Need help! Mid7022
Coby Kyros Mid 7022 Stuck on Force close screen
Tried applying a theme to ADW launcher and it went into forceclose screen and now I can't get past it. I tried reset button but as soon as I unlock screen it goes to adw launcher forceclose screen. How do I get around this?
08-12-2011 08:57 AM
# ADS
Try connecting to ur pc and manually deleting the theme, if not then boot into recovery manager an do a master reset/factory reset
Sent from my Coby Kryos MID7024 not-rooted with 16gb microSD
ROOTED Acer Iconia A100 16gb running HC 3.2
Originally Posted by
wicced247
I have tried connecting to my computer but I can't find where the files are. I went to devices and found it and tried clicking and right clicking but there is no way to open the files.
How do I boot into recovery mode and do the factory reset?
Thanks. Was able to reset my tablet. Your help was very much appreciated
Oh thats great and your welcome
I am with same problem.
Coby Kyros Mid 7022 Stuck on Force close screen. Tried applying Google Market and it went into forceclose screen and now I can't get past it.
I tried power+back (silver) button but it goes to Android warning triangle screen and stay frozen.
Please, someone can help me ?
When you get to the triangle with the exclamation hit the back button you should be in the recovery menu.
Did you figure out if the issue was ADW Launcher or the theme you tried using?
TheDroid13
I hit the back button but it is frozen on the screen with the exclamation (triangle).
JArmandB
I donīt know. I try to install market and now it is stuck on "andorid.setupwizard force close" screen.
