Results 1 to 7 of 7
  1. #1
    Member Achievements:
    1 year registered 1,000 Experience Points 500 Experience Points 250 Experience Points 100 Experience Points
    31242
    May 2011
    Upstate, SC USA
    44
    Coby 7015
    Charging with non-Coby Charger
    I just picked up 2 wall chargers on the cheap from a yard sale. They were used for a Samsung cell phone. My Coby charger says it's 2amps. The Samsung is 5amps. Will I do any damage to the battery using these chargers?
    Ads
    Advertising world
  3. #2
    Points: 2,710, Level: 31
    Level completed: 74%, Points required for next Level: 40
    Overall activity: 0%
    Achievements:
    1 year registered 1,000 Experience Points 3 months registered 31 days registered 500 Experience Points
    54431
    Oct 2011
    Tennessee
    242
    Thanked
    11 times
    Points
    2,710
    Level
    31
    Samsung Captivate (Rooted) Coby Kyros 1024
    better check the voltage. that is also very critical.
    Coby Kyros MID1024 - Volcano-Honeycomb Rom - Rooted - Optimized - Kicking Ass
    Samsung Galaxy S Captivate - Fusion ICS from the Collective ROM Glitch kernel.
  4. #3
    Developer
    Achievements:
    25,000 Experience Points 10,000 Experience Points 1 year registered 5,000 Experience Points Tagger First Class
    51130
    Sep 2011
    Brasil
    1,388
    Thanked
    240 times
    You need same voltage (V - Volts), and at least same current (A - Amperes). So if your charger says 9V, you need a power supply with also 9V. If the original power supply says 2A, you need one with 2A or more. Also make sure the polarity is the same (positive and negative) or it won´t work.
  5. #4
    Senior Member Achievements:
    5,000 Experience Points 1,000 Experience Points 500 Experience Points 250 Experience Points 100 Experience Points
    38660
    Jul 2011
    California
    417
    Thanked
    30 times
    Coby Kyros MID7022
    Don't want to fry the battery
    Sent from my HTC Glacier using Android Tablet Forum
  6. #5
    1 year registered 1,000 Experience Points 500 Experience Points 3 months registered 31 days registered
    53840
    Sep 2011
    Auckland
    102
    Thanked
    9 times
    Coby 7022
    I'm using a 5V/3A charger on my 7022 (which comes with a 2A charger) no problems so far.
    Seriously though, if you're plugging in something which is not the proper charger for the first time check the following:
    Voltage
    Current (If it's switchmode more is fine, if it's transfomer based [read: heavy] try and match it as closely as possible)
    Pin size
    Polarity (there should be a symbol somewhere on the plugpack with a couple of lines and two circles (one inside the other) make sure this matches, although most devices have ground/negative on the outside)
  7. #6
    31242
    May 2011
    Upstate, SC USA
    44
    Coby 7015
    The samsung chargers are both 5v/5a. The Coby charger is 5v/2a. I already checked the polarity. I was just checking id a 5a charge might damage anything since the oem is 2a.
  8. #7
    Junior Member Achievements:
    3 months registered 250 Experience Points 31 days registered 100 Experience Points 7 days registered
    53906
    Sep 2011
    Thanked
    1 times
    Coby Kyros MID7022
    Quote Originally Posted by subtotal View Post
    Voltage
    Pin size
    The voltage and polarity are very important so you don't fry you tablet on the first plug-in. In your situation the amperage is important, too, but not as much. If the charger is showing 5A, then that means that it can run "up to" the 5A. The important point here is that the device you are charging doesn't exceed that 5A limit. So since the original charger only had 2A, then you're still under the 5A limit which means it won't harm your device as long as the voltage and polarity are correct as well.
Ads:
  1. Replies: 0
    Last Post: 09-28-2011, 01:21 AM
  2. Coby 7024/8024 auto charger
    By Ray50 in forum Coby Tablet Accessories
    Last Post: 08-04-2011, 02:54 AM
  3. NC Power Charger & USB charging issues?
    By FerociousAndroid in forum Nook Color Technical
    Last Post: 06-11-2011, 08:48 AM
  4. Charger Issues (Alternate Charger)
    By lemmyslender in forum Huawei Ideos S7 Accessories
    Last Post: 04-30-2011, 01:54 PM
  5. Coby Kyros NOT Charging after Rooting
    By geheimnisvoll in forum Coby Tablets
    Last Post: 04-06-2011, 08:18 AM
can i use coby charger to samsung phone
coby kyros charger specs
coby kyros tablet charger volts
do i need the orginal charger for my coby tablet
how many volt for a coby tablet
how to charge coby kyros mid1024 without charger
nabi tablet polarity
polarity for coby kyros
positive polarity of a coby kyros
voltage imput for coby tabley
what if the tablet input charging voltage is below 5v
what volt and amp is a coby mid1024
