Page 4 of 36 FirstFirst ... 2 3 4 5 6 14 ... LastLast
Results 31 to 40 of 357
Thanks Tree122Thanks
Thread: Requesting Firmware Dumps from Coby Generation 3 Devices
  1. #31
    Member Achievements:
    3 months registered 31 days registered 250 Experience Points 7 days registered 100 Experience Points
    111833
    May 2012
    SpaceStation, Space
    66
    Thanked
    56 times
    The uploader said the file was too large ( 104.26 MB ) system.tgz
    DOWNLOAD LINK HERE: MID9742-system.tgz , 104.26 MB
    http://www.tempfiles.net/download/20...42-system.html
    (file erased afer on hour)
    I thought I already had the proper drivers.
    The PDAnet Driver would not install (wouldn't recognize my phone/device)
    PDAnet Driver download: http://topnotchtablets.com/installADBdriver
    I had to follow the troubleshooting instructions at http://junefabrics.com/android/driver.php
    (Basically, I had to first install the LG, Samsung and Motorolla Drivers first. )
    Then I Restarted my computer. Then successfully installed the PDAnet Driver.
    Pluged in USB cable, went to Settings, Development, USB Debugging checked. Ran the dump.bat. Script ran successfully (2-3 minutes)
    Dropped the system.tgz file in the same folder as the dump.bat file.
    steev thanked this.
    Ads
    Advertising world
  3. #32
    Developer
    Achievements:
    3 months registered 1,000 Experience Points 500 Experience Points 250 Experience Points 100 Experience Points
    49443
    Sep 2011
    370
    Thanked
    235 times
    Coby Kyros MID7024
    Thanks, downloading...
  4. #33
    Developer
    Achievements:
    49443
    Sep 2011
    370
    Thanked
    235 times
    Coby Kyros MID7024
    The offsets for the 9742 are exactly the same as the 7042.
    Can you do a full dump with the script here?
    http://www.androidtablets.net/forum/...tml#post205970
    I just need the .img files this time, you can skip system.tgz since I already have it.
  5. #34
    111833
    May 2012
    SpaceStation, Space
    66
    Thanked
    56 times
    @steev
    Are you asking me to download the fw_dump2.zip file and run the .bat file?
    `I tried and that process failed.
    * daemon started successfully *
    mkdir failed for /sdcard/dump, File exists
    Dumping bootloader...
    /system/bin/sh: su: not found
    Dumping boot...
    Dumping recovery...
    Dumping system...
    Pulling files...
    A subdirectory or file dump already exists.
    pull: building file list...
    0 files pulled. 0 files skipped.
    Finished
    Press any key to continue . . .
  6. #35
    Developer
    Achievements:
    49443
    Sep 2011
    370
    Thanked
    235 times
    Coby Kyros MID7024
    Sorry, you must run the root.bat script here first, then run the fw_dump2 script afterwards.
  7. #36
    111833
    May 2012
    SpaceStation, Space
    66
    Thanked
    56 times
    @steev
    OK here are the recovery.img / boot.img / bootloader.img / for the MID9742 (Dump Image Files MID9742.zip) (9MB)
    --Tempfiles.net : Download -> Dump-Image-Files-MID9742.zip--
    steev thanked this.
  8. #37
    Developer
    Achievements:
    49443
    Sep 2011
    370
    Thanked
    235 times
    Coby Kyros MID7024
    Got it, thanks.
    That should be everything for the 9742
    RedDeer thanked this.
  9. #38
    31 days registered 250 Experience Points 100 Experience Points 7 days registered
    110455
    Apr 2012
    65
    Thanked
    10 times
    Coby Kyros 7042-4
    and here was the results from that root checker apk
    I rebooted it a few times (since I rooted it)
    root check
    busybox check
  10. #39
    111833
    May 2012
    SpaceStation, Space
    66
    Thanked
    56 times
    @Joe88
    When you run the Root Exporer App, (downloaded from 1moblie.com)
    Look at the Top left corner.
    Do you see both R/o AND r/w ... OR do you only see R/O ?
    Please, always mention your tablet name.
    People viewing this thread have different tablets. So mentioning the name would be helpful.
  11. #40
    Developer
    Achievements:
    49443
    Sep 2011
    370
    Thanked
    235 times
    Coby Kyros MID7024
    root checker is incorrect there.
    Setuid attribute and root user ownership are present, but permission to execute as a non-root user is not present
    Correct permissions for root access should be -rwsr-sr-x root root
    Coby put a line that basically disables root in /init.sun4i.rc:
    Code:
    chmod 6750 /system/xbin/su
    Btw I have removed this line in the restore firmware, so it should be fully rooted.
    Attached Images Attached Images
    Joe88 thanked this.
Ads:
  1. Requesting stock ROM and instructions to unroot Coby Generation 3
    By juandamejia in forum Coby Generation 3
    Last Post: 06-25-2012, 09:24 PM
  2. What does Coby Generation 3 have that Coby Generation 2 doesn't
    By tablethelper in forum Coby Generation 3
    Last Post: 04-29-2012, 03:18 PM
  3. Requesting Coby Kyros MID 8024 Image
    By tiht20 in forum Coby Generation 2
    Last Post: 08-15-2011, 08:04 AM
  4. S7 Firmware Dumps
    By Balcora in forum Huawei Ideos S7 Development
    Last Post: 05-02-2011, 02:15 AM
00 firmware adb dump original.bat
coby 9742 4.0.3.zip
coby firmware upgrade
coby kyros mid7035 firmware
coby kyros mid8042 firmware
coby kyros mid8042 firmware update
firmware adb dump.bat
firmware dumper a10
requesting
requesting firmware dumps from coby generation 3
requesting firmware dumps from coby generation 3 devices
unroot a coby kyros mid1045
Tags for this Thread
