Disclaimer: Due to users continuously bricking their tablets by attempting to use the Livesuite ROM images in this post, the links to those images have been removed. System dumps are unaffected.
I am requesting firmware dumps from Coby Generation 3 (MIDxx42) devices using the Allwinner A10 SoC.
With these I should be able to create firmware restore images to be used for unbricking.
Firmware dump instructions here:
http://www.androidtablets.net/forum/...tml#post205970
Then upload the *.img files and system.tgz you pulled
Coby doesn't provide firmware downloads for these tablets, which is why I'm trying to put these together.
UPDATE:
WARNING:
I have tested these on my Novo 7 Elf tablet which has similar hardware and it worked, but I can't guarantee they work on the Coby tablets since I do not have the hardware to test.
Therefore, I recommend that somebody with an already bricked tablet be the first to try it.
Firmware restore images for Coby Kyros 7042:
It was discovered that Coby is using 2 different touchscreens in the 7042 models, goodix and ft5x_ts.
The firmware below should support both touchscreens:
coby_7042_4.0.3_dual_ts.zip (Thanks David for the dump), Confirmed working by David
The following firmware only supports 7042 models with Goodix touchscreens:
coby_7042_4.0.3.zip (Thanks to Joe88 for providing the dump)
md5: 3c014061580d74c4c6b112204f3deb92
Firmware restore images for Coby Kyros 9742
coby_9742_4.0.3.zip (Thanks to RedDeer for providing the dump), Confirmed working by swalker5906
md5: 71a31c954e164a0bb7f19bbd1a143d7a
Flashing instructions:
- Download LiveSuite, this is the flashing software for A10 devices
- Run LiveSuitePack.exe (a bunch of files will be extracted to the current folder, so best to create a new one)
- Now run livesuite.exe
- Choose "SelectImage"
- Choose the coby_kyros_4.0.3.img
- Now you need to put your device in upgrade mode, to do so:
1. power off the device
2. Press and hold any physical key except the power key on the device(ie, press and hold Vol+ key, still holding in 3 and 4)
3. Connect the tablet to your PC via USB cable
4. Repeatedly press the power button until a popup dialog shows on your computer screen
- Now follow the on-screen instructions
If this works I look forward to seeing some custom ROMs from the Coby community![]()
104Thanks
LinkBack URL
About LinkBacks
