Results 1 to 10 of 10
Thanks Tree2Thanks
  • 1 Post By leeshor
  • 1 Post By delbarto
Thread: 9042 Wifi Issues
  1. #1
    Junior Member Achievements:
    31 days registered 3 months registered 100 Experience Points 250 Experience Points 500 Experience Points
    43239
    Jul 2011
    USA
    Kyros 9042-8
    9042 Wifi Issues
    Hello. I owned a 7022 for about 8 months before it died. I had purchased a TRU warranty so decided to put that towards a new ICS tablet from Coby. Figured I'd give them one more try.
    I was excited to purchase the MID9042-8 (until I saw that there's a 10.1" 16x10 version, grrrr....). I've had it for about 2 weeks and so far the only thing that's got me frustrated is the Wifi. Right now it's showing the following:
    Status: Connected
    Signal Strength: Excellent
    Link Speed: 58Mbps
    Security: WPA2 PSK
    IP address: *****
    However it's showing "Amazon.com might be temporarily unavailable". REALLY??? Even as I use my laptop to access androidtablets.net the 9042 shows the site as unavailable. So far everything else with this tablet I like. But if I can't surf the internet then why bother.
    Has anyone else had Wifi issues with their 3rd Gen Coby tablets? Should I send this back to Amazon for credit or try out another one? I've never rooted anything (just did the GooglePlay hack on the 7022) but could that help with the Wifi?
    Thanks in advance for any input.
    Ads
    Advertising world
  3. #2
    Super Moderator
    Points: 18,859, Level: 87
    Level completed: 2%, Points required for next Level: 491
    Overall activity: 99.9%
    Achievements:
    Recommendation First Class 10,000 Experience Points Recommendation Second Class 1 year registered 5,000 Experience Points
    Awards:
    Frequent Poster
    77592
    Dec 2011
    Norcross, GA
    4,448
    Thanked
    842 times
    Points
    18,859
    Level
    87
    Transformer Prime & TF700
    If you can't access anything on the Internet the problem may be security related in your router, firewall etc, or possibly a DNS issue.
    The first thing I would do would be to power down your router for at least 30 seconds then power up and restart your tablet.
    If you long press the WiFi connection you can go to advanced and input fixed information in the settings including DNS. My suggestion is that you use 8.8.8.8 and 8.8.4.4 for DNS which is Google's DNS servers. There must be a fairly simple explanation.
    bdub72 thanked this.
    Locked out of your Tablet? - Printing from an Android tablet (or phone) - Connecting to the Internet with no WiFi - Move/copy/cut/paste files to and from your tablet - WiFi connection issues - Getting Flash Player
    TF201 & TF700 (stock) with dock, .
  4. #3
    43239
    Jul 2011
    USA
    Kyros 9042-8
    Hello leeshor. I have no problems accessing my wifi with my phone, netbook and laptop (and 7022 when I had it).
    I long pressed the wifi connection on the tablet to look for the DNS. I did use this function to post what I posted originally (status, signal, speed, etc). I do not see DNS listed. Is this something I would fix on the tablet or wifi router?
    Thanks.
  5. #4
    Super Moderator
    Achievements:
    Awards:
    Frequent Poster
    77592
    Dec 2011
    Norcross, GA
    4,448
    Thanked
    842 times
    Points
    18,859
    Level
    87
    Quote Originally Posted by bdub72 View Post
    Thanks.
    It's something you would normally see in the WiFi connection, advanced, but it may not appear in some tablets or versions of the Android OS. Your router should be issuing DNS information to the tablet under normal circumstances but based on your original description it sounded like that wasn't happening. Another thing you might try is that long press on the connection and tell it to forget then connect again.
  6. #5
    Developer
    Points: 22,935, Level: 93
    Level completed: 59%, Points required for next Level: 415
    Overall activity: 66.0%
    Achievements:
    Recommendation Second Class 10,000 Experience Points 5,000 Experience Points 1 year registered 1,000 Experience Points
    61306
    Nov 2011
    Huntington WV
    3,665
    Thanked
    1369 times
    Points
    22,935
    Level
    93
    Coby 7065, Coby 8042, Coby 9740, Lenovo A2109
    To change DNS you need to set wifi to static, then you can set what ever DNS you want.
  7. #6
    250 Experience Points 500 Experience Points 3 months registered 7 days registered 31 days registered
    139095
    Aug 2012
    California
    Thanked
    2 times
    coby kyros mid9042-8
    having a similar issue, took a mid9042-8 running ice cream sandwich fresh out of the box today and cannot get it to connect to the home network
    you can see the network available, and some of my neighbors but when we tried to connect that looks like it is connecting but then it keeps going from "saved, secured with WPA2" to "not in range" and we cannot get away from this.
    when we press the icon in the top right-hand corner which looks like three vertical dots it shows an advanced button, when this is pressed it displays network notifications, keep WiFi on during sleep, mac address and IP address which is displaying unavailable
    now I haven't been anywhere yet to try it on a different WiFi signal , and we have not been able to get a WiFi signal icon on the device down by the clock, but the things we have tried are the following.
    changing network channel/frequency in the router
    disabling network security (temporarily) in the router
    returning the device to the factory default setting
    disabling re-enabling WiFi on the device multiple times
    resetting router both through accessing the software and disconnecting from the power
    powering down device and rebooting device multiple times
    we also switched the wireless mode from 802.11 b/g to 802.11 b & 802.11 g individually
    I have seen some suggestions about changing DNS , but I imagine this would only apply if we could actually make a connection to the network, but then could still not access the Internet, please correct me if I am wrong (i.e. we can connect to the network but when we tried to go to Google and were still unable to).
    I have also seen suggestions to change DHCP to static , I can find the settings in the advanced section for the network connection, it allows me to change them to static, but I'm not sure what to do with the rest of the fields which I assume is to make a manual connection, here is where we can also find the DNS which is set to 8.8.8.8 and 8.8.4.4 but without filling out the rest of the information there is no confirmation button, if somebody could give me instructions on where to get the information for each particular field, maybe this would be a solution as the automatic process keeps displaying unavailable for the IP address as mentioned above.
    I think I have covered pretty much everything, any suggestions would be grateful but please provide clear instructions on how to do the things you suggest (unless of course it's just something very simple standard) and if any more information is required for me, please ask.
    Thank You
    delbarto
    I will try to test the device on a different network as soon as possible.
  8. #7
    139095
    Aug 2012
    California
    Thanked
    2 times
    have since been able to try a manual config with the help of a friend, but still the same problem, I go to connect, it displays the network, the signal strength is high, it looks like it is connecting, then it says "out of range"
    very frustrating
  9. #8
    138301
    Aug 2012
    7
    MID1042
    I changed the channel in the router and...solved, for me
  10. #9
    3 months registered 250 Experience Points 100 Experience Points 31 days registered 7 days registered
    146851
    Oct 2012
    Annapolis MD
    7
    Thanked
    2 times
    Coby MID9042
    Quote Originally Posted by caproby View Post
    Changing the router to channel 1 solved the problem for me also.
  11. #10
    139095
    Aug 2012
    California
    Thanked
    2 times
    Quote Originally Posted by MWalter View Post
    Confirmed! Changing to channel 1 finally worked!
    previously I had tried changing to 7 different channels randomly without systematically trying every single one, and I thought I had tried pretty much everything feasible within my computer capabilities of which I actually gained more looking into this, happy me, happy wife, it is her tablet
    thank you very much MWalter!
    1823 thanked this.
Ads:
  1. Mid help wifi issues
    By Anayaangel in forum Android Tablet Q&A
    Last Post: 02-29-2012, 01:42 PM
  2. Wifi Issues
    By inertsoul in forum Honeycomb
    Last Post: 02-22-2012, 01:17 PM
  3. WIFI issues
    By papisongo in forum Honeycomb
    Last Post: 11-06-2011, 04:41 AM
  4. New WIFI ISSUES
    By myzoo in forum Viewsonic gTablet Technical
    Last Post: 10-04-2011, 09:11 AM
  5. Wifi signal issues.
    By LordBane00 in forum Coby Tablets
    Last Post: 03-03-2011, 11:58 AM
add coby kyros mid9042 wont connect to wifi
coby android tablet connectivity issues
coby kyros mid9042 wifi not in range
coby kyros mid9042 wifi problems
coby kyros troubleshooting mid 9042
coby kyros wireless out of range
coby mid9042 problems
coby mid9042-8 can't find wifi
coby tablet wifi issues
coby tablet wifi not in range for coby kyros 9042
kyros mid9042 internet connection problems
problems connecting coby tablet to wifi connection
