Page 2 of 2 FirstFirst 1 2
Results 11 to 20 of 20
Thanks Tree1Thanks
Thread: Help Won't Connect to Wifi
  1. #11
    Senior Member Achievements:
    500 Experience Points 1,000 Experience Points 250 Experience Points 100 Experience Points Created Album pictures
    10344
    Dec 2010
    Fort Carson, CO
    250
    Thanked
    16 times
    I have a Flytouch II Generation II with 512mb variation.
    Quote Originally Posted by sheep5161 View Post
    I think you should restart router or System reset
    I have reset my router twice, but like I said, only my wife, well and my daughters (also windows 7,) seem to have a consistent connection. I think my router is biased in favor of Microsoft. :/
    Sent from my Huawei Ascend M860 using Android Tablet Forum App
    Ads
    Advertising world
  3. #12
    22922
    Mar 2011
    123
    Thanked
    7 times
    Quote Originally Posted by dwcunpluged View Post
    If you wife's and daughter's PC are Ok to connect through Wi-Fi. It is your deivce - Tablet has an issue. Find out from your wife or daughter's PC what IP address they have on thier PC (Ipconfig /all). Then you use a static IP address to try out on your tablet. And you will know the answer.
    Remember ie. Ip address: 192.168.0.200
    subnet mask: 255.255.255.0
    Gateway add: 192.168.0.1
    DNS :192.168.0.1
    etc.
    Disable your Static IP address afterwards.
    Good luck.
  4. #13
    10344
    Dec 2010
    Fort Carson, CO
    250
    Thanked
    16 times
    I have tried that with my laptop, which is having the same problem and it still acts up every now and then. Maybe there is just a setting I am missing or something on the pc and the tablet.
  5. #14
    Junior Member Achievements:
    17083
    Feb 2011
    20
    Lol i get that sometime too but that is only cause of the router but i seem to have steady connection on mine right now
  6. #15
    10344
    Dec 2010
    Fort Carson, CO
    250
    Thanked
    16 times
    When I finally do get connected it works fine. I will figure it out soon.
  7. #16
    10344
    Dec 2010
    Fort Carson, CO
    250
    Thanked
    16 times
    And I am an idiot. I keep arning others about accidently deleting things they need and that is exactly what I did to cause my internet to stop working on the tablet. I am now back up and rocking along again.
    Sent from my Flytouch 2 Generation 2 using Android Tablet Forum App
  8. #17
    500 Experience Points 1,000 Experience Points 250 Experience Points 100 Experience Points 3 months registered
    24566
    Apr 2011
    Australia
    131
    Thanked
    18 times
    Flytouch 2 v2
    I have seen many threads with wifi issues on FT3/SP2, especially it seems with update 20110302. Some people report success with reapplying this firmware (Update #3). My friend has same issue, he will wait for next firmware. You could try rolling back to an older firmware, or wait for the next one (My pad came with 20110316 and I have no wifi issues, but I have not seen this firmware for d/l yet?!)
    Anyways, hope you work it out.
  9. #18
    10344
    Dec 2010
    Fort Carson, CO
    250
    Thanked
    16 times
    I actually just reinstalled the update, and then didn't erase the necessary files. Mine works beautifully now. There is now another ROM (beta) posted here in the forum that I am going to tey after I get home: )
  10. #19
    25139
    Apr 2011
    columbus ga
    Thanked
    1 times
    android m860 huawei
    if your phone connects to public networks but not your home this is most likely your problem and solution.............
    the solution is simple, first go into your routers configuration find mac address for your device then the ip your router is issuing to your device make sure the router's ip or any other device on your network, is not the same, if it is give your router a different address,ortry giving your phone a static ip, when two devices have the same ip,this causes conflict....this was my problem on my android phone, huawei accend 860 and i tried everything i discovered this on my own... it works!!!
    Last edited by jwsmith9806; 04-05-2011 at 09:52 PM. Reason: i almost trashed my phone and wish someone could have led me to my conclusion, so if i can help someone else thats good
    dwcunpluged thanked this.
  11. #20
    10344
    Dec 2010
    Fort Carson, CO
    250
    Thanked
    16 times
    Quote Originally Posted by jwsmith9806 View Post
    Glad to see I am not the only one using the Ascend. Hope you are loving yours too. But the wifi connection problem with my tablet was carelessness on my part. I accidently deleted a couple of files I needed. Oops. Thank you for the info about the IP address thing, I have placed that on my troubleshoot checklist.
Ads:
  1. Now it won't connect to home wifi
    By eboomer in forum Android Tablet Q&A
    Last Post: 04-03-2012, 02:21 AM
  2. WiFi connection does not connect
    By Brunis in forum Gome Flytouch
    Last Post: 10-22-2011, 08:43 AM
  3. Unable to connect to WiFi
    By lynneunz in forum eLocity Tablets
    Last Post: 02-07-2011, 09:24 AM
  4. Can't connect to wifi
    By The Don in forum Huawei Ideos S7
    Last Post: 02-01-2011, 09:31 PM
  5. Can't connect to wifi overseas
    By jim harvest in forum Telechips TCC8902 Tablets
    Last Post: 12-02-2010, 10:10 AM
how to reconnect on wi-fi in zeki's tablet
huawei m860 says my network is disabled
huawei m860 wont connect to secure wireless network
my tablet won't connect to wifi
my tablet wont connect to my wifi
my tablet wont connect to the wifi
my tablet wont connect to wifi
tablet won'tconnect to wifi
why won't kocaso tablets connect to my wifi
why wont my tablet connect to the wifi
why wont my tablet connect to wifi
Tags for this Thread
