Saving in MicroSD
Hi everyone and to our devs.
i want to ask how to save in the MicroSD, especially the apps. I'm running out of internal memory. I just want to clear out from our devs if I need to edit volt.fstab or edit the permissions in platform.xml so that I can install/save using the MicroSD.
thank you so much!
12-01-2012 08:14 AM
# ADS
Generally speaking, without a whole lot of trouble, tablets cannon save apps to SD cards and it was not designed to do that. You may consider using the cloud, Google Drive or DropBox to move some "stuff"
Locked out of your Tablet? -
Printing from an Android tablet (or phone) -
Connecting to the Internet with no WiFi -
Move/copy/cut/paste files to and from your tablet -
WiFi connection issues -
Getting Flash Player
TF201 & TF700 (stock) with dock, .
thank you for that one, leeshor.
if i move the apps or whatever to the MicroSD, are they still readable for the device?
Originally Posted by
manekineko
There's the rub. Without rooting and some serious modifying of the Android OS you can't move them anyway. The primarey reasons are because the SD card is not standard on tablets where it is on most phones, and the naming convention changes from tablet to tablet. If I COULD move them I wouldn't.
I see...though my device is rooted and I have ClockworkMod installed in it, I thought MicroSD in tablets are plug-and-play just like in mobile phones. The internal memory is way too small and that's sad...
WARNING: Editing vold.fstab only works on Coby tablets with an Allwinner CPU. Attempting this modification on tablets running a VI Micro or Telechips CPU will brick the tablet!
Make sure you have a nandroid backup stored somewhere before you do this. You have to edit both platform.xml and vold.fstab.
Edit platform.xml and change the WRITE_EXTERNAL_STORAGE section so it looks like this. If platform.xml isn't edited you won't be able to write to the MicroSD card using an app. Then edit vold.fstab to change the mount points so that /mnt/extsd refers to the internal memory and /mnt/sdcard refers to the MicroSD card.
Reboot the tablet.
I do not accept PMs asking for one-on-one tech support. Ask on the forums so everyone can benefit.
Q: Why does an App say it's not compatible on Google's Play Store?
A: The build.prop is faulty and files are missing from \system\etc\permissions. Download the file from
here and install it.
Q: Why does Google Earth refuse to start on stock ROMs?
A: Google Earth expects to be able to pinpoint your location. Read
this thread to fix things.
thanks for that, traveller!
i already editted the platform.xml like you showed. but how am i going to change volt.fstab..? i tried to interchange the /mnt/sdcard/ and /mnt/extsd/ but after i reboot, they just went back to the same position. what commands will i input there?
It's edited with a text editor on your PC, like notepad++. I believe all you have to do to change the mount points is to change the names; however I'm not 100% sure because changing the mount points is something I have NOT done on my 9742.
Below is a sample. I believe this is all that needs be done, but as I said, I've not tried it myself so make absolutely sure you have a nandroid backup or system dump before doing this.
Code:
# Mounts the first usable partition of the specified device
#/devices/platform/awsmc.3/mmc_host for sdio
dev_mount sdcard /mnt/sdcard auto /devices/platform/sunxi-mmc.1/mmc_host /devices/platform/sunxi-mmc.0/mmc_host
dev_mount extsd /mnt/extsd auto /devices/virtual/block/nandi
dev_mount usbhost1 /mnt/usbhost1 auto /devices/platform/sw-ehci.1 /devices/platform/sw_hcd_host0 /devices/platform/sw-ehci.2
OMG thank you so much for this info, traveller! I ACTUALLY DID IT!!!!
I tried to install a game application, just to make sure that it will save in the MicroSD this time, and it did! I'm so happy about this!
For anyone who wants to have a fully integrated access to MicroSD, here's what I did:
1. I MADE A NANDROID BACK-UP using ClockworkMod. Seriously, if you don't want to struggle restoring your system after every single failed tweak you do in your device, make a back-up. Also, make sure your device is rooted.
2. To get started, I downloaded Notepad++ on my PC at this link. This will be used to edit the mount points in vold.fstab.
3. then, I edited the platform.xml file in system/etc/permissions like this, (just like Traveller1701 said) then save.
4. So since I already have the program (Notepad++) on my PC, I copied the vold.fstab in my MicroSD using root explorer but during this step, I needed to physically unmount the MicroSD out of the device and use a card reader instead. Because when I directly plugged the USB (with vold.fstab in MicroSD), my PC did not recognize the device.
5. I edited vold.fstab (refer to the code above) and saved. I did NOT change the permissions.
6. Mount the MicroSD back to the device.
7. I moved the vold.fstab to system/etc. Overwrite and save.
8. Lastly, I rebooted my device.
So again, MAKE A BACK-UP of your system before you try to do this!!! This worked in my device and I'm hoping this will work on yours too.
Thanks to Traveller!
It's all YOUR fault! Because of you I'm actually thinking of changing my mount points.
I'm glad it's working. Just one thing though; you might want to edit your post and mention downloading notepad++ before editing platform.xml, as regular notepad will screw up the formatting of the file. Also, did you change the permissions on vold.fstab after copying? If so, you might want to mention that as well.
