Page 1 of 2 1 2 LastLast
Results 1 to 10 of 17
Thanks Tree3Thanks
Thread: [ROM] 'honeycomb' for craig cmp 738a (tweaks, wallpaper, power rooted apps)
  1. #1
    Developer
    Achievements:
    Recommendation Second Class Recommendation First Class 7 days registered 31 days registered 3 months registered
    1423
    Aug 2010
    USA
    1,504
    Thanked
    105 times
    COBY KYROS 7015 | 7015A
    Wink [ROM] 'honeycomb' for craig cmp 738a (tweaks, wallpaper, power rooted apps)
    Honeycomb themed firmware
    This is what I've used on my ROM MODs but they have been ported over to the CRAIG. Instead of making a Rooted ROM which you can with the enclosed package if you need be. But I've given you all you need to make the tablet run as fast as you can get out of it! Enjoy what I enjoy daily. Make the battery last as long as the next day. Free up Memory and Space. (Depends how you set it up). I had rooted mine the old fashion way so that is included but for those who use third-party ROM you can still use this to get some features of of your tablet.
    Use the link below to access the package it will explain more.
    Found here
    The above is called Smart Task Bar there is a trigger to your right of the screen that calls it up anywhere.
    jackrussell, m3red and ArcticWolf thanked this.
    Devices: MID7015-4G | MOD: HoneyComb Hybrid HCV31.0 GB38 with Extreme Power Booster | ROM OS: Rooted Android OS 2.3.1a GingerBread
    Devices: MID7015A-4G | MOD: HoneyComb Hyrbird HCV15.0-B22V with Extreme Power Booster | ROM OS: Rooted Android OS 2.1a Eclair
    Devices: M150A12 | MOD: HoneyComb Hybrid HCV15.0-B22V with Extreme Power Booster | ROM OS: Rooted Android OS 1.6a Donut
    18x Tablets Owned/Tested/Configured/Tweaked: Running OS: 1.6, 2.0, 2.1, 2.2, 2.3 | Since 2010
    Ads
    Advertising world
  3. #2
    Senior Member Achievements:
    7 days registered 31 days registered 3 months registered 1 year registered 100 Experience Points
    5521
    Oct 2010
    RTP, NC, US
    141
    Thanked
    3 times
    Many - mainly Archos 5 IT, several Fujitsu Lifebook "P" models
    Quote Originally Posted by tipstir View Post
    Found here
    Is something missing? All I see is 7z zip file for the Coby. I downloaded and looked through it, but it just looks as though there are wallpapers and apk files meant to give the look of Honeycomb, but not an actual upgrade, or the ability to make " a Rooted ROM which you can with the enclosed package" as you state above. No mention of the Craig in the files in that zip file or anything looking like the sources for a ROM upgrade.
    TIA.
  4. #3
    Developer
    Achievements:
    1423
    Aug 2010
    USA
    1,504
    Thanked
    105 times
    The file was just replaced. Took out the FP file and replaced it with the OC file so you can crank up the CPU. There are 19 files in all. This file is for both COBY AN CRAIG. Z4Root was in the prior but you can't use that on the Craig only the Coby. But I've removed file. Gave FP causing AV to remove the contents. I've scanned the files no more issues. I would download it again. If you need help just post your questions here. Thanks
  5. #4
    Developer
    Achievements:
    1423
    Aug 2010
    USA
    1,504
    Thanked
    105 times
    See the first post..
  6. #5
    Junior Member Achievements:
    7 days registered 31 days registered 3 months registered 100 Experience Points 250 Experience Points
    24495
    Apr 2011
    28
    Craig CMP738a w/Body Glove eReader case (fits perfectly)
    Tipstit, the power pack is very cool. Thanks for providing it.
    One question - does the Flash player run on the Cmp738a? At all?
    Does it require the Froyo ROM?
    Doesn't seem to run on 4.2 eclair, but it did install OK.
    Thanks!
  7. #6
    Developer
    Achievements:
    1423
    Aug 2010
    USA
    1,504
    Thanked
    105 times
    Flash for 2.1 seems to to be flaky. Just have to wait for Craig (rated by BBB (F) by customers) to get around to it releasing OS 2.2. They might not come through, but who knows? Tomorrow I'll be heading to CVS to return mine and see if the new ones are there yet.
  8. #7
    24495
    Apr 2011
    28
    I've been playing with the tools and there are some really good ones there. Thanks for taking the time to assemble them.
    On the Cpuboost, I'm not sure I have it figured out, but I've been using Caffiene mark to test when its working. Any idea how high I can clock this thing?
  9. #8
    Developer
    Achievements:
    1423
    Aug 2010
    USA
    1,504
    Thanked
    105 times
    3 settings: Performance 8xxx for the first one and 6xxx for the second one Set on Boot Enabled. You'll get over 1,667
  10. #9
    Points: 1,608, Level: 23
    Level completed: 8%, Points required for next Level: 92
    Overall activity: 0%
    Achievements:
    1 year registered 1000 Experience Points 500 Experience Points 250 Experience Points 100 Experience Points
    18506
    Feb 2011
    myrtle beach
    40
    Points
    1,608
    Level
    23
    coby kyros 7015a
    craig honeycomb mod
    I was wondering if I would need to start from the stock 2.2 or can I install over the shad 4.3 mod I am currently using .
  11. #10
    Achievements:
    18506
    Feb 2011
    myrtle beach
    40
    Points
    1,608
    Level
    23
    coby kyros 7015a
    hello is there anybody out there
Ads:
  1. Craig CMP 738a Information
    By xaueious in forum Craig Tablets
    Last Post: 12-05-2011, 07:58 AM
  2. Replies: 6
    Last Post: 09-29-2011, 03:37 PM
  3. honeycomb parts for coby kyros (tweaks, wallpaper, power rooted apps)
    By tipstir in forum Coby Generation 1 Technical
    Last Post: 09-28-2011, 08:54 PM
  4. Rooted MID7015 Power Button Problems
    By didema in forum Coby Generation 1
    Last Post: 01-17-2011, 08:27 PM
  5. Replies: 0
    Last Post: 09-15-2010, 04:38 PM
cmp738a
cmp738a apps
cmp738a gingerbread
craig cmp738a
craig cmp738a apps
craig cmp738a honeycomb
craig cmp738a update
get honeycomb on craig tablet
honeycomb rom for cmp738a
how to make craig tablet faster
how to make my craig tablet run faster
Tags for this Thread
