Results 1 to 1 of 1
  1. #1
    Points: 215, Level: 4
    Level completed: 30%, Points required for next Level: 35
    Overall activity: 2.0%
    Achievements:
    7 days registered 31 days registered 100 Experience Points Tagger Second Class
    159900
    Dec 2012
    TN
    7
    Points
    215
    Level
    Coby Kyros 7034
    Help Past Coby Load Screen
    Ok it seems i need to post a new thread to help get this clear. i have a Coby 7036 and its stuck at the coby loading screen, i believe it happened after i edited the vold.fstab file for swapping the internal and external memory. Ive installed GAPPS fine and found a good rooting .zip file that worked great. Once i edited the vold file i started having problems. i tried using the backup and recovery options in the custom CWM that came with the root files. Nothing seems to work or get me past the loading screen. I dont know how to post my system dump files or whatnot or i would. A simple walkthrough for this would be great. Thank you for your assistance.
    Ads
    Advertising world
Ads:
  1. Onda V811 Won't Load Past White Android Symbol
    By Debebjo in forum Onda Tablet Forum
    Last Post: 05-02-2013, 02:38 AM
  2. Cant get nook color to load past "android_" screen (CM7)
    By jealousblues in forum Nook Color Technical
    Last Post: 12-07-2012, 10:24 AM
  3. coby kyros 7022 turns on but wont go past the coby screen
    By nando in forum Coby Generation 2
    Last Post: 08-17-2012, 11:04 AM
  4. Tablet won't load past boot screen
    By thejester in forum Android Tablet Q&A
    Last Post: 06-12-2012, 10:08 PM
  5. Replies: 1
    Last Post: 06-08-2012, 12:25 PM
coby kyros 7034 froze loading screen
coby kyros 7034 frozen screen won't unlock
coby kyros 7036 wont move past android screen on boot
coby kyros tablet wont turn pastandroid screen
coby kyros wont load past coby screen
coby tablet troubleshooting screen won't go past android
coby tablet won't get past startup screen android
coby tablet wont unlock
coby won't get past android screen
colby screen frozen
onda v811 frozen
why won't my kyros tablet load past the colby screen
Tags for this Thread
