Page 1 of 2 1 2 LastLast
Results 1 to 10 of 20
Thanks Tree6Thanks
Thread: wireless issue on AMID-972XS
  1. #1
    Member Achievements:
    1,000 Experience Points 3 months registered 500 Experience Points 31 days registered 250 Experience Points
    150751
    Oct 2012
    Southport
    62
    Bauhn AMID-972XS
    Hi
    among the many issues I have with this tablet, one which bothers me is the poor wireless communications. Does anyone else find that if they are not within a close range to the wireless access point that you get no signal and drop offs?
    I go to a room only 10 meters away and my phone gets better more reliable wireless connection than this table does. Heck my phone and my laptop connect me across the road!
    Then there is the issue of wireless dropping off when there are more than one SSID's on the same channel. I get constant drop offs on this tablet while again my phone (Nokia E72) just gives me great signal.
    Is there any way that the wireless config can be updated via some sort of remote access *without* rooting the tablet?
    thanks
    Ads
    Advertising world
  3. #2
    Points: 1,946, Level: 26
    Level completed: 46%, Points required for next Level: 54
    Overall activity: 0%
    Achievements:
    1 year registered 1,000 Experience Points 500 Experience Points 3 months registered 250 Experience Points
    140915
    Sep 2012
    Australia
    73
    Thanked
    17 times
    Points
    1,946
    Level
    26
    Bauhn amid-917r + amid-972XS
    Have you done the firmware update yet? If not, see the thread about it. It may help you.
    I tend to use WiFi Manager to administer my Android devices wireless needs, it makes it easy. Do you use more than one wireless connection for it? The device will try to connect to the same AP normally and you may have to tell it to connect to another. WiFi Manager is fantastic for this and also has great widgets to make it easy.
    I find my tablet works well on wireless.
    https://play.google.com/store/search?q=wifi+manager
    Also, WiFi Analyzer is great for checking channels etc when setting your router manually.
    https://play.google.com/store/apps/d...5hbmFseXplciJd
    And I also use Fing Network Tools. It's really handy to reverse lookup a network and see the devices etc, and get MAC addresses, ping, look up services etc. I was using it last night to check if a security DVR was on the network. Fantastic app.
    https://play.google.com/store/apps/d...b2lkLmZpbmciXQ..
    leeshor and pellicle thanked this.
  4. #3
    150751
    Oct 2012
    Southport
    62
    Bauhn AMID-972XS
    Hi
    Quote Originally Posted by Robbo View Post
    had not, will do :-)
    well I resort to that when I'm at work, at home its fine. The tablet works fine in simple environments but gets confused at my university campus (I assume because there are so many similar SSID's
    my Nokia however does not ... nor my Galaxy running Froyo ... so either its an ICS issue or its the tablet.
    good ...
    already using that. Its like watching a camel race seeing the humps move around.
    sorry, but since my Nokia, my Samsung, everyone's iPhone and all the iPads work fine right out of the box if something as simple as connecting to a more complex access point scenario than "I'm at home with one AP" stumps the system, then its speaks reams for how fragile and dinky this system really is ... perhaps I just expect things to work?
  5. #4
    Super Moderator
    Points: 18,928, Level: 87
    Level completed: 16%, Points required for next Level: 422
    Overall activity: 64.0%
    Achievements:
    Recommendation First Class 10,000 Experience Points Recommendation Second Class 1 year registered 5,000 Experience Points
    Awards:
    Frequent Poster
    77592
    Dec 2011
    Norcross, GA
    4,460
    Thanked
    843 times
    Points
    18,928
    Level
    87
    Transformer Prime & TF700
    I don't think it is an ICS specific issue or there would be many hundreds more complaints. Not all devices work the same with all router settings and sometimes that can indeed be the problem, (of course it could be your tablet). Someone on this forum had a similar issue a few weeks ago and changed their router channel to 1 and the problem(s) went away.
    I have some additional tips in a link in my sig. Maybe something there will help, or not!
    Locked out of your Tablet? - Printing from an Android tablet (or phone) - Connecting to the Internet with no WiFi - Move/copy/cut/paste files to and from your tablet - WiFi connection issues - Getting Flash Player
    TF201 & TF700 (stock) with dock, .
  6. #5
    Junior Member Achievements:
    149601
    Oct 2012
    Central Tablelands of NSW, Australia
    8
    Thanked
    2 times
    Bauhn AMid 972Xs
    Pellicle, I'm with you on this, when I buy something I dont expect or want to have to go chasing bloody updates to get it to work.
    A lot of this Technobabble is way over my head and I dont have a clue what its about like 'Rooting', 'Jailbreaking', 'Bricking', 'jellybeans' etc.
    I have only worked out that 'Tethering' is just another way of saying 'Connected' !!!
    I really dont see why I should have to pay for an 'APP' (another new bloody term) to make the Tablet work when it should do so when bought !!!
  7. #6
    3 months registered 250 Experience Points 100 Experience Points 31 days registered 7 days registered
    143930
    Sep 2012
    Australia
    16
    Thanked
    1 times
    Bauhn 972XS
    My wireless has been good. No dropouts or poor signal and signal strength on my home wifi is exactly the same, according to network signal info app, as my galaxy s when it was running ICS and it's even a bit better than my galaxy s now that it's running jellybean. And I have tested tablet and phone together at different places around the house.
    Tethering to my galaxy s has worked very well too, always connects as soon as I activate it on my phone
    One thing that does bug me about my 972xs wireless is that after I wake it with the power button it shows no internet in the notification panel and it's a little slow to reconnect both at home and on my phone.
  8. #7
    150751
    Oct 2012
    Southport
    62
    Bauhn AMID-972XS
    Quote Originally Posted by senus View Post
    and that too!
    I can not get WiFi hotspot to work with AdHOC wireless, when you set it up on your galaxy I'm pretty certain that you set an infrastructure WiFI accesspoint. I know that all meanings in life drift, but once upon a time I understood wifi hotspot meant an adhoc sharing arrangement.
    seeing as my phone supplies WiFi Hotspot with Joikuspot you just can't access it. You may google this and discover just how many people have identified this issue
  9. #8
    150751
    Oct 2012
    Southport
    62
    Bauhn AMID-972XS
    Hi
    Quote Originally Posted by leeshor View Post
    oh, but there already are. Nearly always a poster gets swamped by fanboys and noone has the experience to stand up and provide solid evidence. Either that or they just lurk and await solutions.
    My neighbour is just one such. He's an engineer and his SG LTE with ICS (and his wifes S Note 7) will not connect to a WiFi point reliably. He's tried a new router at home, mine here ... so he's 3G or too bad. He can only get his wife on WiFi if he makes his SG LTE into a wifi infrastructure point and gives her that to slup off
  10. #9
    Super Moderator
    Achievements:
    Awards:
    Frequent Poster
    77592
    Dec 2011
    Norcross, GA
    4,460
    Thanked
    843 times
    Points
    18,928
    Level
    87
    I have solved that problem by doing the following, (your settings location may be different) but there should be a spot somewhere to tell your tablet to keep the WiFi on while sleeping. On mine it is set to always. Then install an app from the Store called Auto Airplane Mode, (by DON). My tablet's WiFi is on before I can even get the passcode input and it uses only about 2% battery power over night.
  11. #10
    Achievements:
    140915
    Sep 2012
    Australia
    73
    Thanked
    17 times
    Points
    1,946
    Level
    26
    I must admit, the slow wake up of wifi can be a tad annoying if you're in a hurry, but it's just a power conservation setting. If it didn't sleep you would then complain of battery issues. Look at the new iP5, many complaints regarding battery. I think Apple released the phone with a lot of stuff turned on so it is fast, responsive and impresses the fanboys. They soon tire of charging twice a day and start turning things off
    BTW, the 2XS has a 3 point performance mode setting for the CPU too. It comes set on medium.
    I'm leaving my wifi in auto sleep mode, it wakes up and connects reliably for me anyway. I take my tablet with me sometimes, so it has to connect to my home wifi, dad's wifi, maccas wifi or to my phone when set to wifi tether. I also tether to my laptop with the phone, but USB tether also works great and only have one power cord then, phone charges off lappy.
Ads:
  1. Updating System on AMID 971r and 972xs
    By Robbo in forum Bauhn Tablets
    Last Post: 04-17-2013, 05:21 AM
  2. Bauhn AMiD-972XS Android 4.0 Tablet
    By kato59 in forum Bauhn Tablets
    Last Post: 02-05-2013, 12:01 AM
  3. Root Bauhn AMID-972XS
    By D3ATH in forum Bauhn Tablets
    Last Post: 12-11-2012, 12:33 AM
  4. Bauhn AMiD-972XS Android 4.0 Tablet
    By kato59 in forum New Member Introduction & Site Assistance
    Last Post: 09-28-2012, 04:22 AM
/amid-972xs jellybean
amid-972xs
amid-972xs android tablet
amid-972xs android upgrade to jelly bean
amid-972xs flash player
amid-972xs jelly bean
amid-972xs update
amid-972xs wifi
bahun tablet wifi problems
bauhn tablet wifi
how to install jellybean 4.1 bauhn on to amid-972xs tablet
poor wifi connection on bauhn 972xs
