Page 1 of 2 1 2 LastLast
Results 1 to 10 of 16
  1. #1
    Junior Member Achievements:
    12927
    Jan 2011
    south dakota
    Thanked
    1 times
    kyros
    trouble charging tablets
    I may be posting in the wrong place, sorry if that's so. Is anyone having problems charging your tablets? I have 2 for my kids, bought them at the same time, and we are having the hardest time getting them to charge at all.
    We plug the power cords into the tablets, the little red/green lights no longer come on. Occasionally the battery indicator on the screen itself will show totally green as if fully charged, when in fact the tablet battery was just dead. As soon as the power cord is disconnected, it gives the "powering down" message, due to dead battery.
    We've tried adjusting the position of the cords, thinking a loose connection, but still no luck. Both kids are fairly responsible and take very good care of the tablets, just seems odd that they should both have the same problem at the same time.
    New to the tablet world here, and any help would be greatly appreciated.
    Ads
    Advertising world
  3. #2
    18588
    Feb 2011
    16
    Thanked
    1 times
    I would go into clockworkmod and try to clear the battery stats. Worth a shot.
    Device: HTC Inspire™ 4G x2
    ROM: CoreDroid 4G V6.7
    OS: Android 2.3.3 *GingerBread*
    Kernel: 2.6.35.13 MDJ's V21
    Radio_12.41.60.19_26.06.04.14_M
    ENG S-OFF: ✓
    Device: Coby MID7015A-4G x3
    ROM: OEM Gpad701 20110426
    OS: Android 2.3.1 *GingerBread*
    Kernel: 2.6.35.7
  4. #3
    Senior Member Achievements:
    28293
    Apr 2011
    Peoria, IL
    201
    Thanked
    13 times
    Coby Kyros MID7015A
    How long have u had the tablets?
    worm9110, he may not have the tablets rooted so he will not have clockworkmod
  5. #4
    12927
    Jan 2011
    south dakota
    Thanked
    1 times
    kyros
    They were Christmas gifts. No, not rooted, I was never quite that confident to root and they worked fine for what the boys wanted to use them for (movies, games, music, surfing the web). Thanks for the replies.
  6. #5
    28293
    Apr 2011
    Peoria, IL
    201
    Thanked
    13 times
    Coby Kyros MID7015A
    Well christmas seems too far away from a warranty, unless u got like a 2yr extended. If not then an option u could try is to factory reset them. If u really want them fixed and u dont care if u lose everything, I would do that. Or do a factory reset on 1 and if it works on 1 than do on both, if it doesnt work, then try something else
  7. #6
    Points: 2,446, Level: 29
    Level completed: 98%, Points required for next Level: 4
    Overall activity: 0%
    Achievements:
    1,000 Experience Points 1 year registered 500 Experience Points 250 Experience Points 100 Experience Points
    31026
    May 2011
    New Orleans
    111
    Thanked
    13 times
    Points
    2,446
    Level
    29
    Galaxy Note 10.1
    I saw a post in the Kyros forum here that said the stock battery could be charged 300 times. Maybe both of your kids have hit the charge limit. I'll search around again and see if I can find that post. Of course I may be thinking of another tablet, I read about quite a few.
    Sent from my TnT G-Harmony using Android Tablet Forum
  8. #7
    28293
    Apr 2011
    Peoria, IL
    201
    Thanked
    13 times
    Coby Kyros MID7015A
    No Adelamarc, you are right. The crappy battery in the device can only be charged '300 times' according to COBY. Which I could see the limit being reached from christmas. When mine takes a dump, I am going to buy a battery offline, and replace it myself
  9. #8
    Achievements:
    31026
    May 2011
    New Orleans
    111
    Thanked
    13 times
    Points
    2,446
    Level
    29
    Galaxy Note 10.1
    Well I'm glad that I remembered that correctly, I have to admit I was a bit shocked when I read that. Does the tablet have a substandard NiMH battery or something?
  10. #9
    28293
    Apr 2011
    Peoria, IL
    201
    Thanked
    13 times
    Coby Kyros MID7015A
    Here is the link to the thread u were probably looking at http://www.androidtablets.net/forum/...-concerns.html
    Not sure on the battery specs. I kno it is a 2450mAh and 3.7v (as shown in photo in thread) You can buy a replacement battery for some $ and replace it. I think there is a link for 1 in the thread. Also u could buy some connectors (which is also talked about in the thread) and do it that way. when the battery goes bad, just get a new one and hook it in. Or u could possibly upgrade to a 500 charge battery, which would take longer to wear out.
  11. #10
    Moderator Achievements:
    10,000 Experience Points 1 year registered 5,000 Experience Points 1,000 Experience Points 500 Experience Points
    11725
    Jan 2011
    The Big Apple
    476
    Thanked
    21 times
    Nook Color (Rooted)
    I'm not really sure I buy that "it only charges 300 times" thing. It's too vague. Do they mean from completely empty to full? What if you never let the battery drain completely? I know these are low cost tablets but give me a break. Someone who uses it to watch movies or listen to music frequently could conceivably have to charge their battery twice a day. That would leave them with a useless tablet in just 5 months!
Ads:
  1. USB Charging
    By cisfast in forum Acer Iconia Tab A500 Accessories
    Last Post: 06-09-2012, 10:52 PM
  2. help with charging
    By mcjr517910 in forum Augen Gentouch
    Last Post: 10-11-2011, 08:00 PM
  3. USB charging?
    By husker_fan in forum Augen Gentouch
    Last Post: 04-14-2011, 08:37 AM
  4. Trouble charging AND with Velocity Micro....
    By CenturionFive in forum Velocity Micro Tablets
    Last Post: 04-12-2011, 11:36 AM
  5. Trouble charging
    By Lukap in forum Coby Generation 1
    Last Post: 01-16-2011, 04:28 PM
how to fix a rca tablet charger
my rca tablet wont charge
rca 7 inch tablet not charging
rca tablet battery not charging
rca tablet charging problem
rca tablet charging problems
rca tablet not charging
rca tablet will not charge
why wont my 7 rca tablet charge
why wont my rca tablet charge
www rca tables problem charger
