Results 1 to 10 of 10
Thread: Rotate problems
  1. #1
    Junior Member Achievements:
    500 Experience Points 3 months registered 250 Experience Points 31 days registered 100 Experience Points
    81147
    Jan 2012
    Saint Peter, MN
    24
    Thanked
    1 times
    Kyros 7127
    Rotate problems
    My Kyros is fond of going from portrait to landscape when sensing the slightest sideways movement while flat (or slightly tilted). With using the kindle App that becomes a problem. So I have been trying to find an app that will lock my screen in portrait mode. Every app I see states Google only allows android OS to lock in portrait mode, which is funny cause mine only locks in landscape. Does anyone have any suggestions?
    Sent from my MID7127 using Android Tablet Forum
    Ads
    Advertising world
  3. #2
    Developer
    Achievements:
    25,000 Experience Points 10,000 Experience Points 1 year registered 5,000 Experience Points Tagger First Class
    51130
    Sep 2011
    Brasil
    1,388
    Thanked
    240 times
    In Settings -> Advanced settings, do you have an option to change the gravity sensor mode from pad to phone and vice-versa? If yes, does it help?
    I don't have Gingerbread on my MID1024 now, or I would test it here. And sometimes Telechips based Kyros like MID7127 have a completely different settings.
    Anyway, you can try finding a way to change the gravity sensor mode so the lock screen will be in portrait mode like a phone. Or root the tablet and hack it to rotate the sensor manually.
  4. #3
    31 days registered 100 Experience Points 7 days registered Tagger Second Class
    71865
    Dec 2011
    25
    Im not sure what model you have, but on the 7022 if you go to Settings -> Display there is and option call Auto-rotate screen. If you uncheck this, it should solve your problem.
  5. #4
    Points: 1,539, Level: 22
    Level completed: 39%, Points required for next Level: 61
    Overall activity: 0%
    Achievements:
    1,000 Experience Points 1 year registered 500 Experience Points 250 Experience Points 3 months registered
    71298
    Dec 2011
    63630
    11
    Thanked
    5 times
    Points
    1,539
    Level
    22
    lepan tc970
    If just worried about kindel app get in kindel position as you want it tap lower right corner brings up a pad lock tap agian ubtil padlock is locked now it will not change
    Sent from my TC970 (Wi-Fi) using Android Tablet Forum
  6. #5
    81147
    Jan 2012
    Saint Peter, MN
    24
    Thanked
    1 times
    Kyros 7127
    I don't think any of you truly read through the description of the problem.
    1. If i disable auto rotate, use padlock in kindle app, use any app to lock screen in portrait mode it jumps it into landscape and refuses portrait.
    2. The Android OS does not have a settings ->advanced settings
    A little more info I can provide is that it will also auto rotate so the screen is upside down at times.
    So my key question is can I calibrate the rotation or at least lock it in portrait somehow?
  7. #6
    Developer
    Achievements:
    51130
    Sep 2011
    Brasil
    1,388
    Thanked
    240 times
    As I said before, if your device doesn't have Advanced Settings then you can install an apk to enable it or do the same thing.
    Probably there are apps on Market to rotate the screen too, it will need a rooted device, that is also needed to do it manually by editing the system files.
  8. #7
    7 days registered
    86519
    Jan 2012
    Keaau, Hawaii
    coby kryos 7125
    rotate problems
    This has been driving me crazy too! No matter what I do if i turn off auto rotate it reverts back to landscape. I did find an app called orientation control that claims true control over orientation but the market says its incompatable with my device so I can't try it.
  9. #8
    Developer
    Points: 24,391, Level: 95
    Level completed: 5%, Points required for next Level: 959
    Overall activity: 36.0%
    Achievements:
    Recommendation Second Class 10,000 Experience Points 5,000 Experience Points 1 year registered 1,000 Experience Points
    61306
    Nov 2011
    Huntington WV
    3,708
    Thanked
    1384 times
    Points
    24,391
    Level
    95
    Leagoo Lead 1 ZTE OPEN C, Coby 7065, Coby 8042, Coby 9740
    This happens a lot with theses tablets, what I do is just install the app I want on my EVO3D, then just use adb to pull from the phone and install to my tablet.
  10. #9
    81147
    Jan 2012
    Saint Peter, MN
    24
    Thanked
    1 times
    Kyros 7127
    THANK YOU!! The orientation control app works to force portrait perfectly! Google search for the APK and install it and you're golden. No market saying incompatible crap lol...
  11. #10
    Senior Member Achievements:
    5,000 Experience Points 1,000 Experience Points 500 Experience Points 250 Experience Points 100 Experience Points
    38660
    Jul 2011
    California
    417
    Thanked
    30 times
    Coby Kyros MID7022
    Quote Originally Posted by jbaerbock View Post
    nice findddd
Ads:
  1. Tablet wont rotate
    By ryno1974 in forum WonderMedia Based
    Last Post: 09-20-2011, 03:25 PM
  2. screen will not rotate
    By jdc115 in forum Acer Iconia Tab A500 Forum
    Last Post: 09-12-2011, 12:30 AM
  3. Anyone know of a program to rotate video clips?
    By illdill in forum Nook Color Apps and Games
    Last Post: 01-23-2011, 01:41 PM
  4. screen rotate lock?
    By troyy0206 in forum Coby Generation 1
    Last Post: 12-29-2010, 09:01 AM
  5. Disable auto-rotate/g-sensor?
    By kxs783kms in forum Sylvania Tablets
    Last Post: 12-25-2010, 04:51 PM
android app to invert tablet screen
android virtual box tablet apps turn sideways
how to lock screen rotation on rca tablet
my tablet screen won't rotate hannspree
my zeki tablet doesnt go landscape
nexus 7 2nd gen my screen wont turn with the tablet when i turn it sideways
the view on my rca tablet is sideways
verizon tablet gravity sensor
where is the g sensor for zeki tablet
zeki 10 tablet flips from landscape to portrait repeatedly
zeki 10.1 tablet screen orientation
zeki g-sensor
