Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
  1. #1
    Junior Member Achievements:
    3 months registered 250 Experience Points 31 days registered 100 Experience Points 7 days registered
    123380
    Jun 2012
    Portugal
    coby kyros mid7042-4
    coby kyros mid7042-4 problem: need your advice
    Hi there guys!
    I have a coby kyros mid7042-4 for about 2 days and I'm testing the tablet... so far it runs angry birds space smoothly, tryed grooveshark app and it worked like a charm. The only thing that is bugging me is that I couldn't get my gmail into the email app that came with this tablet, so I had to use a gmail app (if you can help me with this feel free to share some knowledge).. has I was writing some random e-mail the tablet just freezes and came back to the "desktop". Some times the same happens while I'm browsing random stuff in the internet (i use the browser that came with the tablet).
    I wonder if this is normal in this kind of low budget devices or if it's a software (or hardware) problem, because I can get this one changed by other new tablet in the future 13 days...
    Ads
    Advertising world
  3. #2
    250 Experience Points 3 months registered 31 days registered 100 Experience Points 7 days registered
    122788
    Jun 2012
    21
    Thanked
    1 times
    try to make a factory reset and try again to see if the same problem still exists.
  4. #3
    123380
    Jun 2012
    Portugal
    factory reset = vol down + power, right? i'm doing that and nothing is happening
  5. #4
    122788
    Jun 2012
    21
    Thanked
    1 times
    i dont know a way throught buttons, just go to settings-->backup & reset--> factory data reset
  6. #5
    bvn
    bvn is offline
    121143
    Jun 2012
    Seattle WA USA
    17
    coby mid7042
    There is also a button on the back that can be pressed with a paper clip (page 6 of my manual)
    I'm afraid that confirming the problem with Factory Reset is standard practice.
    --- TTFN
  7. #6
    123380
    Jun 2012
    Portugal
    Guys,
    I did both ways and the problem persists.
    After a factory restore (5x actually) I was able to sign in my gmail account, as I was writing an email... the tablet just froze and went back to desktop. The same happen while browsing some pages.
    What should I do? Is this supposed to be normal in this kind of device?
  8. #7
    122788
    Jun 2012
    21
    Thanked
    1 times
    Return it, i see you are from portugal, me too, have you bought it in worten? you have the right to exchange it, its not working properly, go there and show them what is happening and they give you a new one.
  9. #8
    123380
    Jun 2012
    Portugal
    ty friend, and yes... it was on worten.
    your tablet is ok? or sometimes have this problems?
  10. #9
    122788
    Jun 2012
    21
    Thanked
    1 times
    Quote Originally Posted by xavia View Post
    mine is okay
  11. #10
    Senior Member Achievements:
    500 Experience Points 3 months registered 250 Experience Points 31 days registered 100 Experience Points
    115428
    May 2012
    100
    Thanked
    15 times
    Firstly, you cant use your gmail account with the stock email app, its for things like pop3 imap and microsoft exchange servers. So you need to get the gmail app, the best way of which is to root your tablet and put one of the roms on which have google play installed/ For you I recommend Steevs rooted stock rom, its exactly what you have on the tablet now except its rooted, google play is installed and google location services work. There is a how to in this forum on how to install this using windows. I am currently using vampirefos mobiz rom but I am encountering a laundry list of problems which seem systemic and I cant currently recommend it even with its advantages. From there you can install the gmail app, as well as other apps, like Dolphin web browser or opera. Now the problem with the browers crashing and going back to the desktop is a two part problem. One is it is the problem of the actual browser software, and in the stock browser of the 7042 it is a beta version of Googles Chrome for android. The second problem is with android itself getting fed up to quickly with the browser and therefore killing the process. Usually if im using the browser on a say image intensive page, android will run out of memory and intermittingly bring up a dialog saying it the browser is unresponsive and ask if I want to close it. I have found that opera and dolphin can be more stable with big pages but the stock browser can take advantage of a lot of new html5 enhancements so sometimes its worth it to use. If you do install a rom like steevs I suggest u download the lates gapps (google apps) because it fixes a bug with google search.
Ads:
  1. Thoughts and opinions on the Coby MID7042
    By bvn in forum Coby Generation 3
    Last Post: 07-14-2012, 09:02 AM
  2. COBY MID7042-4 battery life?
    By Joe88 in forum Coby Generation 3
    Last Post: 06-21-2012, 01:13 AM
  3. Charge Status Indicator Light on Coby Kyros MID7042
    By oasiscorpmse in forum Coby Generation 3
    Last Post: 06-21-2012, 01:02 AM
  4. Looking for a Gel Case/Skin for a New Coby MID7042-4
    By noto in forum Coby Tablet Accessories
    Last Post: 05-18-2012, 10:48 PM
  5. coby kyros mid 7120 problem
    By aqil in forum Coby Generation 1
    Last Post: 01-05-2012, 03:50 PM
coby kryos 7042 hard reset
coby kyros mid7042
coby kyros mid7042 hard reset
coby mid7042 hard reset
hard reset coby kryos mid7042
hard reset coby kyros mid7042
hard reset en una tablet coby kyros mid7042
how to factory reset coby kyros mid7042
how to restore coby kyros mid7042
how to root coby kyros mid7042-4
how to unlock coby kyros mid7042
