Page 1 of 2 1 2 LastLast
Results 1 to 10 of 13
Thread: USB charging
  1. #1
    Senior Member Achievements:
    1 year registered 1,000 Experience Points 500 Experience Points 3 months registered 31 days registered
    53840
    Sep 2011
    Auckland
    102
    Thanked
    9 times
    Coby 7022
    USB charging
    Hey all
    As some of you who have the new Coby gen3 tablets will have noticed; these tablets support charging through the USB port.
    However, you may not have realised that charging through the USB port is not as fast as using the mains adaptor. After checking the estimated charging time with my 9742 connected to USB and then the mains adaptor, I found that the charge time was roughly double for USB charging.
    I also found that having the USB cable connected to a 1A adaptor while the mains charger was plugged in also did not affect charging time.
    Based on this I think we can safely assume that these tablets (at least some of the gen3) have a proper charging circuit with current limiting (at least on the USB port, I tried an iPad charger as well) that suggests to me that we can safely use mains adaptors with higher current ratings than standard.
    Ads
    Advertising world
  3. #2
    31 days registered 250 Experience Points 100 Experience Points 7 days registered
    110455
    Apr 2012
    65
    Thanked
    10 times
    Coby Kyros 7042-4
    the more amperage you provide the faster it will charge
    its just a limitation of usb though
  4. #3
    53840
    Sep 2011
    Auckland
    102
    Thanked
    9 times
    Coby 7022
    Quote Originally Posted by Joe88 View Post
    Actually, I've tested this fairly thoroughly. A 2A mains USB charger is giving the same charging time as a 1A mains USB charger.
    This means the current is being limited by the tablet; if it wasn't there would be a difference in the charging times.
  5. #4
    Developer
    Points: 22,923, Level: 93
    Level completed: 58%, Points required for next Level: 427
    Overall activity: 63.0%
    Achievements:
    Recommendation Second Class 10,000 Experience Points 5,000 Experience Points 1 year registered 1,000 Experience Points
    61306
    Nov 2011
    Huntington WV
    3,665
    Thanked
    1369 times
    Points
    22,923
    Level
    93
    Coby 7065, Coby 8042, Coby 9740, Lenovo A2109
    Are you suggesting that the software controls the speed at which the tablet charges via USB? Or is this determined via hardware? If via software we could possibly change this setting.
  6. #5
    53840
    Sep 2011
    Auckland
    102
    Thanked
    9 times
    Coby 7022
    Quote Originally Posted by vampirefo. View Post
    I suspect we have a piece of hardware (e.g. a FET of some kind) controlling the amount of current going through the USB port. I've started using a home-made USB-DC charging cable and I've found that there is a significant difference in the charging rate between this and the standard mini-USB cable off the same powered hub.
  7. #6
    500 Experience Points 3 months registered 250 Experience Points 31 days registered 100 Experience Points
    115428
    May 2012
    100
    Thanked
    15 times
    The amount of charge you will get coming from say a computer usb port, and that of a ac dc adapter charger is going to be much different. I have a NiMH battery recharger and on it is also a usb port to charge devices. Since its never going to host a device, just charge one (or possibly multiple with a daisy chain) it kicks out more juice, and therefore charges my tablet quick then say hooking it up to my desktop. Is this what your talking about? Other then that there is a limit on the amount a usb port can take and therefore pass it on to the battery. The leads between the dc charger and the battery are thicker, and can handle more.
  8. #7
    53840
    Sep 2011
    Auckland
    102
    Thanked
    9 times
    Coby 7022
    Quote Originally Posted by ziggyzag View Post
    You need to look at the current output that specific USB port is capable of providing; the original USB standard (1.0/1.1/2.0) is for 500mA (900mA for USB 3.0).
    However with devices like the iPad and Galaxy Tab charging from USB, it is not uncommon to see USB ports capable of providing current up to 2.1A.
    Additionally, when using a device such as a powered USB hub, it is common to be able to draw up to the full current rating of the connected power supply.
    TLDR version: Charging off a USB port is limited by:
    1. How much current (Amps or mA) the USB port can provide.
    2. The maximum charging rate of the device.
    The point I was trying to make before, was that while these tablets can charge off of USB there seems to be something in the circuitry which limits the charging rate through the USB port that is not present on the DC socket.
    As far as how fast your battery charger can charge a tablet, look for an mA rating for the USB port, I'm guessing it will be either 1A or 500mA. At this level of current wire thickness is more about durability than current capacity.
  9. #8
    Points: 15,693, Level: 80
    Level completed: 69%, Points required for next Level: 157
    Overall activity: 5.0%
    Achievements:
    10,000 Experience Points 1 year registered 5,000 Experience Points 3 months registered 1,000 Experience Points
    117131
    May 2012
    California
    473
    Thanked
    42 times
    Points
    15,693
    Level
    80
    Nexus 7, iDeaUSA CT702/YG A777
    Quote Originally Posted by subtotal View Post
    I was going to ask this exact question for other tablet manufacturers, and looks like I got my answer here for the Coby!
    Does Android indicate the status as "Charging" when you charge via USB?
    See results for my tablet here: Charging tablet via USB
    Some manufacturers log the charging current in the Android logcat: see http://www.droidforums.net/forum/sho....php?p=1312534 for the Motorola DroidX Smartphone.
  10. #9
    53840
    Sep 2011
    Auckland
    102
    Thanked
    9 times
    Coby 7022
    When connected to USB the battery icon on the status bar shows the 'charging' animation.
    Also for the record, I used the app ZDbox (needs to be sideloaded but works fine) to gauge charging rate through charge time.
    If anyone knows of an app that displays charge current, let me know and I will repeat the experiment using that.
  11. #10
    131797
    Jul 2012
    hull
    arnova 7G2
    help:)
    my android tablet, (arnova 7G2) will not charge. is there any other way to charge it apart from using the main charger???
Ads:
  1. USB Charging
    By Joe88 in forum Coby Tablet Accessories
    Last Post: 05-17-2012, 03:37 AM
  2. Charging
    By james44 in forum New Member Introduction & Site Assistance
    Last Post: 04-19-2012, 11:34 PM
  3. Use while charging?
    By hru in forum Viewsonic gTablet
    Last Post: 04-19-2012, 06:00 PM
  4. car charging..?
    By rosystreasures in forum Archos Tablets
    Last Post: 02-09-2012, 03:37 PM
  5. Not Charging
    By britinva in forum Samsung Galaxy Tab 10.1
    Last Post: 08-19-2011, 09:17 PM
can we charge tablet using usb port
can you charge hkc tablet with usb
can you charge hkc with a usb cable
charge polaroid tablets thur computer usb ports
hkc tablet charger
hkc tablet where do i charge
how to charge hkc tablet
is there animation on a colby tablet when charging?
mains
usb charger for hkc 7774a
usb charging tablet app
will a tablet charge on a usb port on a car charger
