Play Store crash..Anybody please help..
hi. i'm new here. i've been reading a lot of stuff here about getting the Google Play up and running. i think i was able to root my tab in the right manner because i already have the Superuser icon after reboot.
but my problem is, i installed the Play Store app (so have the white bag icon here) but it just keeps on crashing everytime i try to open it. like when i tap the icon, it will just show the gray background and ''loading'' for a sec then goes back to the laucher. i already did factory reset (since i still don't have important files to back up yet), then tried to reinstall Play Store, but same thing happens.
please someone shed some light on this matter..
thank you very much in advance!
11-18-2012 12:54 PM
# ADS
Based upon what you have said, you only installed the app itself, and none of the support files. Install the 20120429 complete package from Goo.im Downloads - Browsing gapps using ClockworkMod.
I do not accept PMs asking for one-on-one tech support. Ask on the forums so everyone can benefit.
Q: Why does an App say it's not compatible on Google's Play Store?
A: The build.prop is faulty and files are missing from \system\etc\permissions. Download the file from
here and install it.
Q: Why does Google Earth refuse to start on stock ROMs?
A: Google Earth expects to be able to pinpoint your location. Read
this thread to fix things.
oh i see..
but do i need to flash my tab or something like that? or i'll just install ClockworkMod and download the link you gave to make Play Store running properly..?
thanks for the reply mr. traveller..
Flash your tablet? No. But you do want to uninstall that Play Store app you installed before you install the Google apps package.
Install ClockworkMod using the tools and links provided in the thread titled "READ FIRST - Development Index and Root Utility" found at the top of the Generation 3 Development forum. Make sure you READ IT, not skim it. Then put the Google apps package on your MicroSD card, boot into ClockworkMod, and install the package using the "Update from zip" function in CWM. From there, reboot.
P.S. Skip the "Mr." It's just "Traveller".
ok i'll read it first..
i hope i can do it right this time..
i'll post again once i get it done.
thank you again, traveller..
hi traveller, i went to the post about Google apps package and i believe that the series of numbers listed as the files names are the build numbers, right? unfortunately, i wasnt able to find my Coby's build number which is 20120701. my tab's version is 4.0.3
thanks!
The numbers on the Google apps packages are the dates those packages were built. If you're trying to match the build date of the apps package with the date of the ROM on your tablet it will never happen. In fact, the build date of the files on your tablet means absolutely nothing.
Download the 20120429 Google apps package as I said earlier, and install it.
Originally Posted by
Traveller1701
i saw this right after i posted my last message. sorry about that..
btw, i already have the ff: utility (cobyADB), recovery images (from CW recovery and system dumps), and the Google Apps package.
i did extract the utility, renamed the images and copied them to the ''data'' folder of the utility (cobyADB).
i also copied the GAPPS in the MicroSD.
then what i did is run the adb.exe (which i really dont know if it was correct)
when i run that, it just showed a black screen filling it out with commands then the black screen disappeared.
now i don't know what am missing.
i'm not a technical person but am really trying hard to make this work.
thank you for the patience and quick responses..
they're very much appreciated.
You're making this way too difficult on yourself.
Run "root_recovery.bat".
yes i did that..i also did system dumps, then recovery.
it says ClockworkMod is already installed then proceed to reboot the tab.
but then, nothing new happened..
