I have a Spuerpad 10". I am not a tech guy and I am having problems with the USB slots. They do not read or tell me the USB devices are damaged. Any suggestions?
Not quite sure what the issue is. Is it that you are connected your tablet to your pc and nothing happens? Or that you are trying to plug something in to your tablet's USB and nothing happens?
Peter B. - email: tardis@androidtablets.net | Twitter: pbbrauer | Google+: pbbrauer | gTalk: pbbrauer@gmail.com
Current Devices, ROMs:
(Active) VZW Samsung Galaxy Nexus- Rooted, Android ICS 4.0.2 | ASUS Transformer Prime TF201- Rooted, Unlocked, Virtuous Prime-9.4.2.15 v1 ROM
(Retired) Viewsonic gTab - Rooted, Flashback 10.3 (Honeycomb) | Huawei S7 - Rooted, Froyo Fusion R2 | (Other) Nook Color (2 of these) | Gentouch 7/8 - Rooted, Lincrackers Pirate 3
Remember to "Thank" people that help you out! |Click here for general Questions?
when I insert the USB storage cards or I try and connect to anything using the USB slots it always says "damaged storage disk/card" The USB ports just don't work.
can you return the device?
I bought it off of craigslist from a individual. It was new in the box guess I should have known. Came from China. Should have warranty.
ok...all is not lost yet, USB on Android does function a little differently. using your pc, do a full reformat of the sd card as FAT32 and see if that works.
Thank You very much!! I will try that.
good luck and let us know if it works for you
Will do, Thank You.
