Page 1 of 5 1 2 3 ... LastLast
Results 1 to 10 of 43
Thanks Tree1Thanks
Thread: Other Solution to Remount Internal SD?
  1. #1
    Points: 3,866, Level: 39
    Level completed: 44%, Points required for next Level: 84
    Overall activity: 0%
    Achievements:
    3 months registered 31 days registered 1000 Experience Points 7 days registered 500 Experience Points
    157518
    Dec 2012
    Philippines
    130
    Thanked
    5 times
    Points
    3,866
    Level
    39
    Coby Kyros Mid7048
    Angry Other Solution to Remount Internal SD?
    hey? is there another solution to remount the internal sd? i'm taking this problem about 2months i cant play other games that saving in sdcard/android/data, and others post the step by step fixing or as much as possible please post a video? thanks :/
    Ads
    Advertising world
  3. #2
    Achievements:
    157518
    Dec 2012
    Philippines
    130
    Thanked
    5 times
    Points
    3,866
    Level
    39
    Coby Kyros Mid7048
    i have still problem this one
  4. #3
    Developer
    Points: 13,744, Level: 76
    Level completed: 24%, Points required for next Level: 306
    Overall activity: 99.9%
    Achievements:
    Recommendation Second Class 10000 Experience Points 5000 Experience Points 1 year registered 1000 Experience Points
    Awards:
    Activity Award
    61306
    Nov 2011
    Huntington WV
    2,474
    Thanked
    827 times
    Points
    13,744
    Level
    76
    Coby 9740, Coby 8042, Lenovo A2109
    Have you changed your vold.fstab back to stocked? I know you had messed with it.
    adb shell
    su
    cat /system/etc/vold.fstab
    post output.
    If you like my work buy me a coffee!!!
    Donations Appreciated
    Due to the overwhelming PM's that I receive, I am unable to answer all the questions and many questions are duplicates so PLEASE post all questions on this forum so I may better help you and any others who are having the same issues.
    No PM's regarding windows questions will be answered, I am a Linux Guy.
  5. #4
    Achievements:
    157518
    Dec 2012
    Philippines
    130
    Thanked
    5 times
    Points
    3,866
    Level
    39
    Coby Kyros Mid7048
    #External NAND Storage
    dev_mount sdcard / mnt/sd card auto / devices/virtual/block/ndda
    #External SD card
    dev_mount ext_sd / mnt/ext_sd auto/ devices/platform/tcc-sdhc
    this is my ouput, i have this problem started last year
  6. #5
    Achievements:
    157518
    Dec 2012
    Philippines
    130
    Thanked
    5 times
    Points
    3,866
    Level
    39
    Coby Kyros Mid7048
    i try to restore the device using stock rom that you gave to me via CWM then if i mount the nand in CWM the below said error?
  7. #6
    Developer
    Achievements:
    Awards:
    Activity Award
    61306
    Nov 2011
    Huntington WV
    2,474
    Thanked
    827 times
    Points
    13,744
    Level
    76
    Quote Originally Posted by acidburn23 View Post
    The rom wont fix nadd it is to restore system to stock.
    ok to fix your problem this should work, i made it up the other day and tested on my devices worked well, as with any modification it could brick your tablet.
    adb shell
    su
    busybox mkfs.vfat /dev/block/ndda1
    reboot
    if all went well your problem should be fixed.
  8. #7
    Achievements:
    157518
    Dec 2012
    Philippines
    130
    Thanked
    5 times
    Points
    3,866
    Level
    39
    Coby Kyros Mid7048
    what application needed to input that codes? via computer using usb cord? or i will do that thru my tablet?
  9. #8
    Achievements:
    157518
    Dec 2012
    Philippines
    130
    Thanked
    5 times
    Points
    3,866
    Level
    39
    Coby Kyros Mid7048
    like this? Name:  12.JPG
  10. #9
    Developer
    Achievements:
    Awards:
    Activity Award
    61306
    Nov 2011
    Huntington WV
    2,474
    Thanked
    827 times
    Points
    13,744
    Level
    76
    you have to have a space you put it all as one code.
    busybox mkfs.vfat space /dev/block/ndda1
    Code:
  11. #10
    Banned
    Points: 273,394, Level: 100
    Achievements:
    Recommendation First Class Tagger First Class Created Album pictures 50000 Experience Points 25000 Experience Points
    Awards:
    Downloads
    15754
    Jan 2011
    828
    Thanked
    435 times
    Points
    273,394
    Level
    100
    Quote Originally Posted by vampirefo. View Post
    Code:
    This should help you, just do it without the syntax holdback # or whitespace.
    thehandofdoom thanked this.
Ads:
  1. How to Remount SD Internal?
    By acidburn23 in forum Coby Generation 3 Technical
    Last Post: 04-03-2013, 04:08 PM
  2. Replies: 3
    Last Post: 07-06-2012, 10:43 AM
  3. Internal, internal SD and external SD space on Lenovo A1
    By imageincdave in forum Lenovo IdeaPad A1
    Last Post: 06-02-2012, 06:48 AM
  4. In need of a solution
    By MrJim in forum Android Tablet Q&A
    Last Post: 11-29-2011, 07:42 PM
  5. In need of a solution
    By MrJim in forum New Member Introduction & Site Assistance
a2109 vold.fstab
adb shell su busybox mkfs.vfat /dev/block/ndda1 reboot
android mkdir ndda1
android remount sd
android tablet remount sd card
coby tablet error message sd card not present
internal sd
remount internal sd android fix
remount sd
sd remount
size internal sdcard coby 7048
vold.fstab lenovo a2109
