need help for 9042 tablet.. sir traveller help
gud day.. i knowe this is the right place to answer my questions.. i have a 9042 and have a dump file using ur tutorial about adb method.. and i got 3 files.. boot bootloader and recovery.. after rooting i have run the tablet smoothly.. but when i install the busybox and tick the reboot using busybox reboot menu i got a reboot and stuck on android word "android" although its not freezing there, it cannot continue.. about 5-10 mins displaying that android word.. so i suspected already that there is a problem.. my question is that, how can i use my dump file that infact i cannot access it usb debugging? and there is a way that i can fix it through clockwordmod? coz i can stil access the recovery that is recovery cwm... thank you very much for your reading this...
11-15-2012 06:51 PM
# ADS
Originally Posted by
johnny_luck
All you replaced was busybox?
If you like my work buy me a coffee!!!
Donations Appreciated
Due to the overwhelming PM's that I receive, I am unable to answer all the questions and many questions are duplicates so PLEASE post all questions on this forum so I may better help you and any others who are having the same issues.
No PM's regarding windows questions will be answered, I am a Linux Guy.
yes sir vampire.. i don't uninstall the su.. i just install busybox and try to reboot there.. but it reboot but cannot process with the system..
johnny_luck
Just flash this via cw recovery
9042_busybox.zip
sir vampire, this i got when try to install the zip..
installing: /sdcard/9042_busybox.zip
finding update package...
opening update package...
installing update...
e:error in /sdcard/9042_busybox.zip
(Status 6)
Installation aborted.
by the way sir vampire, i've made already the factory reset...
johnny_luck
(Status 6)
first one got corrupt on upload.
download again 9042_busybox.zip
check md5sum
d70d01964b748224f98d0ce32aeef44f 9042_busybox.zip
sir vampire, i am stucked on the coby logo.. sir, is there any posibilities that i can restore my dump files from adb? all i hve here sir is the boot.img, bootloader.img and recovery.img... is there a big chance i can unbrick my device?
johnny_luck
yes, sounds like you did more than busybox.
what are the names of your backups? exact name
make sure they are on your sdcard.
in cw recovery make sure adb works, then post the names of your backups and I will type required commands.
im sory sir vampire i mean can i restore my adb backup files in cwm? these are my files in the dump files of adb.. boot.img, bootloader.img, and recovery.img thanks for your help sir..
