Page 2 of 2 FirstFirst 1 2
Results 11 to 19 of 19
  1. #11
    Member Achievements:
    29098
    May 2011
    Nebraska
    47
    Thanked
    2 times
    Kyros 7024
    im in the same boat. im done with coby. just going to sell mine for parts.
    Ads
    Advertising world
  3. #12
    Junior Member Achievements:
    7 days registered
    54126
    Sep 2011
    coby mid7024
    same thing here on 4th day of using
    I figured out that the problem is in NAND chip which is flashed with wrong/damaged u-boot.bin
    This NAND flash is used like bios chip in PC, and it does initial setup when device is booting.
    Mine is hard-bricked after I updated it with first rom from this post by elemist2:
    http://www.androidtablets.net/forum/...tml#post130172
  4. #13
    Points: 2,148, Level: 27
    Level completed: 99%, Points required for next Level: 2
    Overall activity: 0%
    Achievements:
    3 months registered 1 year registered 250 Experience Points 500 Experience Points 1,000 Experience Points
    52194
    Sep 2011
    california
    21
    Thanked
    1 times
    Points
    2,148
    Level
    27
    samsung galaxy tab 3 t217t
    Wow this scares me! Can you all return the devices? Mine froze on the home screen for awhile and I could not unnlock it. I powered off then on and thank God itcame back and unfroze. So far it has not locked up again thank god but to hear your stories I'm worried now! Hopefully you can get a refund or return. Id hate to loose everything that took me so long to figure out how to install! That's just awful! I hope someone can come up with something to fix the problem!
  5. #14
    Banned Achievements:
    500 Experience Points 3 months registered 250 Experience Points 100 Experience Points 31 days registered
    43672
    Aug 2011
    Itajubá - MG - Brasil
    67
    Koby Kyros MID7024
    Can anyone help me? In mine, only the LED's light up. I can not turn it at all. When I press to turn the LED's light up but he does not care. Thank you.
  6. #15
    Developer
    Achievements:
    25,000 Experience Points 10,000 Experience Points 1 year registered 5,000 Experience Points Tagger First Class
    51130
    Sep 2011
    Brasil
    1,388
    Thanked
    239 times
    You can try this (at your own risk):
    PROJECT: Reviving a Hard Bricked Kyros
    Read all the thread for more info, it was reported to work with MID8024 and MID7024. Good luck.
  7. #16
    7 days registered
    54126
    Sep 2011
    coby mid7024
    worked for me, it's alive
  8. #17
    Achievements:
    52194
    Sep 2011
    california
    21
    Thanked
    1 times
    Points
    2,148
    Level
    27
    I had my coby kyros for less than one week and it won't start! It keeps blinking android. I ordered a new android tablet, a skytex skypad alpha with android 2.3 os. I'm hoping I have better luck with it! It has some great reviews and has bluetooth and a webcam.. maybe it will be better? I hope so!
  9. #18
    250 Experience Points 100 Experience Points 7 days registered
    54038
    Sep 2011
    Lisbon, Portugal
    35
    Thanked
    1 times
    MPMAN 827 (replica of the Coby Kyros MID 8027)
    Quote Originally Posted by Scrawler View Post
    Any luck?
    Mine is a MID 8027 and it's the same. Tried the PROJECT: Reviving a Hard Bricked Kyros with no luck.
  10. #19
    108263
    Apr 2012
    here is my version of fixing dead MID7024
    STATE: It wouldn't turn on. When I press the start button the softkeys light up for a few seconds, then go out. The screen never lights up. I does the same thing holding the home/back key while starting.
    SOLUTION:
    1. Take out external sdcard from device
    2. Put it in my computer (win 7 64 bit)
    3. Erase all data from it
    4. Use winimage tool: from winimage menu "Disk->Restore Virtual Hard Disk image on physical drive..." select the microSD card (corresponding device), then pick file "u-boot-SD.bin.mid703v3.mm" (find that file online)
    5. Eject and insert again sd card
    6. Format sd card (fat 32 - don't choose quick format)
    7. All files from Coby firmware put on sd card (Kyros™ Internet 7" Touchscreen Tablet | COBY) - just unpack zip
    8. Put sdcard into device (MID7024)
    9. Hold home button and press power few sec
    10. flashing started... when finished it will turn off.. press power and voila, Coby is live again! :-)
    PS. without short-circuit the NAND
Ads:
  1. Kyros 7024 Web Browser Issue
    By becks in forum Coby Generation 2 Technical
    Last Post: 12-27-2011, 08:50 PM
  2. Kyros 7024 Sd card question.
    By acidchalk in forum Coby Tablet Accessories
    Last Post: 10-16-2011, 12:06 PM
  3. how to format kyros 7024?
    By anlekna in forum Coby Generation 2
    Last Post: 06-28-2011, 07:39 PM
  4. Kyros 7024 Lockscreen
    Last Post: 06-17-2011, 08:35 AM
  5. Kyros 7024 as a PMP
    By Ray50 in forum Coby Generation 2
    Last Post: 06-09-2011, 01:33 PM
coby kyros mid7024 factory reset
coby kyros mid7024 won't start
coby kyros tablet will not boot
coby kyros won't turn on
coby kyros wont boot up
coby tablet kyros model md7042 will not turn on
coby tablet won't start up
dropped kyros wont boot
factory reset coby mid7024
how to factory reset coby tablet mid7024
mid 7024 is not loading what can i do
reset mid7024
Tags for this Thread
