Page 1 of 19 1 2 3 11 ... LastLast
Results 1 to 10 of 189
Thanks Tree22Thanks
Thread: PROJECT: Reviving a Hard Bricked Kyros
  1. #1
    Developer
    Achievements:
    25,000 Experience Points 10,000 Experience Points 1 year registered 5,000 Experience Points Tagger First Class
    51130
    Sep 2011
    Brasil
    1,388
    Thanked
    239 times
    Lightbulb PROJECT: Reviving a Hard Bricked Kyros
    Background
    Quote Originally Posted by Arlic View Post
    ..."Soft Recovery" mode doesn't seem to work in all "brick" cases. When the Coby screen doesn't turn on at all "and" Droid Explorer or Disk Management don't detect the Coby "and" the soft lights shut off after 7 seconds......you're Coby is in a "HARD" brick.
    There are some users with "hard bricked" Kyros: tablet will remain on only while holding the power button, during this period the touch buttons will remain light. Buttons will go off as soon as one releases the power button. If the power button is also pressed for a long time (~10 seconds), it will also go off.
    There is a similar "hard brick" with tablets very similar to Kyros, known as HeroTab/DroPad. They found out that it's possible to revive the tablet using a "SD boot", when the internal NAND content is bypassed or not needed.
    Tutorial with solution is here:
    [GUIDE] Revive your dead tablet - SlateDroid.com
    Long thread with hardware details (although not devoted to revive a tablet) here:
    [DEV] Custom kernel for Dropad/Herotab - SlateDroid.com
    Facts:
    1. Some Kyros tablets exhibit "hard brick".
    2. "Hard brick" is related to NAND problems.
    3. Similar tablets (almost same hardware) with similar symptoms were successfully revived, using a bootable microSD card that re-flashed NAND.
    4. It is possible to put smdkv210 (CPU board used in MIDxx24) to boot from either NAND or SD.
    5. Not all Kyros have the same internals (ex. MID1024 tablets may have MID1025 boards or MID1024N boards, same goes for 7024 and possibly 8024).
    Questions:
    1. Is there a simple way to determine if a Kyros is "hard bricked", i.e. fully working besides a faulty NAND?
    2. It is possible to have console (simple TTL terminal) access to smdkv210 boards, it's also possible with Kyros? How?
    3. Is there a way to change a Kyros from NAND boot to SD boot? How?
    4. Is there a working bootable image (u-boot-sd.bin) for Kyros? Universal or one file is needed for each model?
    5. Finally, is it possible to revive a "hard bricked" Kyros? How?
    Admin and zamb thanked this.
    Ads
    Advertising world
  3. #2
    Developer
    Achievements:
    51130
    Sep 2011
    Brasil
    1,388
    Thanked
    239 times
    Edited 2011.10.15
    Open your Kyros, and short-circuit NANDS pins 7 & 8 while you hold power button pressed. I may go on with the screen all white. Release power button and remove whatever you've used to do the short-circuit. If your tablet remains on then probably it's still working. (Ref: Arlic)
    It seems that in some cases (maybe due to a non-working/dead NAND), Kyros will boot from external microSD without the need of opening it and short-circuiting pins 7 & 8. It was reported more than once for MID7024 models (megalex and theNige). You just need a specially made microSD in the external slot (see below).
    Yes, it's possible, connecting some wires to the smdkv210 board (Ref. slatedroid forum forum - Asure/mg3100) found in MIDx024 tablets. It's a risky procedure since the pins are very small and close to each other. Maybe it's also possible to use some pads in the main board, but it isn't documented so far.
    Yes, there is. So far the only known way is to short-circuit NAND pins 7 & 8 while turning one the tablet. It's also possible to change some smdkv210 board resistors/wires (see slatedroid thread above for more info), but it's not a good solution for Kyros since resistors are too small and there is a high risk that you may break something else or simply won't be able to revert it. If there're pads in the main board for these connections like the ones in Herotab/Dropad boards, then it will be much easier.
    Yes, the same u-boot used for Herotab/Dropad resurrecting firmware can be used with Kyros. The only problem is that it's made for tablets with resistive screens like 7024/8024. It will boot 1024, but a proper ROM/firmware has to be used to actually flash NAND/microSD for a fully working tablet.
    Yes! Arlic was the first one to find it using a MID8024. So far, his procedure was tested with 7024, MPMAN827 and 1024. For success, a correct firmware is needed (the ressurection firmware only revives the tablet, the correct one is needed for a fully operational unit). For this reason, it seems that some old MID1024 tablets actually use a 1025_v4 board that may brick if used the official firmware, so a working ROM for these models is yet to be found.
    PS: microSD card with resurrecting firmware used in the external slot must be 4GB or bigger! (found by SampNeves)
    If you still have questions, ask it in this thread and I am sure someone will try to help.
    Thanks for everyone who helped and shared what has been found. Props go to Arlic for trying it on smdkv210-based Kyros and sharing it!
    zamb thanked this.
  4. #3
    Senior Member Achievements:
    5,000 Experience Points 1 year registered 1,000 Experience Points 3 months registered 500 Experience Points
    49171
    Sep 2011
    Nevada
    142
    Thanked
    9 times
    Coby mid8024,Coby mid1024
    I didn't read all of your post but I googled smdvk210 board and I found this pdf
  5. #4
    Developer
    Achievements:
    51130
    Sep 2011
    Brasil
    1,388
    Thanked
    239 times
    Got that PDF too. It explains how to choose between NAND and SD boot, but it needs to change wires (or resistors) in the board. That how they got access to NAND boot in the SlateDroid thread about a custom ROM.
    Regarding Kyros, it seems that the board doesn't have any labels for the pads (8024 pics from nefirim):
    Unbrick or update Coby Kyros 7024 with gingerbread firmware...!!!!
    I don't wanna mess with the CPU board as the soldered items are too small. If we are able to find out OM1-OM2 pads in the Kyros board, then we have a starting point... Until then, only assumptions I guess...
  6. #5
    Developer
    Points: 4,949, Level: 44
    Level completed: 99%, Points required for next Level: 1
    Overall activity: 0%
    Achievements:
    1 year registered 3 months registered 1,000 Experience Points 500 Experience Points 250 Experience Points
    50666
    Sep 2011
    119
    Thanked
    31 times
    Points
    4,949
    Level
    44
    Coby Kyros 8024
    If anyone has a board/tablet they're willing to spare or don't care about, I can try and do some testing to see if I can get a serial connection on it and then beyond that, if there is a way to SD boot. I unfortunately do not have the money to buy another and make this one my testing one.
  7. #6
    Developer
    Achievements:
    51130
    Sep 2011
    Brasil
    1,388
    Thanked
    239 times
    So, no one knows how to get a console connection to Kyros 2nd gen boards?
    It seems that hard bricking may be related to a hardware failure, when the system tries to write to the NAND. I've read some reports when people bricked tablets simply by trying to flash the official stock firmware. Maybe a design defect? If so, it'd be very dangerous to try any ROM flashing using any smdkv210 based Kyros.
  8. #7
    Developer
    Achievements:
    50666
    Sep 2011
    119
    Thanked
    31 times
    Points
    4,949
    Level
    44
    Coby Kyros 8024
    reposting here for everyone following this thread : Unbrick or update Coby Kyros 7024 with gingerbread firmware...!!!!
  9. #8
    Developer
    Achievements:
    50666
    Sep 2011
    119
    Thanked
    31 times
    Points
    4,949
    Level
    44
    Coby Kyros 8024
    also I found this little http://db.tt/hbx3ZTFa jewel after some google-fu. Its the full data sheet/manual for the S5PV210 (Thanks to the folks at Slatedroid) which does include the memory address map and also the pin outs, meaning we can now find the OM1 and OM5 needed to get SD boot. granted this just shows it for the bottom of the processor which is covered but it does allow for a more educated guess as to which of those pads on the back of the board go to what.
  10. #9
    Developer
    Achievements:
    51130
    Sep 2011
    Brasil
    1,388
    Thanked
    239 times
    This is nice. If we are able to get a direct terminal connection to the smdkv210 board it would be half the problem solved. If it only needed USB then much better.
  11. #10
    Developer
    Achievements:
    50666
    Sep 2011
    119
    Thanked
    31 times
    Points
    4,949
    Level
    44
    Coby Kyros 8024
Ads:
  1. [HARD MOD] Added 500 GB harddrive + on/off switch for hard drive
    By goodintentions in forum Asus TF101/SL101 Forum
    Last Post: 09-23-2011, 01:30 PM
  2. Coby Kyros 7005 Bricked?
    By gre3ntea in forum Coby Generation 1
    Last Post: 08-24-2011, 02:56 PM
  3. Help, I bricked my Kyros using autostarts!
    By henrychamb in forum Coby Tablets
    Last Post: 03-21-2011, 05:30 PM
  4. Next project
    By idontknow in forum Nook
    Last Post: 03-10-2011, 02:03 AM
  5. reviving x5a
    By playnotwork in forum Telechips TCC8902 Tablets
    Last Post: 02-16-2011, 05:55 PM
coby kyros mid7015 board
hard bricked mid8024
how to fix hard bricked coby kyros mid 8024
how to revive dead in tablet
kyros 8024 bricked
mid7127
revive bricked android tablet
reviving brick tablets
short circuit bricked kindle
smdvk210
smdvk210 board
unbrick hard bricked android tablet
Tags for this Thread
