Register Hello & Welcome to Andriodtablets.net, is this your first visit?
[Firmware] Debian v0.3 for Flytouch SD bootable.
This is a discussion on [Firmware] Debian v0.3 for Flytouch SD bootable. within the Gome Flytouch Firmware forums, part of the Gome Flytouch category; Hi all, this time i bring you debian os ready to use on flytouch just copying it to a SD card, so if you dont ...
Results 1 to 8 of 8
  1. #1
    Developer
    Points: 41,400, Level: 100
    Overall activity: 0%
    Achievements:
    Recommendation Second Class Recommendation First Class 7 days registered 31 days registered 3 months registered
    Awards:
    User with most referrers
    1423
    Aug 2010
    USA
    1,504
    Thanked
    89 times
    Points
    41,400
    Level
    100
    COBY KYROS 7015 | 7015A
    Exclamation [Firmware] Debian v0.3 for Flytouch SD bootable.
    Hi all, this time i bring you debian os ready to use on flytouch just copying it to a SD card, so if you dont like just remove the memory, reboot and go back to your android unharm.
    Enjoy, experiment, make it better, share and let me know how it goes.
    Cheers to all!!!!!
    Source Link Download
    This version is a mod from the eken m001 debian v0.3, lets get into bussines:
    What works?
    - Wifi works 100% all you have to do is run the built in config utility.
    - Touchpad it has some flaws, is better if you copy your touchcal config from android to the etc folder on ext2 partition. The axyses are fixed so it doesn't do the mirror thingy that was so annoying anymore. And the responsiveness well i find it better than the android one.
    - Loads with 256MB ram.
    - Autologin as root, so you don't need a keyboard to run the system.
    - Everything else that you expect from a debian Arm device.
    What doesn't work?
    - Hardware buttons has no function.
    - Accelerometer.
    How do i install it?
    First of all, i guess this is a 100% no risk installation. Since it runs directly from the sd card and it does not need to be installed in nand, leaving your filesystem intact.
    For a great installation guide follow this link to the ekens forum and follow the instructions described in step 2: Debian on Eken install quidlines for Windows users.
    NOTE: The first time you start your device it will run fsck and after that will shut down, dont get alarmed, once the device is down you only have to turn it on again and it will work. And always remember to shut it down properly going to terminal and entering "reboot" or else fs will get screwed and you will have to run fsck on a linux machine over ext2 partition of the SD card to fix it.
    notice that some 1gb sd cards are in fact 960mb large so they dont support the full copy of the image in them, leading the firmware to crash on load. (Yes is the experience talking, i was melting my brains with this untill i had the idea to flash a 4gb SD before it works... silly me).
    How does it look?
    Here's some screens of my flytouch with matchbox desktop manager running with debian (no video this time until i get my english better or leave college to get some more extra time, whatever happens the first):
    Problems Booting
    Bounty Working Debian Touchscreen driver
    Devices: MID7015-4G | MOD: HoneyComb Hybrid HCV31.0 GB38 with Extreme Power Booster | ROM OS: Rooted Android OS 2.3.1a GingerBread
    Devices: MID7015A-4G | MOD: HoneyComb Hyrbird HCV15.0-B22V with Extreme Power Booster | ROM OS: Rooted Android OS 2.1a Eclair
    Devices: M150A12 | MOD: HoneyComb Hybrid HCV15.0-B22V with Extreme Power Booster | ROM OS: Rooted Android OS 1.6a Donut
    18x Tablets Owned/Tested/Configured/Tweaked: Running OS: 1.6, 2.0, 2.1, 2.2, 2.3 | Since 2010
    Advertising world
  3. #2
    Junior Member Achievements:
    7 days registered 31 days registered 3 months registered 100 Experience Points 250 Experience Points
    14181
    Jan 2011
    Denmark
    7" China Clone
    How do I "burn" this image to the sd card?
    Update: Never mind I got it all figured out days ago
  4. #3
    28091
    Apr 2011
    The Netherlands
    Wondermedia WM8650
    im downloading now, lets see if it works... i'll keep you updated!
    update: wait im using 265MB SD card... oh well lets try!
  5. #4
    Points: 763, Level: 14
    Level completed: 63%, Points required for next Level: 37
    Overall activity: 0.7%
    Achievements:
    16030
    Jan 2011
    Luzerne, PA
    15
    Thanked
    1 times
    Points
    763
    Level
    14
    FlyTouch 2
    Tuxor,
    How did you get the .img to burn to the sd? I'm using linux and tried the dd command from a terminal. Looks like I ended up with a 900+ meg file system. Install the tf back in the flytouch II and rebooted. But, I got nothing.
    Is there something I am missing to make the Flytouch boot of the sd card ?
    Thanks,
    Brian
  6. #5
    26402
    Apr 2011
    Saudi Arabia
    Sawee pad
    OK, I give up...I also tried to burn the image using dd and using winhex. Pad will not boot from the SD card.
  7. #6
    Achievements:
    16030
    Jan 2011
    Luzerne, PA
    15
    Thanked
    1 times
    Points
    763
    Level
    14
    FlyTouch 2
    Esmsabir,
    i'm with you. this if my first attempt to boot from a sd card and I have had NO LUCK at all. I was thinking I was doing something wrong.
    Tipstir, is there something we might be missing?
    Brian
  8. #7
    7 days registered
    46438
    Aug 2011
    France
    Flytouch 3
    Flytouch 3 ???
    Hi everybody.
    And thank you Tipstir for you tuto..!
    But... I have a problem. I did everything as said, my SD Card is ok, debian inside, but I'm unable to boot from the SD on my Flytouch 3 !!
    Did I miss something ?
    Thank for answering.
    Friendly,
    Chris
  9. #8
    Points: 19, Level: 1
    Level completed: 37%, Points required for next Level: 31
    94242
    Feb 2012
    Points
    19
    Level
    china
    Please, somebody, reupload the firmware.
Sponsors:
  1. [ROM] Gome Flytouch Firmware Releases (VIA8505 7" Tablet)
    By xaueious in forum Gome Flytouch Firmware
    Last Post: 06-10-2011, 03:35 AM
  2. Hands-On Videos with Gome Flytouch
    By tipstir in forum Gome Flytouch
    Last Post: 08-30-2010, 02:47 PM
  3. Rooted Gome Flytouch
    Last Post: 08-30-2010, 01:29 AM
  4. Flytouch Screen Shots
    Last Post: 08-29-2010, 11:10 PM
  5. Generic Flytouch problem
    By allyndnoir in forum Gome Flytouch Problems
    Last Post: 08-17-2010, 01:38 PM
android tablet debian
debian flytouch
debian on flytouch
debian tablet
debian-m001
flytouch 3 debian
flytouch 3 firmware
flytouch 3 linux
flytouch debian
flytouch firmware
linux flytouch
linux on flytouch 3
Copyright © 2012 vBulletin Solutions, Inc. All rights reserved.
