Results 1 to 6 of 6
  1. #1
    Junior Member Achievements:
    28277
    Apr 2011
    Caglary
    Coby Kyros MID7015
    Coby Kyros MID7015 Not Turning On
    Hi, I have had my tablet for a week and now the unit will not start up. It feels hot as if it is running but the screen is blank, it appears to charge. Right now I can't get it to reset, or start up using the battery power or when plugged in.
    The reset button hole has no resistance at all and I can get a paper clip in to about a half inch with nothing behind.
    Thanks for any help...
    Ads
    Advertising world
  3. #2
    Senior Member Achievements:
    17893
    Feb 2011
    Arkansas
    186
    Thanked
    15 times
    Coby MID 7015
    What reset button hole? There is a small button on the back that you can use the stylus on to push in for a few seconds. If you are sticking paper clip into a hole on the Coby that may be part of your problem. You may have shorted something out. Hopefully not.
  4. #3
    28752
    May 2011
    Charlotte, NC
    MID7015
    I'm having the same problem, i got 3 days of use out of it and it won't turn on now.
    edit- pushed reset and it started up. I was afraid that if i pushed reset it would put it back to factory and I would lose the root.
  5. #4
    500 Experience Points 250 Experience Points 100 Experience Points 3 months registered Tagger Second Class
    28874
    May 2011
    Quillota CHILE
    20
    CYROS MID 7015
    I recommend you connect the tablet to a charger
    preson reset button and if it does not leave a long time down the power button (about 30 seconds)
    S DESIGN chile S.A
    www.sd-chile.com
    graphic design at your fingertips
  6. #5
    Points: 6, Level: 1
    Level completed: 11%, Points required for next Level: 44
    Overall activity: 0%
    190645
    Feb 2014
    Points
    Level
    help
    my coby kyros is not turning on i even alrready pressed the reset button but stillnothing happens. i also tried to charge it, still nothing happens. i already connected it on a usb connector but still nothing happens
  7. #6
    Points: 337, Level: 6
    Level completed: 74%, Points required for next Level: 13
    Overall activity: 12.0%
    Achievements:
    31 days registered 3 months registered 250 Experience Points 7 days registered 100 Experience Points
    190840
    Feb 2014
    Northeast
    30
    Thanked
    4 times
    Points
    337
    Level
    Rooted Coby Kyros MID1125/ ICS, Kurio 7s, Kurio 7, Trio Stealth 8, Sylvania 7,
    Hey, My Coby is a little different from yours, but as far as I know...you can't charge it with the usb cable- that is only for connecting to computer to access it. I could be wrong but you should try letting it charge with your dc charger. I could be totally off the mark but let me know how your coming along.
Ads:
  1. Coby Kyros mid7015 will not work
    By 100thdegree in forum Coby Generation 1
    Last Post: 07-07-2012, 06:22 AM
  2. Market 3.4.4 Coby Kyros MID7012-4g and the problem with device turning on randomly
    By eynstyne in forum Android Tablet Usage, Tips & Tricks
    Last Post: 03-02-2012, 09:55 AM
  3. coby kyros mid7015 2.1
    By tlucas1973 in forum Coby Generation 1 Technical
    Last Post: 11-29-2011, 01:03 AM
  4. Coby Kyros MID7015
    By KSR in forum Coby Generation 1
    Last Post: 05-10-2011, 09:53 PM
  5. Android 3.0 on Coby Kyros MID7015
    By MarioLucioNeto in forum Coby Generation 1
    Last Post: 03-18-2011, 05:48 PM
cant turn on my coby
coby 7015tablet wont power on
coby android tablet not turning on
coby kyros med7036 does not turn on
coby kyros mid7012 wont turn on
coby kyros mid7015 wont turn on
coby kyros no power
coby tablet mid7012 gets hot when charging and does not turn on
how to get kyros tablet to work when its not trurnin on
kyros tablet will not turn on
my coby kyros 7 wont charge
my coby kyros mid7015 wont turn on
