Page 2 of 5 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 43
Thanks Tree17Thanks
Thread: Play Store crash..Anybody please help..
  1. #11
    Super Moderator
    Points: 12,367, Level: 72
    Level completed: 80%, Points required for next Level: 83
    Overall activity: 76.0%
    Achievements:
    10000 Experience Points 5000 Experience Points Recommendation Second Class 3 months registered 1000 Experience Points
    122577
    Jun 2012
    1,136
    Thanked
    434 times
    Points
    12,367
    Level
    72
    Coby Kyros MID9742, Dell Streak 5
    Considering I wrote the batch file I highly doubt it's going to say anything except "ClockworkMod Recovery Installed". If, however, CWM is already installed, the two finger salute (hold down Volume - and Power) should get you into ClockworkMod so you can install the Google apps. The reboot recovery command in the batch file is for some reason not being cooperative.
    manekineko thanked this.
    I do not accept PMs asking for one-on-one tech support. Ask on the forums so everyone can benefit.
    Q: Why does an App say it's not compatible on Google's Play Store?
    A: The build.prop is faulty and files are missing from \system\etc\permissions. Download the file from here and install it.
    Q: Why does Google Earth refuse to start on stock ROMs?
    A: Google Earth expects to be able to pinpoint your location. Read this thread to fix things.
    Ads
  3. #12
    Points: 254, Level: 5
    Level completed: 8%, Points required for next Level: 46
    Overall activity: 20.0%
    Achievements:
    250 Experience Points 7 days registered 100 Experience Points
    155042
    Nov 2012
    35
    Thanked
    4 times
    Points
    254
    Level
    Coby MID8042
    yes i noticed that too. after it was installed, i just used the ''b'' command to reboot my device.
    when is the right time to hold those buttons?
  4. #13
    Super Moderator
    Achievements:
    122577
    Jun 2012
    1,136
    Thanked
    434 times
    Points
    12,367
    Level
    72
    Completely shut down the tablet. Press and hold both buttons until you're in recovery. If it boots normally, try again.
  5. #14
    Achievements:
    155042
    Nov 2012
    35
    Thanked
    4 times
    Points
    254
    Level
    Coby MID8042
    i've been trying over and over and over again but i can't pull up the recovery..
    btw, does it have to do something with this?
    CW Recovery v6.0.1.1 for Coby 7042, 8042
    i did not input those commands because i honestly dont know where to type those in and besides, in your installation instructions, you only said there to copy and rename the recovery image. that's what i only did then run the utility.
  6. #15
    Super Moderator
    Achievements:
    122577
    Jun 2012
    1,136
    Thanked
    434 times
    Points
    12,367
    Level
    72
    The sequence may be different for the 8042. Try volume-, power, and back, all held down at the same time. And don't have your AC adapter plugged in when doing this. Plug it in once you're in recovery.
    Now...if you followed my instructions you downloaded CWM, renamed it "cwm_recovery.img" and placed it in the data directory. Then you ran the utility which should have installed CWM.
  7. #16
    Achievements:
    155042
    Nov 2012
    35
    Thanked
    4 times
    Points
    254
    Level
    Coby MID8042
    OMG! i ws able to pull up the recovery and update from zip. i wont go this far without your help, traveller.
    hmmm..do i need to see an icon for Google apps since it's already installed?
    and btw, i went to file manager and it's giving me the error '' SD card empty, unmounted or not present.''
  8. #17
    Super Moderator
    Achievements:
    122577
    Jun 2012
    1,136
    Thanked
    434 times
    Points
    12,367
    Level
    72
    Did you format the card? If so, was it formatted as FAT32 or NTFS?
    If the apps were properly installed, they should appear in the app drawer. If they didn't install, then most likely you DON'T have CWM installed.
  9. #18
    Achievements:
    155042
    Nov 2012
    35
    Thanked
    4 times
    Points
    254
    Level
    Coby MID8042
    yeah i did format the MicroSD before i did anything else..and it's formatted as FAT32.
  10. #19
    Super Moderator
    Achievements:
    122577
    Jun 2012
    1,136
    Thanked
    434 times
    Points
    12,367
    Level
    72
    FAT32 is fine. Android doesn't read NTFS formatted cards, which is why I asked. This means you need to double-check and make sure ClockworkMod is installed as your recovery. After doing that, try installing the Google apps package again.
  11. #20
    Achievements:
    155042
    Nov 2012
    35
    Thanked
    4 times
    Points
    254
    Level
    Coby MID8042
    what's the indication that i already installed CWM?
    this is how it looked like when i boot into recovery and installed the GAPPS package..
    is this correct?
    Traveller1701 thanked this.
Ads:
  1. Play store.
    By Jameel2010 in forum Asus TF300 Forum
    Last Post: 10-08-2012, 12:59 AM
  2. Google Play always Crash
    By dapidc in forum Android Tablet Apps
    Last Post: 09-07-2012, 04:40 AM
  3. Play Store
    By Androidfonefan in forum Lenovo IdeaPad A1
    Last Post: 06-18-2012, 12:19 PM
  4. Android 4.0.3 Crash Google play store
    By 3dcarlos in forum Sony Tablet S
    Last Post: 06-11-2012, 04:22 AM
  5. Replies: 1
    Last Post: 05-25-2012, 03:59 PM
galaxy s3 play store crash
google play always crashes
google play crash
google play store crash s3
google play store crashes s3
play store crash
play store crash s3
play store crashes
play store crashes galaxy s3
playstore crash
playstore crashes
s3 play store crash
Tags for this Thread
