Page 1 of 2 1 2 LastLast
Results 1 to 10 of 13
  1. #1
    Junior Member Achievements:
    Tagger Second Class
    58400
    Oct 2011
    USA > Oklahoma
    7
    Coby Kyros Model: MID8125 Android Vers: 2.3.3 Kernal Vers: 2.6.35.7
    Question Help! Rooting/Getting Android Market on a Kryos 8125
    Alright, I am having some problems and I am going to explain, in detail, whats wrong.
    I need the Android Market on my Kryos (8125). I did some research and found it should work with the 7033 < Or w/e >. So I preformed the Root method and it did not work and i restored. <Fast Boot although is corrupted but I can factory reset> When I tried the first few times I failed. After getting it to work, with old android market (And goggle services and crap) I noticed the WiFi would go out and i was getting no internet connect. It said I was connect to the wifi, yes, but when I turned WiFi off and then tried turning back on (On my device) it would take 2 minutes and then it would say error. I can get this to work without rooting but I need to get WiFi to stay on ALL TIMES. If I cant get this to work, I am take the thing to the shooting range and and put some lead in it.
    Method:
    Before Hand:
    1. Turn USB Debugging On
    2. Put files on Device SD Card
    3. Turn WiFi On
    4. Make Backups
    Install:
    1. Google Service Framework
    2. One Time Init
    3. Setup Wizard
    4. OLD Market
    6. Setup The Google Launcher
    7. Reboot
    8. Start Market
    9. Setup Market
    10. Use for 5 Mins
    11. WiFi Screwed Up
    12. Reboot
    13. Use For 5 Mins
    14. WiFi Screwed Up
    15. Goto BEFORE INSTALL (Beforehand Steps) and Repeat
    GETTING ANNOYING >
    Specs:
    Brand/Make: Coby Kryos
    Model: 8125
    Kernel: 2.6.35.7
    Recovery: Factory Reset Works/Fastboot is Corrupted
    Adroid Market: Not Installed anymore
    If anyone can help me, THANK YOU
    Ads
    Advertising world
  3. #2
    Developer
    Achievements:
    25,000 Experience Points 10,000 Experience Points 1 year registered 5,000 Experience Points Tagger First Class
    51130
    Sep 2011
    Brasil
    1,388
    Thanked
    239 times
    Can you check the versions of GoogleServicesFramework.apk and Vending.apk (Market)? Go to Settings -> Applications -> Manage Applications, find them, tap once and note the version in the top left corner.
    If it's not 2.3, try to find a package with GoogleServicesFramework in this version, and I suggest Market at least 2.3 (I think you only need these too in order to download from Market).
  4. #3
    Tagger Second Class
    58400
    Oct 2011
    USA > Oklahoma
    7
    Service > 2.2
    Gonna Try it (This isnt just for me, its for all of you who have model1825's. After this ima put up a guide for you guys :3)
  5. #4
    Developer
    Achievements:
    51130
    Sep 2011
    Brasil
    1,388
    Thanked
    239 times
    OK, so now try using this package:
    Market_for_2.3 - Minus.com
  6. #5
    Tagger Second Class
    58400
    Oct 2011
    USA > Oklahoma
    7
    "Application Not Installed"
    I wonder if i can photoshop a quick RED and WHITE Photo That looks like a round target.
    Vending Installs, Google...NOPE
    Thanks for trying to help me.
  7. #6
    Tagger Second Class
    58400
    Oct 2011
    USA > Oklahoma
    7
    Older Version Installed......................................... ............ Im really getting pissed now.
  8. #7
    Developer
    Achievements:
    51130
    Sep 2011
    Brasil
    1,388
    Thanked
    239 times
    Remove all versions and try to install in a certain order. If it fails, remove the one installed and install in the other sequence.
    Edit: if it still fails, try downloading ZipSigner2 from somewhere else then sign GoogleServiceFramework to your "platform", then try installing it again.
  9. #8
    Tagger Second Class
    58400
    Oct 2011
    USA > Oklahoma
    7
    It fails. Its that googleservice apk
  10. #9
    Developer
    Achievements:
    51130
    Sep 2011
    Brasil
    1,388
    Thanked
    239 times
    If even after removing every Google-related apk and rebooting it fails, then try to sign it using ZipSigner2.
  11. #10
    Tagger Second Class
    58400
    Oct 2011
    USA > Oklahoma
    7
    I kinda need a direct link seeing as i kinda dont have android market anymore
Ads:
  1. Android Market on the Coby Kyros mid8024 no rooting needed
    By coyle1010 in forum Coby Generation 2 Technical
    Last Post: 12-19-2012, 12:10 PM
  2. Rooting a CMP738b to get android market to run
    By nypokerfreak in forum Craig Tablets
    Last Post: 10-19-2011, 06:37 PM
  3. Replies: 2
    Last Post: 09-16-2011, 04:28 AM
  4. android app market without rooting
    By revlen in forum Viewsonic gTablet Technical
    Last Post: 04-11-2011, 07:54 PM
  5. How to get Android Market apps without Rooting
    By WolfmanRobby in forum Viewsonic gTablet
    Last Post: 03-17-2011, 10:43 PM
8125 rom
coby kyros mid8125 google play
download google play store app for coby kyros mid8125
free apps for coby kyros mid8125
google play store for coby kyros mid8125
how can i make my coby kyros mid8125 faster and up to date for free
how to download google play on coby kyros mid8125
how to install google play store on coby kyros mid8125
install play store on coby kyros mid8125
install playstore on coby kyros mid 8125
mid8125 root
www.androidtablets.net 25064-help-rooting-getting-android-market-kryos-8125-a
Tags for this Thread
