Page 3 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 21 to 30 of 43
Thanks Tree1Thanks
Thread: Other Solution to Remount Internal SD?
  1. #21
    Points: 3,866, Level: 39
    Level completed: 44%, Points required for next Level: 84
    Overall activity: 0%
    Achievements:
    3 months registered 31 days registered 1000 Experience Points 7 days registered 500 Experience Points
    157518
    Dec 2012
    Philippines
    130
    Thanked
    5 times
    Points
    3,866
    Level
    39
    Coby Kyros Mid7048
    and i try this codes from traveller in my other thread and this is the output of my device
    adb shell
    su
    busybox df -h
    Ads
    Advertising world
  3. #22
    Developer
    Points: 13,819, Level: 76
    Level completed: 43%, Points required for next Level: 231
    Overall activity: 99.9%
    Achievements:
    Recommendation Second Class 10000 Experience Points 5000 Experience Points 1 year registered 1000 Experience Points
    Awards:
    Activity Award
    61306
    Nov 2011
    Huntington WV
    2,479
    Thanked
    828 times
    Points
    13,819
    Level
    76
    Coby 9740, Coby 8042, Lenovo A2109
    Yes that shows you don't have an internal sdcard mounted, doesn't help in your case.
    If you like my work buy me a coffee!!!
    Donations Appreciated
    Due to the overwhelming PM's that I receive, I am unable to answer all the questions and many questions are duplicates so PLEASE post all questions on this forum so I may better help you and any others who are having the same issues.
    No PM's regarding windows questions will be answered, I am a Linux Guy.
  4. #23
    Achievements:
    157518
    Dec 2012
    Philippines
    130
    Thanked
    5 times
    Points
    3,866
    Level
    39
    Coby Kyros Mid7048
    Lols it seems there's no solution to fix this problem? if there's a firmware of this and reflash via Live suite you think it will be fix or not?
  5. #24
    Developer
    Achievements:
    Awards:
    Activity Award
    61306
    Nov 2011
    Huntington WV
    2,479
    Thanked
    828 times
    Points
    13,819
    Level
    76
    no, telechips can't use livesuite, there is nothing that can repartition your device, unless Coby decides to release a tool to do it.
  6. #25
    Achievements:
    157518
    Dec 2012
    Philippines
    130
    Thanked
    5 times
    Points
    3,866
    Level
    39
    Coby Kyros Mid7048
    and i installed the custom rom 8048 that you post i try it then the internal sd card said insert for a mount? i installed it last year
  7. #26
    Super Moderator
    Points: 12,284, Level: 72
    Level completed: 59%, Points required for next Level: 166
    Overall activity: 77.0%
    Achievements:
    10000 Experience Points 5000 Experience Points Recommendation Second Class 3 months registered 1000 Experience Points
    122577
    Jun 2012
    1,135
    Thanked
    433 times
    Points
    12,284
    Level
    72
    Coby Kyros MID9742, Dell Streak 5
    Quote Originally Posted by thehandofdoom View Post
    I mean that if the problem of your tablet were solved with the method of vampirefo tells you
    I'm not the one you should be asking that question to since I don't have a problem with my tablet. Apparently, I didn't understand the intent behind the question so.... :S
    I do not accept PMs asking for one-on-one tech support. Ask on the forums so everyone can benefit.
    Q: Why does an App say it's not compatible on Google's Play Store?
    A: The build.prop is faulty and files are missing from \system\etc\permissions. Download the file from here and install it.
    Q: Why does Google Earth refuse to start on stock ROMs?
    A: Google Earth expects to be able to pinpoint your location. Read this thread to fix things.
  8. #27
    Points: 149, Level: 2
    Level completed: 98%, Points required for next Level: 1
    Overall activity: 17.0%
    Achievements:
    31 days registered 100 Experience Points 7 days registered Tagger Second Class
    160534
    Dec 2012
    quito
    17
    Thanked
    1 times
    Points
    149
    Level
    coby MID7048-4
    when i tried to put busybox in the line of the shell.....Name:  andro.jpg
Size:  45.4 KB says me that busybox not found
  9. #28
    Developer
    Achievements:
    Awards:
    Activity Award
    61306
    Nov 2011
    Huntington WV
    2,479
    Thanked
    828 times
    Points
    13,819
    Level
    76
    You don't have busybox installed, you need to install busybox.
  10. #29
    Achievements:
    160534
    Dec 2012
    quito
    17
    Thanked
    1 times
    Points
    149
    Level
    coby MID7048-4
    Quote Originally Posted by vampirefo. View Post
    how can i install busybox???.......i found that Busybox do you have the right one? but dont say how can i install please hepl me
  11. #30
    Developer
    Achievements:
    Awards:
    Activity Award
    61306
    Nov 2011
    Huntington WV
    2,479
    Thanked
    828 times
    Points
    13,819
    Level
    76
    In the the first post it explains exactly how to install it.
    you can also get busybox from market,
    first run this command, postout.
    adb shell
    su
    chmod 755 /system/bin/busybox
    busybox tar --Usage
Ads:
  1. How to Remount SD Internal?
    By acidburn23 in forum Coby Generation 3 Technical
    Last Post: 04-03-2013, 04:08 PM
  2. Replies: 3
    Last Post: 07-06-2012, 10:43 AM
  3. Internal, internal SD and external SD space on Lenovo A1
    By imageincdave in forum Lenovo IdeaPad A1
    Last Post: 06-02-2012, 06:48 AM
  4. In need of a solution
    By MrJim in forum Android Tablet Q&A
    Last Post: 11-29-2011, 07:42 PM
  5. In need of a solution
    By MrJim in forum New Member Introduction & Site Assistance
a2109 vold.fstab
adb shell su busybox mkfs.vfat /dev/block/ndda1 reboot
android mkdir ndda1
android remount sd
android tablet remount sd card
coby tablet error message sd card not present
internal sd
remount internal sd android fix
remount sd
sd remount
size internal sdcard coby 7048
vold.fstab lenovo a2109
