievements:
    Awards:
    688
    Jun 2010
    Gilbert, Arizona
    1,840
    Thanked
    138 times
    Points
    70,854
    Level
    100
    Quote Originally Posted by dadown View Post
    what kind of tablet do you have?
  7. #6
    1325
    Jul 2010
    Oklahoma, USA
    17
    Quote Originally Posted by probbiethe1 View Post
    A Kmart Gentouch.
  8. #7
    Points: 2,778, Level: 32
    Level completed: 19%, Points required for next Level: 122
    Overall activity: 0%
    Achievements:
    Veteran 1,000 Experience Points 500 Experience Points 250 Experience Points 1 year registered
    860
    Jul 2010
    Points
    2,778
    Level
    32
    Gentouch has problems accessing the Android Market. A patch was suppose to be released on 7/30/2010, but they only released the drivers for USB connectivity. Hopefully a patch will be out within the next few days to address that. As for the wi-fi connectivity problems, what is the level of security on your router (wep, wpa, etc.)??
  9. #8
    Super Moderator
    Achievements:
    Awards:
    688
    Jun 2010
    Gilbert, Arizona
    1,840
    Thanked
    138 times
    Points
    70,854
    Level
    100
    Scarybob did that work for you.
    dadown until the patch comes out you can side load apps by downloading them to a memory card and then using a file explorer to open them and install them
  10. #9
    1325
    Jul 2010
    Oklahoma, USA
    17
    slideme.org has a variety on Android apps that you can download.
  11. #10
    Administrator Achievements:
    100,000 Experience Points Veteran 50,000 Experience Points 25,000 Experience Points 10,000 Experience Points
    795
    Jul 2010
    Canada
    3,486
    Thanked
    433 times
    If your wifi has issues after changing routers or locations, it may be a hardware issue. The Telechips TCC8902 platform the Augen is equipped with is not all that robust. I wouldn't be surprised if there are quality control issues.
Ads:
  1. Problems accessing the Android Market
    By dandroid in forum Android Tablet Q&A
    Last Post: 02-28-2012, 06:56 AM
android tablet wifi setup
can you set up a wifi router with a tablet pc?
chrome tablet wifi setup
how to set up wifi on a asus tablet
how to turn on how to set up wifi on polaroid tablet
polaroid s7 andriod tablet wifi problems
polaroid tablet how to set it up
polaroid tablet wifi set up
polaroid tablet wifi setup
tablet pc wifi setting
tablet pc wifi settings
tablet pc wifi setup
Tags for this Thread
