Results 1 to 6 of 6
  1. #1
    Junior Member Achievements:
    250 Experience Points 100 Experience Points 31 days registered 7 days registered
    35530
    Jun 2011
    Philippines
    Coby Kyros 7015A
    Coby Kyros MID7015A Won't Turn On
    All, hi, I rooted my Coby MID7015A, and then installed the Google Market Place on it. The unit was doing fine, until the battery ran out. I connected the unit to the AC Charger, and the red light along the side of the unit where the Power Button was on lighted up. However, even after an hour of charging, when I try to turn on the unit using the power button, it just won't turn on.
    I have a brand new unit, by the way. Right out of the box, I rooted it and installed the Google Market Place. I don't know if that action had an effect on the unit not turning on now.
    Any help whatsoever is highly appreciated. Thanks.
    Ads
    Advertising world
  3. #2
    35530
    Jun 2011
    Philippines
    Coby Kyros 7015A
    All, the problem has been solved. I initially reset the unit (push on the reset button at the back) before, but it didn't work. When I tried it again later, though, the unit turned on.
  4. #3
    22891
    Mar 2011
    31
    Coby Kyros 7015
    Yep, you will encounter this scenario most of the time.
    Sent from my KYROS 7015 using Android Tablet Forum
  5. #4
    1,000 Experience Points 1 year registered 500 Experience Points 250 Experience Points 100 Experience Points
    10932
    Dec 2010
    SF Bay Area
    27
    Coby Kyros
    Vanj, do you mean that you often have to "double reset" ? I ask because I have to push the reset button onmy 7015 every time it has reached the green light fully charged state. I don't know if this could be remedied with a cache cleaning but it seems to have become a regular scenario somewhere along the update from original OS to HC over Gingerbread. Not complaining mind you, still a great experience! RJ
  6. #5
    111365
    May 2012
    Brasil
    Coby Kyros MID7015
    Hello,
    I have a problem with my Kyros MID7015, that seems like what you described. When I try to turn on the tablet, sometimes the power button doesen't work. I try it using different combinations of buttons without success, even pressing the reset button does nothing. After some tries, I hold the power button again and it turns on normally. This behavior was shown after I upgraded to 2.3.1. I also upgraded to 2.3.3 and the problem continues. Does anybody here saw something like that, or knows how to correct?
    Thanks.
  7. #6
    Points: 2,590, Level: 30
    Level completed: 94%, Points required for next Level: 10
    Overall activity: 0%
    Achievements:
    Veteran 1,000 Experience Points 1 year registered 500 Experience Points 250 Experience Points
    18474
    Feb 2011
    72
    Thanked
    2 times
    Points
    2,590
    Level
    30
    Coby Kyros 7015
    Quote Originally Posted by rafaelgustavo
    Hello,
    Thanks.
    You may see that periodically. Seems to be the nature of the beast. For some reason I've found mine powers on more readily the first time (as if it were cold overnight, for example) when plugged into the charger. Then resets and restarts, if any, are pretty much normal plugged-in or not. Goodluck.
Ads:
  1. New COBY KYROS MID7015A Owner
    By noto in forum Coby Generation 1
    Last Post: 10-20-2012, 05:23 PM
  2. update.zip from Coby (build MID7015A 1.6a 1/26/11)
    By l_n in forum Coby Generation 1 Technical
    Last Post: 03-18-2012, 02:24 PM
  3. Coby Kyros Stays on coby Main startup screen!! HELP!!!!!!!
    By Moussa in forum Coby Generation 1 Technical
    Last Post: 06-09-2011, 03:30 PM
  4. my coby MID7015a does t no let install anything
    By dr cae in forum Coby Tablet Apps and Games
    Last Post: 05-29-2011, 09:43 PM
  5. Wireless Tether for Kyros MID7015a
    By uslacson1 in forum Coby Tablet Accessories
    Last Post: 03-29-2011, 08:46 AM
coby kyros tablet won't turn on
coby kyros tablet wont turn on
coby kyros won't turn on
coby kyros wont turn on
coby tablet won't turn on
coby tablet wont turn on
how do i know if my coby kyros is charging
how to turn on coby kyros mid7015
my coby kyros tablet won't turn on
my coby kyros wont turn on
what does red light on colby 7015 mean
what to do if your coby tablet wont turn on
