Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
  1. #1
    Developer
    Achievements:
    50,000 Experience Points 25,000 Experience Points 10,000 Experience Points 5,000 Experience Points 1,000 Experience Points
    1423
    Aug 2010
    USA
    1,505
    Thanked
    109 times
    COBY KYROS 7015 | 7015A
    Exclamation Latest Releases in Rooted ROM for WM2.20 (Custom Build) 3 Versions
    Build number by me my own custom build number.This is the latest techniques and methods for those who use the older WM8505 or had Build 1.7.4, 1.8.2, or 1.9_88 would use this build. Also replaces the Xtreme, Xtreme Plus and Deluxe ROM.
    PowerCode 1000 DCX
    Coby Kyros 7012, 7015, 7015a, 7016, 7022, 7042, 7125, 7126, 7127, 8125, 8126, 8127, 9742, 1042, 1125, 1126 (Gingerbread, Ice Cream Sandwich, Jelly Bean)
    Skytex Skypad Alpha, Gemini (Ice Cream Sandwich)
    Visual Land Connect, Prestige Ice Cream Sandwich)
    45x Tablets Owned/Tested/Configured/Tweaked/GUI: Running OS: 1.6, 2.0, 2.1, 2.2, 2.3, 3.0, 4.0, 4.1 | Since 2010
    Ads
    Advertising world
  3. #2
    Junior Member Achievements:
    14331
    Jan 2011
    London
    Android 2.1 MID 7" ePAD
    Hi tipstir,
    I have seen that you are giving a great help to all of us who are having problems with the ePads running with Android. Thanks so much. Really appreciate.
    I recently bought a MID 7" ePad with VIA WM8505/533MHz, 256 MB RAM, 2 GB Flash.
    When I start it, it shows me WMT 2.1.2_105 in the boot screen. When I talk to my supplier, he said it is running Android 2.1. However when I go to "About Device" Menu it shows me following information.
    Firmware version: 1.6
    Kernal version: 2.6.29-00236-g4f8dbbb-dirty
    Build number: WMT2.1.2_105
    Can you kindly clarify me the following issues I have.
    1. I'm confused with the Android version I'm running on this device. Is it 2.1 as supplier say or is it 1.6 ?
    2. What is this build number? I have seen that you also discussed quit a lot on that. According to my current understanding, it is the ROM firmware.
    3. Since I have WMT2.1.2_105, do you recommend me to update to further WMT versions such as WM2.2 you published today.
    4. With my current WMT 2.1.2_105, is it possible for me to update to Android 2.1 or 2.2 (frodo) OS ? If so, could you kindly provide me some guidance.
    Thanks you very much in advance Sir!
    Best Regards,
    Neo
    ExpertCore.ORG
    Where Technology Meets Passion
  4. #3
    13651
    Jan 2011
    Hefei,China
    via8505
    i can't connect this web site,tipstir.the-talk.net - Tablet Zone*
  5. #4
    Developer
    Achievements:
    1423
    Aug 2010
    USA
    1,505
    Thanked
    109 times
    Don't get confuse, these are Android OS 1.6 (code name Donut) Only the builds number changes. Like your building something and you change only the build number. Same is the case here. But you can't use this custom build number. You need WMT2.1.2 I have about 4 of those but working on 100% rooted version. But once it gets tested then I'll release it. Again don't use this rom
    Quote Originally Posted by NeoCambell View Post
    Hi tipstir,
    Best Regards,
    Neo
    PowerCode 1000 DCX
  6. #5
    Developer
    Achievements:
    1423
    Aug 2010
    USA
    1,505
    Thanked
    109 times
    Quote Originally Posted by hfutlink View Post
    register to gain access none of the builds are open file access again.
    PowerCode 1000 DCX
  7. #6
    Developer
    Achievements:
    1423
    Aug 2010
    USA
    1,505
    Thanked
    109 times
    All ROMs now have open access
    PowerCode 1000 DCX
  8. #7
    12971
    Jan 2011
    23
    Thanked
    1 times
    will this work on flytouch2 and is adhoc enabled?
    thanks!
  9. #8
    14331
    Jan 2011
    London
    Thanks for the reply. My supplier told me this is Android 2.1 (I'm really worried now). Can you please tell me whether it is possible to update the Firmware Version (i.e.: Android Version) to 2.1 or higher (I would love if it is 2.2 Frodo) ?
    Thanks in advance.
    ExpertCore.ORG
  10. #9
    13651
    Jan 2011
    Hefei,China
    via8505
    tipstir, how can i connect the pad with bluetooth gps module?
  11. #10
    Developer
    Achievements:
    1423
    Aug 2010
    USA
    1,505
    Thanked
    109 times
    No you can't use Flytouch2 with these ROMs. XB or XC for Bluetooth using USB dongle only.
    PowerCode 1000 DCX
Ads:
  1. [ROM] EPAD and APAD Generic v1.6, Build 1.8.2 & 1.9_88 Non-Rooted
    By tipstir in forum Gome Flytouch Firmware
    Last Post: 05-17-2011, 09:56 PM
  2. Custom Clockwork Rooted Recovery for Augen Gentouch
    By xaueious in forum Augen Gentouch
    Last Post: 01-28-2011, 12:56 PM
  3. Latest Releases in Rooted ROM for WMT2.1.1
    Last Post: 01-22-2011, 04:47 AM
  4. Is #157 latest for X5As with g-sensor?
    By arachnophile in forum Telechips TCC8902 Tablets
    Last Post: 12-20-2010, 06:15 PM
  5. Replies: 3
    Last Post: 10-18-2010, 11:10 AM
7inch ebook 2.1 en.rar
google android wmt 2.1.2 105 firmware download#gsc.tab
latest mercury tablet roms
new version flytouch wmt 3
tablet mid android 2.1.2 88
wm8505 android 2.2 download
wm8505 android 2.2 download#gsc.tab
wmt 2.1.2 105
wmt 2.1.2 105 download
wmt 2.2 download
wmt roms
