Page 2 of 5 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 43
Thanks Tree1Thanks
Thread: Other Solution to Remount Internal SD?
  1. #11
    Points: 3,779, Level: 38
    Level completed: 86%, Points required for next Level: 21
    Overall activity: 0%
    Achievements:
    3 months registered 31 days registered 1000 Experience Points 7 days registered 500 Experience Points
    157518
    Dec 2012
    Philippines
    129
    Thanked
    5 times
    Points
    3,779
    Level
    38
    Coby Kyros Mid7048
    what's next? :/
    Ads
    Advertising world
  3. #12
    Developer
    Points: 13,536, Level: 75
    Level completed: 72%, Points required for next Level: 114
    Overall activity: 65.0%
    Achievements:
    Recommendation Second Class 10000 Experience Points 5000 Experience Points 1 year registered 1000 Experience Points
    61306
    Nov 2011
    Huntington WV
    2,429
    Thanked
    806 times
    Points
    13,536
    Level
    75
    Coby 7042, Coby 8042, Lenovo A2109
    why are you typing commands like that?
    please stop, i never told you to type a command like that.
    adb shell
    su
    busybox mkfs.vfat /dev/block/ndda1
    why is it so hard for you?
    adb shell press enter
    su press enter
    busybox mkfs.vfat /dev/block/ndda1 press enter
    each and every command has it's own line stop putting the commands together.
    If you like my work buy me a coffee!!!
    Donations Appreciated
    Due to the overwhelming PM's that I receive, I am unable to answer all the questions and many questions are duplicates so PLEASE post all questions on this forum so I may better help you and any others who are having the same issues.
    No PM's regarding windows questions will be answered, I am a Linux Guy.
  4. #13
    Super Moderator
    Points: 12,000, Level: 71
    Level completed: 88%, Points required for next Level: 50
    Overall activity: 78.0%
    Achievements:
    10000 Experience Points 5000 Experience Points Recommendation Second Class 3 months registered 1000 Experience Points
    122577
    Jun 2012
    1,111
    Thanked
    422 times
    Points
    12,000
    Level
    71
    Coby Kyros MID9742, Dell Streak 5
    What's interesting here is that other than the missing space in the mkfs command he did it right the first time. So why did he not refer to his previous post when running the commands?
    I do not accept PMs asking for one-on-one tech support. Ask on the forums so everyone can benefit.
    Q: Why does an App say it's not compatible on Google's Play Store?
    A: The build.prop is faulty and files are missing from \system\etc\permissions. Download the file from here and install it.
    Q: Why does Google Earth refuse to start on stock ROMs?
    A: Google Earth expects to be able to pinpoint your location. Read this thread to fix things.
  5. #14
    Points: 149, Level: 2
    Level completed: 98%, Points required for next Level: 1
    Overall activity: 17.0%
    Achievements:
    31 days registered 100 Experience Points 7 days registered Tagger Second Class
    160534
    Dec 2012
    quito
    17
    Thanked
    1 times
    Points
    149
    Level
    coby MID7048-4
    Quote Originally Posted by Traveller1701 View Post
    your problem were solved ?????
  6. #15
    Super Moderator
    Achievements:
    122577
    Jun 2012
    1,111
    Thanked
    422 times
    Points
    12,000
    Level
    71
    You mean the OP's problems? Keep in mind for the future that if you quote someone in a post it's assumed you're talking directly to them.
  7. #16
    Achievements:
    160534
    Dec 2012
    quito
    17
    Thanked
    1 times
    Points
    149
    Level
    coby MID7048-4
    I mean that if the problem of your tablet were solved with the method of vampirefo tells you
  8. #17
    Achievements:
    157518
    Dec 2012
    Philippines
    129
    Thanked
    5 times
    Points
    3,779
    Level
    38
    Coby Kyros Mid7048
    su press enter
    and i try another output
    su press enter
    busybox mkfs.vfat/dev/block/ndda1 press enter
  9. #18
    Achievements:
    157518
    Dec 2012
    Philippines
    129
    Thanked
    5 times
    Points
    3,779
    Level
    38
    Coby Kyros Mid7048
    i can't delete the $ and # then i just type the codes
  10. #19
    Developer
    Achievements:
    61306
    Nov 2011
    Huntington WV
    2,429
    Thanked
    806 times
    Points
    13,536
    Level
    75
    Ok that's it, nothing can be done, your /dev/block/ndda1 is completely gone. There is no tool that I know of that can create partitions on the Coby telechips tablets.
    Had the partition just been damaged the above command would have fixed it, but seeing the partition is completely gone there is no command to fix that.
  11. #20
    Developer
    Achievements:
    61306
    Nov 2011
    Huntington WV
    2,429
    Thanked
    806 times
    Points
    13,536
    Level
    75
    Quote Originally Posted by thehandofdoom View Post
    If your partition is completely gone these commands wont help you either. they only work if the partition exist.
Ads:
  1. How to Remount SD Internal?
    By acidburn23 in forum Coby Generation 3 Technical
    Last Post: 04-03-2013, 04:08 PM
  2. Replies: 3
    Last Post: 07-06-2012, 10:43 AM
  3. Internal, internal SD and external SD space on Lenovo A1
    By imageincdave in forum Lenovo IdeaPad A1
    Last Post: 06-02-2012, 06:48 AM
  4. In need of a solution
    By MrJim in forum Android Tablet Q&A
    Last Post: 11-29-2011, 07:42 PM
  5. In need of a solution
    By MrJim in forum New Member Introduction & Site Assistance
a2109 vold.fstab
adb shell su busybox mkfs.vfat /dev/block/ndda1 reboot
android mkdir ndda1
android remount sd
android tablet remount sd card
coby tablet error message sd card not present
remount internal sd android fix
remount sd
sd remount
size internal sdcard coby 7048
vold.fstab lenovo a2109
