Page 2 of 2 FirstFirst 1 2
Results 11 to 20 of 20
Thanks Tree6Thanks
Thread: wireless issue on AMID-972XS
  1. #11
    Junior Member Achievements:
    3 months registered 250 Experience Points 100 Experience Points 31 days registered 7 days registered
    143930
    Sep 2012
    Australia
    16
    Thanked
    1 times
    Bauhn 972XS
    Well I prefer the saved battery over a little lag time reconnecting, it's only about 5 seconds but still enough to notice. It's a bit annoying because my phone doesn't do it and I just checked it's set to turn off wifi during sleep too. Anyway it's a minor thing for me.
    Ads
    Advertising world
  3. #12
    Points: 1,946, Level: 26
    Level completed: 46%, Points required for next Level: 54
    Overall activity: 0%
    Achievements:
    1 year registered 1,000 Experience Points 500 Experience Points 3 months registered 250 Experience Points
    140915
    Sep 2012
    Australia
    73
    Thanked
    17 times
    Points
    1,946
    Level
    26
    Bauhn amid-917r + amid-972XS
    I guess with PC getting so fast these days, little things with portable devices easily frustrate. That balance between performance/response/convenience versus the battery consumption will always be a problem.
    I found I had to adjust my expectations to reflect the reality of that. I even updated my desktop PC to quad core because trying to use the quad core laptop for power hungry tasks was just heating it too much and thermally throttling it anyway, despite the engineered ability, it was hamstrung by physical limitations of design.
  4. #13
    1,000 Experience Points 3 months registered 500 Experience Points 31 days registered 250 Experience Points
    150751
    Oct 2012
    Southport
    62
    Bauhn AMID-972XS
    Quote Originally Posted by Robbo View Post
    I guess with PC getting so fast these days, .
    well in terms of usability, aside from the bigger screen my Nokia E72 Whoops it
    even editing this reply window was a pita. if I tried to select text i couldnt and the predictive text for some reason fails to activate on any of the text input boxes on this site
    lowered expectations help I guess
  5. #14
    Achievements:
    140915
    Sep 2012
    Australia
    73
    Thanked
    17 times
    Points
    1,946
    Level
    26
    Re: wireless issue on AMID-972XS
    Quote Originally Posted by pellicle View Post
    Maybe you should install TouchPal 5......
    https://play.google.com/store/search...ature=spelling
    Have a look. It's working fantastic on mine. I can select text, prediction is good but I have it set to just show suggestions, not make the change automatically. It has a button to close the keyboard and also one to search, so works better in a browser and a forum. It just seems more intuitive. I've now installed it to all my Android devices and now putting it on my wife's too.
    Sent from my AMID-972XS using Tapatalk 2
    pellicle thanked this.
  6. #15
    150751
    Oct 2012
    Southport
    62
    Bauhn AMID-972XS
    seems interesting, but not sure I like swype on bigger (read landscape) keyboards
  7. #16
    150751
    Oct 2012
    Southport
    62
    Bauhn AMID-972XS
    Quote Originally Posted by senus View Post
    well 1) my nokia with its tiny battery gets 2 days of being on WiFi between charges, so how much power does the tablet reasonabl need? 2) my tablet takes a good 30 seconds to establish wifi again 3) something like 80% of the power goes into the screen anyway
  8. #17
    150751
    Oct 2012
    Southport
    62
    Bauhn AMID-972XS
    was just in the midst of posting somethin encouraging about the post upgrade wifi ability when it dropped its wifi and the browser lost everything I was typing.
    saves me reracting that :-)
  9. #18
    Achievements:
    140915
    Sep 2012
    Australia
    73
    Thanked
    17 times
    Points
    1,946
    Level
    26
    I must admit, I haven't looked hard at the WiFi settings for the tablet, it gets shut down so I wasn't overly concerned about massive battery life in standby. The phone is much more important in this regard, it stays on.
    My wireless has been good on both our tablets. No complaints whatsoever with that. I'd go through the settings carefully and try to decide if the tablet may be faulty. I have had issues with routers in the past. Caused a lot of problems between computer or mobile device use.
    BTW, the TouchPal keyboard doesn't need to be used Swype style. I still key in. That being mentioned, I do want to see how Swype works, more for the phone.
    At any rate, TouchPal beats the included keyboard hands down!
  10. #19
    Achievements:
    140915
    Sep 2012
    Australia
    73
    Thanked
    17 times
    Points
    1,946
    Level
    26
    BTW, I've been swapping between home WiFi and phone tether and my tablet does it with no issue.
  11. #20
    150751
    Oct 2012
    Southport
    62
    Bauhn AMID-972XS
    hi
    the problem i have is that when suspending (quick press of power button) and being connected to a wifi, i then leave and go out of range. I expect that the issue is related to something like email, Facebook, twitter or the like attempting to update by waking up the wlan and then dying in the arse
Ads:
  1. Updating System on AMID 971r and 972xs
    By Robbo in forum Bauhn Tablets
    Last Post: 04-17-2013, 05:21 AM
  2. Bauhn AMiD-972XS Android 4.0 Tablet
    By kato59 in forum Bauhn Tablets
    Last Post: 02-05-2013, 12:01 AM
  3. Root Bauhn AMID-972XS
    By D3ATH in forum Bauhn Tablets
    Last Post: 12-11-2012, 12:33 AM
  4. Bauhn AMiD-972XS Android 4.0 Tablet
    By kato59 in forum New Member Introduction & Site Assistance
    Last Post: 09-28-2012, 04:22 AM
/amid-972xs jellybean
amid-972xs
amid-972xs android tablet
amid-972xs android upgrade to jelly bean
amid-972xs flash player
amid-972xs jelly bean
amid-972xs update
amid-972xs wifi
bahun tablet wifi problems
bauhn tablet wifi
how to install jellybean 4.1 bauhn on to amid-972xs tablet
poor wifi connection on bauhn 972xs
