Page 3 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 21 to 30 of 43
Thanks Tree17Thanks
Thread: Play Store crash..Anybody please help..
  1. #21
    Super Moderator
    Points: 12,284, Level: 72
    Level completed: 59%, Points required for next Level: 166
    Overall activity: 77.0%
    Achievements:
    10000 Experience Points 5000 Experience Points Recommendation Second Class 3 months registered 1000 Experience Points
    122577
    Jun 2012
    1,135
    Thanked
    433 times
    Points
    12,284
    Level
    72
    Coby Kyros MID9742, Dell Streak 5
    That's the stock recovery. ClockworkMod recoveries look similar, being based on the stock recovery, but are clearly marked as being ClockworkMod in the lower left corner. Therefore you need to install ClockworkMod recovery.
    manekineko thanked this.
    I do not accept PMs asking for one-on-one tech support. Ask on the forums so everyone can benefit.
    Q: Why does an App say it's not compatible on Google's Play Store?
    A: The build.prop is faulty and files are missing from \system\etc\permissions. Download the file from here and install it.
    Q: Why does Google Earth refuse to start on stock ROMs?
    A: Google Earth expects to be able to pinpoint your location. Read this thread to fix things.
    Ads
  3. #22
    Points: 254, Level: 5
    Level completed: 8%, Points required for next Level: 46
    Overall activity: 20.0%
    Achievements:
    250 Experience Points 7 days registered 100 Experience Points
    155042
    Nov 2012
    35
    Thanked
    4 times
    Points
    254
    Level
    Coby MID8042
    this time i'm sure i have CWM installed properly..
    i renamed the images as "cwm_recover.img.img" and i think that messed it all up..
    phew...but with the GAPSS properly installed, am not sure about that..
Size:  303.9 KBName:  SAM_2946.JPG
    you are a great guide..
    Traveller1701 thanked this.
  4. #23
    Super Moderator
    Achievements:
    122577
    Jun 2012
    1,135
    Thanked
    433 times
    Points
    12,284
    Level
    72
    I might have to add a note about Windows and double extensions, but I'm glad you got it working.
    Enjoy your tablet.
  5. #24
    Achievements:
    155042
    Nov 2012
    35
    Thanked
    4 times
    Points
    254
    Level
    Coby MID8042
    well, thank you so much..!!! i didn't have any idea how to do any of these..goodthing i came across your forum and you helped me through it all the way. I coudn't be thankful enough.
    i'll be looking forward to your updates.
    i want to learn more about this.
    thanks again, traveller!
  6. #25
    Points: 664, Level: 13
    Level completed: 28%, Points required for next Level: 36
    Overall activity: 0%
    Achievements:
    500 Experience Points 3 months registered 31 days registered 250 Experience Points 100 Experience Points
    99467
    Mar 2012
    United States
    21
    Points
    664
    Level
    13
    Coby kyros MID7016
    Hello, Manekineko and welcome to Android Tablets Forum. I will need for you to make sure you have rooted your device. Rooting the device will enable you to expand the device, while running the device as administrator. If you have not rooted the device, do so, if you do not root the device, your device will crash and will erase the OS. Rooting the device will not do this type of action. If your device crashes, you must perform a hard reset, as this problem has happened to me. Please reply on more information on this factor, as I want for everybody to have a great Android experience. For Your Information (FYI), you can also install the Amazon App Store, as well as Google APK files for the application that you are wanting to install/purchase, as you can install free applications that you need to buy, just by googling what you need. Hope you get this issue resolved!
  7. #26
    Super Moderator
    Achievements:
    122577
    Jun 2012
    1,135
    Thanked
    433 times
    Points
    12,284
    Level
    72
    Quote Originally Posted by Russ450 View Post
    Manekineko, I recommend ignoring this post. This poster has an earlier tablet that has or had firmware issues our tablets do not have. Plus, the possibility exists that this is a zombie account.
  8. #27
    Achievements:
    155042
    Nov 2012
    35
    Thanked
    4 times
    Points
    254
    Level
    Coby MID8042
    thanks, traveller. i know whom to trust..
  9. #28
    Achievements:
    155042
    Nov 2012
    35
    Thanked
    4 times
    Points
    254
    Level
    Coby MID8042
    hi traveller..well..it's me again..
    hmmmm...i can't seem to install the GAPPS though CWM said that it's already installed..
    they're not in my apps drawer.
    i followed your instructions to put the GAPPS.zip in the MicroSD and apply update from zip using CWM.
  10. #29
    Super Moderator
    Achievements:
    122577
    Jun 2012
    1,135
    Thanked
    433 times
    Points
    12,284
    Level
    72
    When you rebooted after the install, did you wipe data and caches before rebooting? Also, when you did reboot, was there a prompt about Android updating its files?
    In any case, download the Google apps package again, copy it again, and install it again (choose zip from SDCard, NOT update.zip). Wipe caches. Reboot.
  11. #30
    Achievements:
    155042
    Nov 2012
    35
    Thanked
    4 times
    Points
    254
    Level
    Coby MID8042
    oh..i didn't know those steps..
    i'll try it again..
    ----> i dowloaded the gapps again.copied to sdcard and installed it again...but it's still not there. and there was no prompt that Android is updating..
Ads:
  1. Play store.
    By Jameel2010 in forum Asus TF300 Forum
    Last Post: 10-08-2012, 12:59 AM
  2. Google Play always Crash
    By dapidc in forum Android Tablet Apps
    Last Post: 09-07-2012, 04:40 AM
  3. Play Store
    By Androidfonefan in forum Lenovo IdeaPad A1
    Last Post: 06-18-2012, 12:19 PM
  4. Android 4.0.3 Crash Google play store
    By 3dcarlos in forum Sony Tablet S
    Last Post: 06-11-2012, 04:22 AM
  5. Replies: 1
    Last Post: 05-25-2012, 03:59 PM
galaxy s3 play store crash
google play always crashes
google play crash
google play store crash s3
google play store crashes s3
play store crash
play store crash s3
play store crashes
play store crashes galaxy s3
playstore crash
playstore crashes
s3 play store crash
Tags for this Thread
