Results 1 to 2 of 2
  1. #1
    Junior Member Achievements:
    Tagger Second Class
    128962
    Jul 2012
    coby kyros mid7035
    Coby Kyros MID7035 problem
    I have a few books saved to the memory that I put on the device using the USB connect, I have been reading one of them but then today when I went to continue reading it, it was no longer in the list in Aldiko the book reading program my device came with, none of the books I had are there any more. So I tried to connect my device to my computer to see if it was really gone off my device but now it wont connect to my computer. All that happens is that I get the sound on my computer that indicates that a USB device has ben added and my device goes to the "USB connected" page that normally opens up but when I click the"Turn on USB storage" button it just makes the processing round circle simple but never lets me into the device from the computer, and if I tilt the device to change the view thing the "Turn on USB storage" button reappears like it was never pressed in the first place. And if I go into settings and try and click on "storage" it gives me the error message "Unfortunately, Settings has stopped" and closes back to the desktop. I have tried resetting my device back to factory default but that didn't fix any of my problems. The only thing I have used this device for is to download a couple apps like angry birds, read a few books, and surf the web. And it seems that I can still do other things normaly like surff the web and install new apps.
    Ads
  3. #2
    Points: 1,063, Level: 17
    Level completed: 63%, Points required for next Level: 37
    Overall activity: 0%
    Achievements:
    1 year registered 500 Experience Points 1,000 Experience Points 7 days registered 31 days registered
    136989
    Aug 2012
    Argentina
    Points
    1,063
    Level
    17
    Coby Kyros 7033-4
    I have the same issue, and I can't find a solution. Is like It can't mount the internal memory, and neither a sd card.
Ads:
  1. coby kyros mid7042-4 problem: need your advice
    By xavia in forum Coby Generation 3
    Last Post: 09-03-2012, 10:50 PM
  2. tablet novice needs help with new Kyros Coby MID7035-4
    By mathemos in forum Coby Tablets
    Last Post: 07-16-2012, 10:02 AM
  3. How to root Coby Kyros MID7035
    By ng3f in forum Coby Tablets
    Last Post: 07-08-2012, 08:25 AM
  4. Coby Kyros 7015 4GB Wifi Problem
    By keebz in forum Coby Generation 1
    Last Post: 05-25-2012, 01:52 PM
  5. coby kyros mid 7120 problem
    By aqil in forum Coby Generation 1
    Last Post: 01-05-2012, 03:50 PM
coby kyros 7035 will not mount sd card
coby kyros mid 7035 sd card
coby kyros mid7035 problems
coby kyros mid7035-4 undetected by computer
coby mid7035 wifi problem
fix coby kyros mid7035 using image
how to factory reset coby kyros coby mid7035 tablet
hownto fix power on a coby mid7035 ?
kyros mid7035 sd card problem
sd card read problem in coby kyros mid7035
trouble connecting to internet on my 7035 coby android tablet
using sd card memory of coby 7035
Tags for this Thread
